AVS › AVS Forum › Video Components › Home Theater Computers › ATI HD 5000 Series Known Problems (5870 5850 5770 5750 5670 5570 5450)
ATI HD 5000 Series Known Problems (5870 5850 5770 5750 5670 5570 5450) - Page 11
post #301 of 2705
Originally Posted by thrang View Post
I just submitted a support form and posted the URL to this thread.
+1. Thx for the heads up, Davin.
post #302 of 2705
Originally Posted by sperlsco View Post
Sound Problems:
I was having some strange sound problems. I tested out a couple of 5.1 multi-channel WMA Lossless music files in WMP. If I went into the audio settings and kept the default 2-channel settings, the Denon would only receive 2 channel audio. I changed the audio settings to 5.1 channel, and did tests of each channel to make certain they were all working and properly assigned. When WMP played the files, the Denon would get 5.1 channels – but they would be all switched around (i.e front left would be in left rear, sub would be in rear right, center in left front, etc.). When I went back to the audio settings and re-ran the tests, the channels were now switched around to the wrong places here too (as mentioned in the last sentence). If I re-set the audio as 2-channel, tested, then went back and reset and retested all in 5.1 channel, everything would go back to its proper location – until I played the files again in WMP (which would then move the channels around again). Anyone have any ideas for this?
See #3 in the OP. Just out of curiosity, what output settings do you have for Windows (16/24 bit, 44.1/48/88.2/96/176.4/192 kHz)?
post #303 of 2705
Originally Posted by Tulli View Post
You need an EDID override for the Denon. Have you installed it? If not follow instructions from link on my sig.
[RANT]
Gee I only hope ATI can come up with a fix for this EDID audio crap soon! It's still amazing to me that so many people have to go through this, and that I have to work so much just to cope for their utter incompetence in dealing with such a stupid bug!
[/RANT]
I have done the EDID override and it shows up as being overridden in the Device Manger. I'm just going to uninstall everything and then just start from scratch.
post #304 of 2705
Perhaps send AMD a bill for services rendered...
post #305 of 2705
Originally Posted by Davinleeds View Post
I hope many participate.
http://www.amdsurveys.com/se.ashx?s=5A1E27D27E29B0E3
At the end you can link this thread.
+1. Me too. Figure if they keep hearing the same issues from multiple people they'll be more inclined to fix them.
post #306 of 2705
Glad to report that I finally got the 3rd option on PDVD9 and I get the nice "Blue" light ON. Thanks to all for your help on this thread. I have tried this with a TrueHD and a DTS-HD blu-ray disc. Now to start the mkv converting process.
post #307 of 2705
Have just rechecked your mod and the audio block is perfect. Are you sure the Denon HDMI is set to "AMP"?
Yes, I'm sure. HDMI setup: Lipsync on, audio amp and control off.
post #308 of 2705
[RANT]
[/RANT]
Don't hold your breath... It's been over 1 year and they still can't / won't fix it.
Even if they're too incompetent to figure out how to correctly parse EDID it wouldn't be that hard to add some check boxes for overriding the EDID the card read. Something like "Force True-HD", "Force DTS-MA", "Force 5.1", etc, etc...
post #309 of 2705
If they added those boxes, people would be opening tickets because they checked them but their receiver (which cannot decode them) is not playing any sound.
You have to remember, HDMI Audio is not the bread and butter of ATI (or any other VIDEO card maker). Be happy a video card maker is even attempting it at all.
post #310 of 2705
Maybe someone can help me out.
My video is stuttering randomly. I have tried all of the drivers (hotfix, 8.70RC2) and am using TMT .170 (it was happening with .161 too). I think it has something to do with PowerPlay, because when I watch a video the memory clock is very low, I tried the method here, but the video card is still underclocked.
The highest it will go is Core Clock: 775MHz and Memory Clock: 500 MHz (via GPU-Z), even though CCC is set to 775 and 1000 (the rated speeds of the card) Also CCC shows it at 775 and 900.
It seems that the memory clock is very low, as others say there's is at 900MHz during DXVA, mine wont go past 500, no matter what I put...
I think this is what is causing my stuttering issue.
Also, during video play back my CPU is at 0-3% usage and the memory is 1.25GB/4GB so this isn't causing the issue...
Please help
post #311 of 2705
Thanks Tulli!
