I have read a bunch of threads on timbre matching and I believe I understand the concept so I was wondering about a couple scenarios:
1. If I buy Def Tech Studio Monitor 350's, which Def Tech Center Channel would be a good timbre match? The CLR 2002 or the CLR 2300?
2. 1. If I buy Def Tech Studio Monitor 450's, which Def Tech Center Channel would be a good timbre match? The CLR 2002 or the CLR 2300?
Thanks!!
Thanks!!
I am hearing sounds I never heard before in movies.
