I just finished putting together my THT..I took extra care to make sure that there are no leaks.. and I used a classic Tempest driver.I couldn't wait to have the second build so I can try them together, so my son helped me haul it from the shop to the tv room. My initial impression of it was of mixed feelings... although it put out lot it failed to match my previous setup... in certain areas.. like in visceral impact.. but it some areas it seemed to excel.I set my Denon 989 to 80hz crossover point and my main speakers are at 60hz... if any of you feel this is off let me know. I also had to boost the subwoofer output on the Denon from -10 to -3..but that was to be expected since my previous setup consisted of 4x15 in a 60 cu.ft box. and it simply was too much for my 300 sq.ft room. To put it in other words,one THT is equal to roughly 1.5 times my 4x15 setup..so if I build the second one it will surely surpass it. If any of you have any ideas I can implement throw them my way...
I used one channel of my Crest CPX 2600 which is around 900 watts... I am planning to sink them into the wall where the other subs are now.. one on top of the other so their fronts are flush with the wall.
Here are some pics I snapped along the way...
