AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › Samsung SMT-H3090 - Adding External memory
post #1 of 5
I have a Samsung SMT-H3090 HD/DVR from TWC.
I'd like to add some external memory to the box, as the current 20 hour HD recording capacity is insufficient.
I see that Western Digital has a product called "My DVD Expander". Could I just not use any external hard drive? The Samsung box has an eSATA outlet on the box, and also a USB outlet.
Does anyone have any experience adding an external hard drive to this box? What needs to be done to set up? Is it simply plug and play?
post #2 of 5
I have the Samsung SMT-H3090 with 320 GB and purchased the 1TB Western Digital DVR Expander. Many tries to have the DVR Expander format (press A to format) with absolutely no luck. The specifications specify that the 1TB Western Digital DVR Expander works with Tivo and I believe the Scientific Atlanta DVR - no mention of the Samsung. I read and am very skeptical about a contributor in July 2009 who was successful getting the WD 1TB to work with the 3090. I haven't yet (it states that the DVR can't read the filesystem (of the WD).
If someone can provide some assistance, I'm all ears. There is an esata port - so I'm open to purchasing any hard drive or expander that works with the Samsung 3090.
JB
post #3 of 5
Any updates?
I had the Western Digital DVR Expander that worked with an SA8300 and when I got an "upgrade" with the Samsung when my 8300 had a problem I lost the storage.
The weird thing is that it shows the capacity as not full, but won't record.
Mike
post #4 of 5
Originally Posted by Mike_WI View Post
Any updates?
Mike
I also had an SA8300 which was hooked up to my 500 GB Seagate External eSata drive. The SA830 finally died and Time Warner brought in a Samsung H3090. When I hooked up my external drive, it asked if I wanted to reformat it and I said yes. It reformatted the drive. It shows the drive as being attached and available with its storage but never records to it. The "list" view shows only about 35% of my drive capacity is used but if it gets to about 36% it says drive full and won't record anything else. It sucks because I really need the extra space -- my daughter records many many shows and I like to have a lot of movies and shows available to watch whenever. If anyone figures out a solution post it here.
post #5 of 5
Pending a fix (and thanks for the comments...), I think I'll move a 8300 box to the family room TV and the Sam to the gym room.
Mike
