AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › VIZIO INTERNET APPS (VIA) Enabled LCD's Thread
VIZIO INTERNET APPS (VIA) Enabled LCD's Thread - Page 26
post #751 of 753
Just so you know, if you are considering buying a Roku, Android USB Stick or WD Live box to watch .mkv or .flv files, DON'T! Vizio TV's Can Play Matroska and Flash (.mkv and .flv) Video Formats! I now love my Vizio 70" TV even more... Yeap, besides .asf, .wmv, .avi (Xvid & Divx), .mp4, .mov, .mpg, .mpeg, .vob (DVD), and others that it can see from a USB device, you can change the file extension for .mkv and .flv to .mp4 and you will be able to see the file on the Vizio Media app, just click on it and it will load the correct codecs for the file and play it beautifully.
Note: .webm, and .rmvb won't play due to missing codecs (.RMVB will only show a black screnn with audio since it loads the .rm or .ra audio codecs).
My guess is that the processor they are using like the Armada on the Co-Star, can play many formats but due to licensing they do not enable all of them and only let you see some of them. Since the codecs are there, it by default loads the correct one to play the container even if it has another file extension just like VLC Player and others due.
Much better than a Roku (can only play .mp4 and some .mkv types) and no need to transcode or buy an Android box or WD live box biggrin.gif
post #752 of 753
There's a lot of talk about the use of the Media streaming feature (DLNA). You may notice it can pick up shared folders wirelessly from your PC. Vizio will tell you it is impossible to stream but this is not true. You can! I do! All u need to do is download and install the PS3 media server on your PC. Add folders (1 or 2 cause the more u add the longer it takes to read), and that's it. For videos make sure the file is converted to the correct readable file type. I use AVS Converter and use a setting with Mpeg 2/avi.
You can also stream from an iPhone/iPad etc. just recently figured that out. Pretty cool.
post #753 of 753
Originally Posted by alwayslearing View Post
I gave up trying on the wireless route, and just ran a cable to it. Was simple.
TV gets an amazing over the air signal.
Two questions:
Is there a way to add widgets beyond what can be downloaded from built in Yahoo? Perhaps to run the no fee version of Hulu or something similar?
Our Sony LCD has a great TV guide menu. Is something similar on this set, and if so, where? It's frustrating only to see a "guide" that is limited to the channel that the TV is set to.[/quote
I have issues with Crackled app playing and then freezing. First wirelessly, so I brought out the long Ethernet cord and guess what.... No better. Still freezes. I uninstalled the app, reinstalled, checked settings everything! Wtf
