Originally Posted by
obi1234
I am playing with Flingo right now. I'll try to post my progress.
Went to flingo.org - website flung video showed up in Web Video app but played sound only + black screen. Trying to exit app crashed TV required unplug+replug to recover.
Downloading Flingo windows pc app and attempting to fling a video from my laptop. Not sure anything I have is properly encoded...will see. Will make separate post with video requirements from Flingo.org forums post.
Edit: Same result as above, possibly due to firmware identifying tv as 422 not 552 as it should..calling CS to correct now.
UPDATE: CS helped me fix the issue with Model number and I tried to play "Big Buck Bunny" video that flingo has up as a test, same result.
Sound only. Black Screen with a "play" arrow in the far right corner and no control of set - requires unplugging/replugging before I can even turn the set back on.
Update 2: Fling video from the website still plays sound only and no video - then locks up TV requiring reboot. After this behavior happens then no videos on Web Video will play.
I deleted the widget and re-added it and was able to play the video's already there, but trying to fling the Big Buck Bunny video from the flingo.org website seems to add the video multiple times (like 5+) in the queue. If I try to play it...same deal, lock up. So no progress.
Either our firmware update or some glitch on the flingo.org website/player seems to be the culprit.
