I'm renovating my basement, which will become a home theater over time as budget allows. I've attached the layout sketch below. I want to soundproof because I have a young baby and a wife who goes to bed early. I've done a lot of reading here and elsewhere on soundproofing techniques, and it seems that double drywall, green glue, isolation clips and hat channel for the walls and ceilings is my best bet.
However, because I don't have a dedicated basement room for home theater, my basement also has a 3-piece bathroom, a utility room and a laundry room. In the utility room, I don't think I'm even allowed to drywall the exterior wall where my boiler is as per building code. In the bathroom, I'm not sure how practical it is to soundproof an environment where there is lots of moisture. And I know from reading about how it doesn't matter where the hole is in the bucket, if there's a hole it will leak. So if I can't soundproof properly this entire space, then whatever expense and effort I undertake for the main walls/ceilings of my basement will go to waste since the sound will leak through the utility room or bathroom or laundry room up to the main and 2nd floors.
Therefore, am I better off just to use regular resilient channels with a single layer of drywall plus Roxul Safe and Sound insulation in the ceiling? I know this is not the preferred way, but I'm not sure if doing proper soundproofing for 75% of the area instead of 100% is any better?
What do you recommend in soundproofing my open area home theater? Thanks in advance for your help!
