There is also one another issue I want to mention:
It seems that I cannot get x.v.color output to work
Anyone has experience?
Â
RGB-YCC.zip 5.4130859375k . file
Time: 7:56:49 AM
Date: Thursday, March 04, 2010
EDID Manager Version: 1.0.0.14
___________________________________________________________________
Block 0 (EDID Base Block), Bytes 0 - 127, 128 BYTES OF EDID CODE:
0 1 2 3 4 5 6 7 8 9
000 | 00 FF FF FF FF FF FF 00 41 2F
010 | 00 00 01 01 01 01 00 12 01 03
020 | 80 6E 3E 78 2A 6D A4 A1 54 35
030 | B3 26 14 4A 52 2F CF 00 81 80
040 | 8B C0 A9 40 81 40 81 00 81 40
050 | 90 40 B3 00 02 3A 80 18 71 38
060 | 2D 40 58 2C 45 00 4E 6C 42 00
070 | 00 1E 02 3A 80 D0 72 38 2D 40
080 | 10 2C 45 80 4E 6C 42 00 00 1E
090 | 00 00 00 FD 00 17 55 0F 45 10
100 | 00 0A 20 20 20 20 20 20 00 00
110 | 00 FC 00 56 53 58 2D 30 31 54
120 | 58 48 0A 20 20 20 01 25
(8-9) ID Manufacture Name : PIO
(10-11) ID Product Code : 0000
(12-15) ID Serial Number : N/A
(16) Week of Manufacture : 0
(17) Year of Manufacture : 2008
(18) EDID Version Number : 1
(19) EDID Revision Number: 3
(20) Video Input Definition : Digital
(21) Maximum Horizontal Image Size: 110 cm
(22) Maximum Vertical Image Size : 62 cm
(23) Display Gamma : 2.20
(24) Power Management and Supported Feature(s):
Active Off/Very Low Power, RGB Color, Non-sRGB, Preferred Timing Mode
(25-34) Color Characteristics
Red Chromaticity : Rx = 0.626 Ry = 0.330
Green Chromaticity : Gx = 0.206 Gy = 0.696
Blue Chromaticity : Bx = 0.150 By = 0.080
Default White Point: Wx = 0.290 Wy = 0.320
(35) Established Timings I
640 x 480 @ 60Hz (IBM, VGA)
640 x 480 @ 72Hz (VESA)
640 x 480 @ 75Hz (VESA)
800 x 600 @ 56Hz (VESA)
800 x 600 @ 60Hz (VESA)
(36) Established Timings II
800 x 600 @ 72Hz (VESA)
800 x 600 @ 75Hz (VESA)
1024 x 768 @ 60Hz (VESA)
1024 x 768 @ 70Hz(VESA)
1024 x 768 @ 75Hz (VESA)
1280 x 1024 @ 75Hz (VESA)
(37) Manufacturer's Timings (Not Used)
(38-53) Standard Timings
1280x1024 @ 60 Hz (5:4 Aspect Ratio)
1360x765 @ 60 Hz (16:9 Aspect Ratio)
1600x1200 @ 60 Hz (4:3 Aspect Ratio)
1280x960 @ 60 Hz (4:3 Aspect Ratio)
1280x800 @ 60 Hz (16:10 Aspect Ratio)
1400x1050 @ 60 Hz (4:3 Aspect Ratio)
1680x1050 @ 60 Hz (16:10 Aspect Ratio)
(54-71) Detailed Descriptor #1: Preferred Detailed Timing (1920x1080 @ 60Hz)
Pixel Clock : 148.5 MHz
Horizontal Image Size : 1102 mm
Vertical Image Size : 620 mm
Refresh Mode : Non-interlaced
Normal Display, No Stereo
Horizontal:
Active Time : 1920 Pixels
Blanking Time : 280 Pixels
Sync Offset : 88 Pixels
Sync Pulse Width: 44 Pixels
Border : 0 Pixels
Frequency : 67 kHz
Vertical:
Active Time : 1080 Lines
Blanking Time : 45 Lines
Sync Offset : 4 Lines
Sync Pulse Width: 5 Lines
Border : 0 Lines
Digital Separate, Horizontal Polarity (+), Vertical Polarity (+)
