I was just curious if it was possible to give a PDP-6020FD the color tweaking functionality of the PRO-151FD by swapping one of the boards out? I been searching and it seems like most of there boards are the same part# maybe they are just hardcoded differently. Anyone know anything about this and which board if it is possible?
Thanks in advance.
EDIT: Yes it is possible. I thought I would move some of the Project "E-LITE" information to the front for easy reference.
Wrinklefree's website has an outstanding rundown: http://www.hippotechsolutions.com/?page_id=2693
Unlock ISF After board swap. See Calibration Forums and contact Turbe(Tell him you have a 9G non-elite with an ELITE I/O board or E-LITE): http://www.controlcal.com/forum/index.php
Also check out these posts: http://www.avsforum.com/avs-vb/showt...5#post19230005 and http://www.avsforum.com/avs-vb/showt...9#post19202059
I also attached my attempt at a clear as mud rundown but you will have to suffer my mindless ramblings
Thanks in advance.
Can the Pioneer 9G Non.pdf 341.8330078125k . file