I was able to use the default lcd/Denon edid override for my Denon 3808 and my Mits HC6000 projector. I had TMT3 passing DTS Master, but Dolby True was silent. Now both work just fine, it's nice to see these show on the display of the Denon, as well as hear the sound quality.
post #312 of 2705
ATI: Add message text, "Only check the boxes if you know what you're doing! Consult the help button."
Yea, have to agree. Audio is a whole new ball field for a Gfx company. So long as the Realtek driver keeps working I'm happy.
post #313 of 2705
You're right! That worked! Thanks! In hindsight, No. 3 should have been plainly obvious. I had it set for 24/96.
Scott
Now I just have to fix the problem with my secondary LCD monitor disappearing and not being able to be reenabled after applying the EDID mod.
post #314 of 2705
My 5670 running 8.69RC2 and Realtek 2.39 HDMI audio drivers with EDID override has an issue on Windows 7 x64. Everytime I exit Windows Media Center (after starting it and using it or not), I lose audio. My receiver (Denon 790) still shows the Multi Ch In input, but no audio is heard. To fix this, I have to Mute the Windows system audio, then unmute it.
Anyone?
post #315 of 2705
Originally Posted by blaubart View Post
Ummph! But living *doomsday scenario* is a psychogram of forums (and *being kafkaesque*?) but was not intention of AnandTech.
Late reply but I've been busy: I agree with that. AnandTech just reported it and were right to do so. That's the point of their reviews
post #316 of 2705
What did you do and fixed it again??? Did you uninstall all drivers?? In what order did you install them again and what SW version you loaded?
post #317 of 2705
Tuli, do you think it might be wise to open a new "Tuli's EDID patches for EDID problems" thread? It seems several of the ATI threads are being overwhelmed with basicly the same posts over and over... Just a thought.
post #318 of 2705
I have installed everything again but still no 3rd option in Cyberlink and only Multi Channel Direct in Denon
I want to send a trouble ticket for 5570 and neither AMD or Sapphire include it in their list. It is like this product does not exist!! I just submitted one
The worst of all Sapphire do not have even drivers for HD 5570 only a page with the product info. Nothing at all!!! On the other hand AMD have a link for drivers of 55xx series which I assume should do the job for 5570
post #319 of 2705
You will see the third option after playing the disc or iso.
post #320 of 2705
Yes, makes sense.
Andy, what do you think? Should we move the EDID modding to a new thread?
post #321 of 2705
Sure, I have no problem either way, if you wanna keep accepting requests for free
I will change the link in the first post if you do so.
post #322 of 2705
Do I have any choice?
OK will do that right now. Really hope for personal sanity that ATI will fix the problem soon ...
post #323 of 2705
Andy, done.
post #324 of 2705
Finally I managed to get TrueHD in MPC-HC, but no DTS MA. Still good though!
Only task now left is how can I configure XBMC Media Center to do bitstreaming or use at least MPC as player
post #325 of 2705
Or even better, have a checkbox like the overclocking one, which you have to check in order for the other checkboxes to be active.
post #326 of 2705
Andy, done.
Gracias, as always. Updated OP.
post #327 of 2705
Are any of these issues/fixes related to the mis-mapping of side-to-rear speakers when 7.1 is set in Windows Audio when playing 5.1 material? not sure if it's doing it on True HD or DTS HD tracks, but I noticed it playing a few older DVDs via TMT3 - side channel surround was mapped to the rear channels in my 7.1 setup, even though the Windows Sound test tones are correct. Any other traditional source connected to my system plays correctly...
post #328 of 2705
I checked and the mis-mapping also occurs on True HD and DTS-MA material...is this a Windows issue or an ATI issue? This is a new level of annoyance...
Thanks...
post #329 of 2705
I'd like to add two more issues:
1) When starting a 3D game, powerplay switches from 2D mode (157/300mhz) to 3D mode (950/1400 in my case), and that makes the game laggy. I noticed it's an issue with memory, from 300/1400 to 950/1400 there is no problem at all.
2) When using auto refresh rate change in MPC-HC, it resets graphics card so that the TV is disconnected first and re-connected, this causes MPC-HC crash (no screen found).
post #330 of 2705
AFAIK and in my experience, when you start a 3D game, the clocks are always at their rated speed. Mine never goes down when playing, it stays at 850. How can you tell the lag is from Powerplay, what does it look like?
About the second one, I've tried that feature with various builds of MPC-HC and they're different. It's a new feature that is only available on the SVN as far as I know, and it's probably still buggy. Those aren't even the same as your regular public beta, they're being updated all the time. Better let the folks at doom9 know about it.
