Originally Posted by Tulli
Samuri, IT WORKS!!!
Just replaced one byte in my DENON 988 EDID to enable 192khz support for TrueHD and that DID IT!
Thanks a bunch to rasmusb and to you for pinpointing the EXACT problem.
So, ladies and gents, mystery solved: ATI is INNOCENT!, or too picky?, for taking too literally (is that a bug?) a FAULTY AVR EDID value.
Now, what about other failing AVRs? Took a look at the failing ONKYO TX-SR875 EDID, and sure enough TrueHD/192Khz is marked as not supported there.
Can't find a couple of SONY AVR EDIDs that I had but this is the issue. OTH Checked one Yamaha and Pioneer AVRs EDID and TrueHD/192khz is marked supported in both.
Samuri, IT WORKS!!!
Great, now that we know the exact issue, I can probably do the fixes programmatically. I would just need to parse the EDID and check the audio block. Tulli won't have to spend his free time making mods.
I'm not sure when I could get it done though. Leaving for vacation on Sunday and I'm trying to wrap up a bunch of stuff.
