AVS › AVS Forum › Display Devices › Rear Projection Units › Sony SXRD Past & Present Owner's Poll
post #1 of 34
Hi. I'm a long time reader here. I have used AVSFORUM to help me make all of my Audio Video decisions. I would like to start a Stats Poll on the Sony SXRD line so that some of us could go to one place to tally the obivious OB problems with the various models. Perhaps it could help all of us in fighting with Sony if necessary or our attorney's if we choose to go that route.
1. Model #: XBR2 70"
2. Build Date & Software Version: January 2007 SP3
3. Date Purchased: 08/06/07
4. How Many Hours on Set: 7720
5. How Many Bulb Changes & Brand: 1; XL-5300 supplied by Sony
6. How Many OB Replacements: 0
7. Date Ext Wtty Expires if applicable: 08/06/11 with BB
8. Location and Environment: USA, FL 1 story home; AC kept 74
Thank you if you choose to participate. Please just leave a post of 1 thru 7 with your answers and any additional comments you have. I love my XBR2 70". I can not find any other set I like as well for the money. I will hate to lose the 70" screen.
Jim
post #2 of 34
Great Idea. I will add mine soon once I get the build date of the back of TV.
One suggestion, in your first post maybe link to the post that shows how to determine the hours, this way people who don't know will be more inclined to post and then include this info.
Short version below (Full version):
1. With the set OFF, grab your remote and enter the following within 1 sec of the previous button:
2. DISPLAY - 5 - VOLUME DOWN - TV POWER
3. You'll see a screen overlay. Last 5 digits on the bottom right is the bulb hours.
4. Hit POWER again to EXIT this mode and shut off the set.
Is this thread for LCD, RP, FP? If so you might want folks to specify this. While it could be determined by model, it would be easier just to have this compiled here.
Also it would be great if folks could list the replacement bulbs they used - brand (osram, philips), online site purchase from, hours on tv that replacement occurred, and any issues with bulb. This way we can also see from this tally what the best bulbs are as I know a batch coming from somewhere is having flickering issues.
And since heat seems to play an issue, maybe Location and environment description.
Examples:
USA, IL, 2 story home on lower level, AC kept low around 68, winters cold
USA, TX, 1 level home TV in basement, AC kept medium, basement always cool
USA, FL, 1 level home TV, AC kept around 75
post #3 of 34
1. Model #: KDS60-A3000
2. Build Date & Software Version: SEPT 07, firmware update "T" via USB
3. Date Purchased: 10/15/07
4. How Many Hours on Set: 7060
5. How Many Bulb Changes: 1 (@ 6900hrs, w/ OEM XL-5200 cage+phillips)
7. Date Ext Wtty Expires if applicable: n/a
8: Environment: Northeast USA, 75F avg. room temp, excellent ventilation
9: Power: stable 125v, no power outages while running, low-lightning strike area
OB at 7000 hours showing ZERO signs of deterioration, discoloration. PQ is superb. Frequent recalibration, color convergence via service menu and interior lined with Duvetyne make this set significantly different from average.
post #4 of 34
1. Model #:KDS-60A2000
2. Build Date & Software Version: November 2006 SP3
3. Date Purchased: 12/29/06
4. How Many Hours on Set: 4230
5. How Many Bulb Changes: 0
7. Date Ext Wtty Expires if applicable: N/A
post #5 of 34
1. Model: KDS-60A2000
2. Build Date: July 2006-SP3
3. Purchased: August 2006
4. Hours on the set: 5325
5. Bulb changes: 0
6. OB Replacements: 1
7. Date Ext Warranty expires: n/a
post #6 of 34
1. Model #: KDS 60A3000
2. Build Date & Software Version: Dec 07 software "T"
3. Date Purchased: 3/08
4. How Many Hours on Set: 10,100
5. How Many Bulb Changes: 2 (1st phillips @ 5500, 2nd osram @ 10,000)
TV looks just as good as when I bought it.
post #7 of 34
1. KDS-60A2000
2. August '06 SP3
3. 8/8/06
4. 3421
5. 0, Original Bulb in place
6. 0, Original OB in place
7. No Warranty
post #8 of 34
KDS-60A3000
built October 2007, firmware T
purchased 1-18-2008
6407 hours on TV
1 bulb change(bulb did not fail, kept original as emergency spare)
0 optical block failures or issues
extended warranty expires 1-18-2012
Location Michigan, TV is on first floor of 2 story home. Average winter temp 65 degrees, average Summer temp 72 degrees.
post #9 of 34
Class Actions have already been filed and settled for SXRD's.
