According to my reading is best to avoid running speakers wires in parallel and close to electrical wiring. I belive, one option is to cross low voltage signal and speaker wires at 90 degrees to electrical wiring at at least 16" apart..
I was wondering if :
Would be ok running speakers wire in parallel to other speakers wires inside pvc electrical conduit or smurf tubes inside the walls/ceilings? or would create any issues (noise)?
Also, can you run Cat 6 or HDMI cable in parallel with speakers wires or each other? If so, would be best to run the cables and wires in parallel at a specific distance from each other?
Thank you
Thank you
