AVS › AVS Forum › HDTV › HDTV Technical › HELP***Terrible XBOX360 graphics on my HDTV!!!!
post #1 of 5
TERRIBLE graphic quality on my 1080p HDTV w/ my xbox elite--PLEASE HELP!!
Ok so i just got a Vizio V0370M 2 months ago. I have xbox 360 elite with both HD component cables by rocketfish and HDMI cables by same maker. My LCD looks great with comcast digital cable tv and absolutely beast w/ Blurays but it is TERRIBLE w/ xbox 360 games!!
The graphics on games like COD4, Halo3, COD modern warfare 2, gears2, borderlands, etc---all look awful. They are poorly rendered, jagged lines, blocky, and TERRIBLE textures! It really looks like 1st gen xbox graphics. I will get some screenies for u all later.
I have my console/display settings set to 1080p. I tried 720p, 1080i and no improvement in quality. I tried using my HDMI and HD component--they look the same. Is there a way to manually set the vizio's resolution to match the xbox's? is it a refresh rate issue? Will adjusting the TV's settings like WS/fullscreen/full affect the quality?
I hooked up my xbox to my old sony 36 in XBR CRT HDTV and it looks way better. I understand the xbox upscales the images but this bad?? really??
ANY ADVICE IS GREATLY APPRECIATED!!!
THANKS
-JAROD V
-MA
post #2 of 5
a lot of xbox games are only 720p, which could be your problem. while playing a game, hit the INFO button on your vizio remote, and see what resolution it is playing. it sounds like your xbox is only sending 480, not HD like it should
post #3 of 5
And many of those 720p games are actually 640p. Also you need to remember the XBOX 360 is still using the old DVD-9 technology that the XBOX and PS2 use. Unlike the PS3 which is using blu-ray.
post #4 of 5
Only thing I can think of, is it set to game mode? With my vizio when hooked up by hdmi, I have in full screen & in game mode, and everything looks great
I need to see your screenshots
post #5 of 5
I would have to agree with others' comments about checking your output resolution in the XBox's system settings panel. Perhaps it's set for 480p? I have my XBox 360 connected to my XBR8 via HDMI, and playing games (like Batman: Arkham Asylum, Assassin's Creed II, Bioshock, etc.) looks very good. Is your component cable set to HDMI output mode?
  Back to Forum: HDTV Technical