They have extended warranty replacements and in some cased offer replacement tvs.
post #10 of 34
Not entirley correct. Some of the class action suits are stll pending. Check out this link for a comprehensive discussion: http://sites.google.com/site/sonylcdrptvproblems/
post #11 of 34
dm145....Some models of SXRD's do not have class action suits filed yet. They are newer models and do not have the hours on the set, but they soon will.
Also, the suit is pending if I read correctly on the XBR2's.
post #12 of 34
1. Model #: KDS-50A3000
2. Build Date & Software Version: Sept. 2007, USB Update "T"
3. Date Purchased: 02/14/08
4. How Many Hours on Set: 4562
5. How Many Bulb Changes & Brand: 0
8. Location and Environment: Northeast USA; On 2nd Floor of split-level home; 68F Winter/72-76F Summer;
TV stand - no top/sides/back; 6" clearance TV back to wall; Golden Retriever fur everywhere
My first HDTV ... no problems so far. Not sure I use it enough that the extended warranty will ever help me if needed. But I'm not going to worry about it and just try to enjoy it as long as it lasts.
post #13 of 34
Hello,
1. Model KDS-55A3000
2. Build Date & Software Version: August 2007 (Cnet Update)
3. Date Purchased: 07/24/08
4. How Many Hours on Set: 11,000 (BB Floor Model)
5. How Many Bulb Changes & Brand: 2 (Sony XL-5200) I sweet talked Sony into sending me 2 free bulbs. One after the warranty lapsed. I have never had a bulb go out, I just wanted the newest bulb possible. I still have 1 Replacement Bulb available from my BB PSP.
6. How Many OB Replacements: 1 (2/15/10)
7. Date Ext Wtty Expires if applicable: 07/24/11 with BB
8. Location and Environment: USA, FL 1 story home; AC kept 72
I was shocked that my OB failed as the A3000's have seemed less prone to OB failures, but since the replacement it looks better than it ever has.
Cheers,
AD
post #14 of 34
How do you tell how many hours are on the set? Sony SXRD.
post #15 of 34
Hello,
Marine Cop, check out Post#2 on this thread.
Cheers,
AD
post #16 of 34
Originally Posted by Audiodork View Post
Hello,
Cheers,
AD
Thank you. I just got my OB replaced today on my Sony SXRD (50"). I bought it in December of 2006. Also I have replaced the bulb/lamp once over a year ago.
Note to all: My repair man said the one main cause of the OB going bad is because of heat. He has replaced many of them because of this. He stated that dust build up will cause it to over heat and anyone who owns this type of set should take off the plastic back plate and vacum it to get all of the dust out at least once a year. He has the same set I have (60" though) and has never had a problem because he vacums the dust out of the vent and fans.
post #17 of 34
Hello,
Marine Cop, good advice about vacuuming the rear panel. Today, I called BB Extended Warranty Dept and got another XL-5200 mailed out.
I did this just in case the bulbs become scarce in the future. I just replaced my bulb 3 months ago thanks to the kindness of Sony giving me one for free 3 Months after my Warranty lapsed. The one that had been in it had been replaced within a week of purchase due to buying a Store Display.
Very stoked that I managed to get two free bulbs and a free Remote Control (BB gave me a Remote from another Model) from Sony since purchasing in June 2008. And I guess (unfortunately) an Optical Block too.
So now, I will have 3 XL-5200's. One with 5 thousand hours, one with 2 thousand hours (current one) , and a Brand New XL-5200.
Cheers,
AD
post #18 of 34
1. Model #: KDS-60A2000
3. Date Purchased: 03/03/07
4. How Many Hours on Set: a mere 2000!!!
5. How Many Bulb Changes & Brand: 1; XL-5200 supplied by Vann's
8. Location and Environment: USA, Illinois, set diagonally in our walk-out basement family room, temps kept around 70 deg.
Replaced lamp upon Sony's suggestion when TV began to shut itself off, then restart on its own back in Dec. 2009. Lamp made no difference, but kept it in anyway. TV showed error code that neither Sears nor Sony is sure what it means. Replaced 2 circuit boards (A1 and QM). Presently waiting to try a 3rd A1 circuit board, believed to be the one to fire up the lamp. TV has been unoperational since we turned it on to watch the Super Bowl. No OB issues as yet.
post #19 of 34
How involved is that?
post #20 of 34
Model SXRD55A200
Build Date :UNK
Purchased 07/2006
Hours on set I would guess 8000 or so
Bulb replaced 3X
OB replaced 5X
Extended Warrantee exp 07/09
Location main TV in Family Room
Sony never admitted any issues with the TV even though the OB was replaced over and over again but a Sony certified repair tech. Finally ABT Electronics took the TV back and sold me a Samsung UN55B6000 for $1060 out the door last summer and took the Sony back. Then 2 weeks later Sony called offering to replace the set. Filed with the BBB and the Attorney General's Office but Sony never replied.
