I just purchased an Energy esw-v8 and it is my first powered sub. I have a HTIB that has a passive sub. The old sub is connected to the receiver with speaker wires from a subwoofer out. The receiver does not have an RCA out for a sub. The new sub doesn't have speaker level out.
It seems that I have a few options to hook up the new sub. I could run parallel lines from the front left and right on the receiver to the right and left speaker level in on the sub. Could I run speaker wire from the sub out on the receiver and convert that to RCA to plug into the sub? Or could I just plug the speaker wire into the left or right speaker level in on the sub?
Which method, if possible, would have the best quality? Could I leave the old subwoofer connected if I use the parallel lines from the front outs?
I could put up pictures if I didn't explain this well enough.
) If your AVR can be configured that way (a NO SUB setting should default the front speakers to LARGE) then, depending upon the sub's capabilities, it might be possible to high-pass your front speakers off of the sub's speaker-level outputs. But the sub, of course, would have to have high-passed speaker-level outputs in order to do this.
No harm done luckily. Lesson learned--the auto power feature takes a few minutes to shut off power after no signal is present and it's necessary to turn the sub fully off when messing with stuff.
