I have been running an old Pioneer receiver on my home theater setup for years. I just replaced my 50" Vizio plasma with a Samsung 58" plasma. My 15A AFCI breaker now pops whenever there is just about any current pulled by the receiver.
My question first Q is this: when I add up all of the loads, I show a a max SS current draw of about 8A, which assumes 500W for the TV and all channels of the receiver running at max rated RMS power @ 100V - all to create pretty liberal assumptions. Is it possible that the peak current draw is that much higher than RMS? I am not listening very loud, and people who have measured the power consumption of the TV on this forum find 300W-400W.
Other Q's:
I am not intimately familiar with how a AFCI breaker works. Is it possible that the TV or receiver may be creating an issue that could be fixed by swapping out for a regular breaker?
Could there be something wrong with the new TV's power supply?
Any ideas are welcome. The wiring is 14AWG, so I cannot go to a 20A breaker. The theater room is a small bedroom upstairs, so rewiring the branch circuit is not easy. If there isnt anything that can be done setup-wise, the only other option would be to use an outlet in the neighboring room on another branch circuit by swapping the outlet to the other side of the wall. I also pulled the TV off of the surge protector (still on same circuit) to make sure that the surge protector wasnt part of the problem w/ max load.
Other Q's:
