AVS › AVS Forum › Display Devices › CRT Projectors › g70 soft picture
g70 soft picture
post #1 of 7
tubes have just over 10000 hour. but green is a 6 1/2, blue 7 ,and red perfect.if i run 480 p tv or 1027 768 60 hz for pc- it stays sharp but any higher it gets real soft, was running it at 1080p for 8000 hours wonder if i overdrove it to long? contrast has been 55 and brightness about the same
post #2 of 7
you've run 1080p for more than 6 years?
post #3 of 7
8000 hours is 333.33 days non stop.
Nashou
post #4 of 7
Hi,
Just wondering how was your picture at 1080p? I have a G70 yet to install and was wondering how it projects at that resolution.
post #5 of 7
I'm running my G70 at 1080p with a moome card and a Sony BDP 360 Blu-Ray player. It does not fully resolve 1080p, but the image looks very good indeed. I had to disable akb and re-calibrate.
Sunstone, this is probably a statement of the obvious, but did you refocus at 1080P? Just curious, as the focus memories follow the resolution.
post #6 of 7
had projector for 2 1/2 years ,i use it for everything pc tv games, runs all the time . will not focus tight on anything higher than 1027 768 at 60 hz .use to use 85 hz all the time for pc . focuses real good at 60hz at low rezs and 1080p used to look awsome untill about 800 hours or so ago
post #7 of 7
Nashou
Exactly! I estimated 4hrs/day 7 days week.
  Back to Forum: CRT Projectors