This TV and my PS3 are the worst pieces of electronics I have ever owned.
post #21 of 34
1. Model #: KDS-60A300 (60")
2. Build Date & Software Version: October 2007
3. Date Purchased: 01/05/08
4. How Many Hours on Set: 4340
5. How Many Bulb Changes & Brand: 1; Osram/Sylvania with OEM specs
7. Date Ext Wtty Expires if applicable: 01/12 for everything but OB. For OB, 3 year warranty after Sony warranty expires. My extended warranty added 3 years to whatever Sony warranties.
8. Location and Environment: USA, GA 1 story home; AC kept 74/75
post #22 of 34
1. Model #: XBR1 60"
2. Build Date & Software Version: April 2010
3. Date Purchased: 10/30/05 (Sony replaced entire set in June 2006 due to bad OB.)
4. How Many Hours on Set: 4500-5000...Guesstimation
7. Date Ext Wtty Expires if applicable: 11/01/12 with BB extended EW.
8. Location and Environment: USA, CA1 story home; Temperature varies.
OB replacement occurred on May 15th 2009...No sign of any degradation yet. Uniform color of grayscale.
post #23 of 34
1. Model #: KDS-50A2000 (65")
2. Build Date & Software Version: have to check
3. Date Purchased: June 2007
4. How Many Hours on Set: 8150
5. How Many Bulb Changes & Brand: 1; Phlips
6. How Many OB Replacements: 1 (made worse)
7. Date Ext Wtty Expires if applicable: June 2010
8. Location and Environment: USA, WI 1 story home; AC 74/75, heat 64-72, on a ups.
post #24 of 34
1. Model #: KDS-60A2000 (65")
2. Build Date: Oct 2006
3. Date Purchased: Dec 2007
4. How Many Hours on Set: 6100
5. How Many Bulb Changes & Brand: 1; Philips
6. How Many OB Replacements: 1 (warranty: fixed, then made worse)
7. Date Ext Wtty Expires: Aug 2010 (class-action lawsuit)
8. Location and Environment: USA, AC 74, Heat 68-72
On a OneAC brick-wall power conditioner.
post #25 of 34
1. Model #: KDS-60A3000 (60")
2. Build Date: Sept 2007
3. Date Purchased: 10/26/07
4. How Many Hours on Set: 4725
5. How Many Bulb Changes & Brand: None
7. Date Ext Wtty Expires: July 2011 (class-action lawsuit)
8. Location and Environment: USA, AC 71, Heat 69-71
On a UPS and 7 inches from wall and on table top and NOT in a cabinet so it is free to air.
post #26 of 34
Originally Posted by jfcarbel View Post
1. Model #: KDS-60A3000 (65")
Where are you getting 65" from?
These are all 50" and 60" TVs. The measurement is in the model name...
  • KDS-50A2000
  • KDS-60A2000
  • KDS-60A3000
50" and 60" are the measurements of the screen. The A3000 and A2000 are the series.
Don't exaggerate.
I own the KDS-60A3000 myself and I'm listed further up on this page.
post #27 of 34
1. Model#-KDS-R50XBR1
2. Build Date-Oct. 2005
3. Purchased-Nov. 2005
4. Hours-?
5. Bulb Changes-0
6. OB replacements-0
7. Extended Warranty expired-Nov. 2009
8. Location-USA-Chicago suburbs, Media room in basement(humidty controled), heat 71F- AC 72F
Going throught the process of getting the replacement TV. Opted for the 55EX710 for $425+ tax. Getting all the information mailed to them in 1 week is a pain. Three different sale reps told me 3 different ways of taking the picture. Got all the stuff ready, then I got the e-mail on how to do it. But I already did it with the ref# on top instead of on the bottom of the tv. I hope they don't complain. I think Sony needs to train their employee's better.
post #28 of 34
Originally Posted by loudog2 View Post
4. Hours-?
See here for how to determine sets hours
post #29 of 34
Thanks!! I put the ? mark there because I can't get to the basement. Just had major knee surgery. The other information was already by the computer for the sony appeal.
post #30 of 34
Well my TV died out again. This time it is once again the lamp. This will be my 3rd lamp replacement since 2006. Thank god it is not the OB again. I don't understand, the TV is watched maybe 3 hours a day and some time less. Overall this 50" SXRD has cost me over $3,500.00 since I bought it with all of the repairs over the years. This TV is just a non-stop money pit in the long run. I am poor right now though so I am stuck with it. Any advice on where to get a cheap lamp for it?
  Back to Forum: Rear Projection Units