Modeline: "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
(72-89) Detailed Descriptor #2: Detailed Timing (1920x1080 @ 50Hz)
Horizontal:
Blanking Time : 720 Pixels
Sync Offset : 528 Pixels
Border : 0 Pixels
Frequency : 56 kHz
Vertical:
Border : 0 Lines
Modeline: "1920x1080" 148.500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
(90-107) Detailed Descriptor #3: Monitor Range Limits
Horizontal Scan Range: 15kHz-69kHz
Vertical Scan Range : 23Hz-85Hz
Supported Pixel Clock: 160 MHz
Secondary GTF : Not Supported
(108-125) Detailed Descriptor #4: Monitor Name
Monitor Name: VSX-01TXH
(126-127) Extension Flag and Checksum
Extension Block(s) : 1
Checksum Value : 37
Block 1 ( CEA-861 Extension Block), Bytes 128 - 255, 128 BYTES OF EDID CODE:
0 1 2 3 4 5 6 7 8 9
128 | 02 03 51 F1 5C 14 05 1F 90 12
138 | 03 13 04 11 02 16 07 15 06 20
148 | 01 1E 26 0F 24 1D 25 0E 23 1A
158 | 0B 19 0A 3B 09 7F 07 0F 7F 07
168 | 15 07 50 3E 1E C0 4D 02 00 57
178 | 06 00 5F 7E 01 67 7E 00 77 1F
188 | 03 83 4F 00 00 6C 03 0C 00 13
198 | 00 B8 2D C0 11 11 22 22 E2 00
208 | 79 01 1D 80 D0 72 1C 16 20 10
218 | 2C 25 80 4E 6C 42 00 00 9E 01
228 | 1D 80 18 71 1C 16 20 58 2C 25
238 | 00 4E 6C 42 00 00 9E 00 00 00
248 | 00 00 00 00 00 00 00 AD
(128-130) Extension Header
Revision Number : 3
DTD Starting Offset: 81
(131) Display Support
DTV Underscan, Basic Audio, YCbCr 4:4:4, YCbCr 4:2:2
Number of Native Formats: 1
(132-160) Video Data Block
1920x1080i @ 50Hz - HDTV (16:9, 1:1)
1920x1080i @ 59.94/60Hz - HDTV (16:9, 1:1)
1920x1080p @ 50Hz - HDTV (16:9, 1:1)
1920x1080p @ 59.94/60Hz - HDTV (16:9, 1:1) [Native]
720x576p @ 50Hz - EDTV (16:9, 64:45)
720x480p @ 59.94/60Hz - EDTV (16:9, 32:27)
1280x720p @ 50Hz - HDTV (16:9, 1:1)
1280x720p @ 59.94/60Hz - HDTV (16:9, 1:1)
720x576p @ 50Hz - EDTV (4:3, 16:15)
720x480p @ 59.94/60Hz - EDTV (4:3, 8:9)
720(1440)x576i @ 50Hz - SDTV (16:9, 64:45)
720(1440)x480i @ 59.94/60Hz - SDTV (16:9, 32:27)
720(1440)x576i @ 50Hz - SDTV (4:3, 16:15)
720(1440)x480i @ 59.94/60Hz - SDTV (4:3, 8:9)
1920x1080p @ 23.97/24Hz - HDTV(16:9, 1:1)
640x480p @ 59.94/60Hz - EDTV (4:3, 1:1)
1440x576p @ 50Hz (16:9, 32:45 or 64:45³ ))
2880x576p @ 50Hz (16:9, 16:45, 32:45, or 64:45´)
1440x480p @ 59.94/60Hz (16:9, 16:27 or 32:27³ )
2880x480p @ 59.94Hz/60Hz (16:9, 8:27, 16:27, or 32:27´ )
1440x576p @ 50Hz (4:3, 8:45 or 16:15³ )
2880x576p @ 50Hz (4:3, 4:15, 8:15, or 16:15´ )
1440x480p @ 59.94/60Hz (4:3, 4:9 or 8:9³ )
2880x480p @ 59.94Hz/60Hz (4:3, 2:9, 4:9, or 8:9´ )
2880x576i @ 50Hz (16:9, 16:45-160:45² )
2880x480i @ 59.94/60Hz (16:9, 8:27-80:27² )
2880x576i @ 50Hz (4:3, 2:15 – 20:15² )
2880x480i @ 59.94/60Hz (4:3, 2:9–20:9²)
(161-188) Audio Data Block
Audio Format #1 : LPCM, 2-Channel, 24-Bit, 20-Bit, 16-Bit
