I know this is a very subjective question. Therefore, I will propose it as such -
You have two B&W floorstanding speakers of high quality and a velodyne minivee.
You have no plans of moving into a 4.1, 5.1 or 7.1 in any sort of the near future. This is not debatable.
What receiver would you go for under 500? under 1k? under 2k?
(I have been told to look entirely within 2-channel receivers)
two that i've looked at so far are the denon avr-697ci and the yamaha rx-797 (which i'm leaning towards). but i'd like some feedback on other options like the NAD (C 725BEE), etc. I'd also be interested in a suggestion from a different era.
thanks for your help.
(uses would be tape player (minimum), blu ray (most), phono (lots), ipod (lots) and cable (not so much).
