Originally Posted by spivonious
Well, I can't find anywhere that states it does HD decoding, but if you say it does then set PowerDVD to bitstreaming (the option says Dolby, but it will bitstream everything). You shouldn't have to do anything else. Check the windows audio control panel for the HDMI connection. It will report everything that the receiver supports. If it's not saying Dolby TrueHD and/or DTS-HD MA, then the receiver is telling the computer that it doesn't support it.
To the other poster: multi-channel PCM audio is EXACTLY the same as bitstreaming the HD codecs. All that changes is which device is decoding the bitstream. Perhaps your receiver isn't handling that input correctly? I've read that some don't apply the correct +4dB LFE boost.
He already stated a couple of times that HD formats don't show up in the control panel, same thing mine does. And I can say for a fact the PCM sounds like crap compared to DD on my sytem anyway. Maybe the board isn't decoding to PCM correctly just like it isn't letting me bit stream. It is very flat and their is no life to it at all. Maybe their is an issue with ATI and the older Asus boards.
So I'm not going to try and put any more effort into getting it to work when I won't need it any more.
). Installed powerdvd10 after that and the third HD audio options showed up...AFTER the movie has allready started. But i've read that allready...but it was still a stretching moment after all those days...uh make that weeks. AND THERE IT FINALY WAS, the True-HD MSTR logo also with big HD-AUDIO letters.
