AVS › AVS Forum › Video Components › Home Theater Computers › Merge srt subtitles with mkvs?
post #1 of 14
Is it possible? i hate having folders for my movies just to put the subtitles file in the same folder, i want to insert the subtitles directly into the mkv .
post #2 of 14
You can use MKVtoolnix to put the sub file into the MKV file.
post #3 of 14
How i do i erase the existing subtitles?
post #4 of 14
right click and delete the srt?
If you are talking about an existing sub in the mkv you should be able to just uncheck it in mkvtoolnix.
I like to reencode the mkv with hard subs myself since the only time i use subs is movies that dont have 100% english (district 9 and 2012 the first that come to mind). But that takes a few hours.
post #5 of 14
Yes , all i had to do was uncheck it.
Whats that default/forced track option all about ?
By the way i get an error playing the files i modified with mkvmerge , movie player says: An error ocurred, Can't display both text subtitles and subpictures.
post #6 of 14
post #7 of 14
What tracks do you have in the MKV that you cant play?
post #8 of 14
i get the error after i attach the srt subtititles i want to play, it plays fine in xbmc, but i cant play the modified mkv ( with mkvmerge) in movie player (totem)
post #9 of 14
So when you open the MKV in mkvtoolnix, there are two tracks: one video file and one srt file?
post #10 of 14
This is the error screen:
post #11 of 14
anyone?
post #12 of 14
The mkv file in the screencaps has two kinds of subtitles - VOBSUB and TEXT. The VOBSUB kind is the native format for DVDs - each subtitle is actually a picture that the DVD player overlays on top of the video. The TEXT format subtitle is just regular text like in a word processor.
The error that totem is giving is that it does not like VOBSUB (subpictures) and TEXT subtitles in the same mkv. I would call that a bug in totem - at the very least it should let you pick one and ignore the other.
But the fix should be simple - just remove the unneeded subtitle tracks with mkvtoolnix the same way you added a subtitle.
PS - the "default/forced" stuff is for two things that kind of overlap
1: default - if there are multiple subtitle tracks, the one with "default" set will play if subtitles are turned on in your player
2: forced - even if subtitles are turned off in your player, the forced set will play anyway - this is good for things like translations where the movie is primarly in your native language but maybe there is a sign or a character says a couple of lines in another language - not all players obey the "forced" flag
post #13 of 14
So, my file is fine then? and i should just ignore totem?
post #14 of 14
If you do not want to play them in totem then, yes, you can ignore the error.
