AVS › AVS Forum › Audio › Speakers › Ceiling mounted speakers
post #1 of 5
I am creating a great rec room / man cave which will feature a large projection screen. At the front of the room I have the luxury of being able have free standing speakers and subs. Unfortunately the rear of the room would be hampered by a bar in the middle which means that I am forced to use some sort of ceilling mount speakers. My general setup can be seen at
http://ssgross.com/Basement/BasementPlans.gif
http://ssgross.com/Basement/ScreensRender.jpg
The main viewing couch will be right in front of that half wall / bar.
For the front, I was thinking about using the Infinity Classia 336 series for the fronts, center, and subs. Are these decent choices or can I get more for my money elsewhere.
What should I do for the rear ceiling mounted speakers? I will have a 7.2 surround setup so I will need 4 of them. Thanks for any help. I am learning as fast as I can.
post #2 of 5
anyone?
post #3 of 5
I'm using Polk RC80i in ceilings in my 5.1 setup. I would have loved to have proper surround speakers, but unfortunately my setup won't allow that. I only have room for 1 row of seating, and it's up against the back wall. Placing them on the side walls is out, I don't have a wall on the right side. The in ceilings work fine, just make sure you get some that have aim-able tweeters.
post #4 of 5
Thanks for the reply. I am setting up for 7.2 sound, would you use the same speakers for all 4 rear channels? Does it matter?
post #5 of 5
nevermind on this comment
  Back to Forum: Speakers
