AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Nintendo › Nyko Nunchuk compatibility
post #1 of 4
I noticed a pretty good deal - Nyko sells a classic controller and nunchuk for $20 in one box. I really want the nunchuk so I can play Wii Sports Resort with a friend - is it compatible with the Motion Plus?
post #2 of 4
If it's the wired Kama nunchuk, then yes, I believe so. IF the wireless Kama, then from what I have read - no.
post #3 of 4
I knew I forgot to mention something! Yes it is the wired version. Thank you.
post #4 of 4
you should be good to go, then.
  Back to Forum: Nintendo