Sampling Frequency : 192 kHz, 176.4 kHz, 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz, 32 kHz
Audio Format #2 : LPCM, 8-Channel, 24-Bit, 20-Bit, 16-Bit
Audio Format #3 : AC-3, 6-Channel, 640 k Max bit rate
Sampling Frequency : 48 kHz, 44.1 kHz, 32 kHz
Audio Format #4 : DTS, 7-Channel, 1536 k Max bit rate
Sampling Frequency : 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz
Audio Format #5 : DSD, 6-Channel
Sampling Frequency : 44.1 kHz
Audio Format #6 : E-AC-3, 8-Channel
Audio Format #7 : DTS-HD, 8-Channel
Audio Format #8 : MLP/Dolby TrueHD, 8-Channel
Audio Format #9 : WMA Pro, 8-Channel
Sampling Frequency : 96 kHz, 88.2 kHz, 48 kHz, 44.1 kHz, 32 kHz
(189-192) Speaker Allocation Data Block (SADB)
Rear Left Center/Rear Right Center Audio Channel (RLC/RRC)
Rear Left/Rear Right Audio Channel (RL/RR)
Front Center Audio Channel (FC)
Low Frequency Effect Audio Channel (LFE)
Front Left/Front Right Audio Channel (FL/FR)
(193-205) Vendor Specific Data Block (VSDB)
IEEE Registration Identifier: 0x000C03
CEC Physical Address : 0x0013
Maximum TMDS Clock : 165MHz
(206-208) Video Capability Data Block (VCDB)
(209-226) Detailed Descriptor #1: Detailed Timing (1920x1080i @ 50Hz 16:9 Apsect Ratio)
Pixel Clock : 74.25 MHz
Refresh Mode : Interlaced
Horizontal:
Border : 0 Pixels
Frequency : 28 kHz
Vertical:
Active Time : 540 Lines
Blanking Time : 22 Lines
Sync Offset : 2 Lines
Border : 0 Lines
Modeline: "1920x1080i" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
(227-244) Detailed Descriptor #2: Detailed Timing (1920x1080i @ 60Hz 16:9 Apsect Ratio)
Horizontal:
Border : 0 Pixels
Frequency : 33 kHz
Vertical:
Border : 0 Lines
Modeline: "1920x1080i" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
(245-254) Post DTD Padding
Residual Byte Padding: 00000000000000000000
(255) Checksum Value: 173
Does anyone know if there is any BT 601 test pattern so that I can see if it looks correct?
Â
Color 601-709.zip 49.328125k . file|
Oh man, you want me to move my TV? Yeah, that one's passing through the VSX-01TXH. I thought I edited the post with that info but I guess I forgot and closed the tab. I'll see if I can just mirror my way behind the monitor tomorrow and connect the cable.
Â
vsx01_krp Monitor Driver.zip 1.2353515625k . file
Time: 7:56:49 AM
0 1 2 3 4 5 6 7 8 9
Horizontal:
Border : 0 Pixels
Frequency : 67 kHz
Vertical:
Border : 0 Lines
Horizontal:
Border : 0 Pixels
Frequency : 56 kHz
Vertical:
Border : 0 Lines
Checksum Value : 37
0 1 2 3 4 5 6 7 8 9
Revision Number : 3
2880x576i @ 50Hz (4:3, 2:15 - 20:15² )
2880x480i @ 59.94/60Hz (4:3, 2:9-20:9²)
Horizontal:
Border : 0 Pixels
Frequency : 28 kHz
Vertical:
Border : 0 Lines
Horizontal:
Border : 0 Pixels
Frequency : 33 kHz
Vertical:
Border : 0 Lines
