AVS › AVS Forum › Video Components › Home Theater Computers › Can MC play multi .ts files seemlessly?
post #1 of 4
Is there any way to get Win 7 MC to play multi chunk .ts files seemlessly (like Theatertek does)? I have a LOT of movies in 100 meg chunks and would hate to have to convert to one big file (unless I really have to).
post #2 of 4
ITs pretty simple to combine them - copy /b *.ts newfile.ts (from a command prompt)
post #3 of 4
I know how easy it is to do, I just don't feel like having to spend hours doing it. I probably have several hundred movies stored this way.
post #4 of 4
That is why "perl" was invented. You should be able to write a quick script which will pattern match on the names of the files to be able to then do the copy/merge.
