OK guys this maybe a little premature because I have to wait for my HF sections to come. I am building my version of the JBL 3731. It will utilize the same waveguides and drivers that are in the 3731 but I am building BFM omnitop 15's(minus tweeters) for my 15 inch driver so I can have a fully loaded horn system in my theater. These will measure 62 x 30 x 17.5 when finished. I am going with either a biamped or triamped version. The biamped will utilize JBL's crossover for a smooth transition from the HF to the MF and I will use a DCX 2496 for the bottom section. If I triamp then I will utilize 2 DCX 2496's for all the crossovers. What do you guys think? Right now I am waiting for my woofers to come in and then the HF sections with compression drivers. I have the MF sections and woofers that go in them. I took a few pics of them but I have not started yet. Once I get the 15's I will start to build. I wanted to post a thread to maybe get some ideas from the members here.
I will take better pics when I get going.
This is what the boxes look like when it arrives. The big box are the 3 MF waveguides and the smaller box has six 6.5 inch woofers. The waveguide is built out of hard molded plastic.
Inside the woofer box
The MF waveguide that is bigger than most people's speakers.
