AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 99
post #2941 of 3574
Originally Posted by Sanborn View Post
Sorry, my original post accidentally says I've never gotten HDMI to work.
What I meant to say is, I've never had HDMI AUDIO work on the HTPC.
My AT&T cable box, X360, Roku Player, and PS3 at one time have all worked flawlessly on this receiver and that includes HDMI audio. It's only this AMD HTPC that has issues.
Which formats are listed on the HDMI audio properties panel? What number of channels? Is the Onkyo HDMI set to not passthrough TV audio? Otherwise the audio descriptor will be passed as 2 channels, LPCM (stereo only).
post #2942 of 3574
Originally Posted by Tulli View Post
Here you go ...
Thanks to all of you and particullary Tulli;
This file works for me : denon avr1910, optoma hd300x, amd radeon hd6850 + hdmi splitter, without any other "trick" during playback. (channel change or switch off/on AVR like in the video), HD audio and 3D work both directly.
I tried all configs with my radeon outputs (HDMI+displayport), but this seems the only solution for me.
Thanks again !!
post #2943 of 3574
Hi guys,
I have Denon AVR-2112CI and nVidia GeForce 210 card with which I'm having EDID issues. Whenever I turn AVR and TV off.. I can't get signal back on the TV. I previously used this TV with different PC without the AVR and it worked perfectly fine so I'm sure the problem is in the receiver and PC handshaking. I captured EDID with MonInfo and updated the driver, but that didn't really help much.
Is there anything else I can do before ordering Gefen HDMI Detective and try solving the problem that way? I really do not want to spend $90 right now
Thanks in advance
post #2944 of 3574
This is a FANTASTIC post that will help a LOT OF PEOPLE!
Way to go Tulli!
People will mess around with various stuff for DAYS not figuring that out!
post #2945 of 3574
I have a similar problem with a Optoma HD20 projector, Yamaha 667 AV amp and an AMD 6650 graphics card over HDMI. I am not able to get the HTPC to display at all - but do get normal sound through the AV amp. Turning the projector on and off does make windows sounds like it knows something is being unplugged.
Will a custom EDID help me with this? I have just stumbled upon this thread so reading through how to capture the information required.
Would any of the existing configs help?
cheers
post #2946 of 3574
cheers
Yes, try any of the available ones for the HD20, regardless of the paired AVR.
post #2947 of 3574
Thank You. Can I update the settings connecting to a monitor that works? My thinking is that I connect via HDMI to my monitor -> make the changes -> reboot pc and connect to the av amp/projector?
post #2948 of 3574
No, the projector must be connected so that its monitor driver be overriden. If you need the monitor then a dual monitor setup will be required, and apply the EDID override to the GenericPnP monitor driver associated to the projector.
post #2949 of 3574
Hmm.. that might be tricky as there is only 1 hdmi port, and the VGA port is not available if a graphics card is installed. Any suggestions on how to implement a dual monitor setup, or trick windows into letting the display through, even at a low resolution?
post #2950 of 3574
So this EDID override is for devices with screwy EDID? I remember havening to do that stuff YEARS ago. The last almost five years it's been a non issue for any gear I use. That includes AVRs/Pres and TVs using the HDMI bus.
People still need to do this !?!
huh
post #2951 of 3574
huh
It happens mostly with projectors (the Optoma is a case in point), with the AVR not repeating the EDID data properly.
Parsing problems are rarer now, but AMD has still a bug with bitstreaming and 5.1 AVRs (as explained in 1st. post).
Then there's the "hack" of TV's EDIDs to enable multichannel passthrough.
They're good for enabling 3D over an HDMI1.3 AVR (if you don't mind losing HD audio).
And finally, EDID overrides help sometimes with handshaking.
I think that's most of it ...
post #2952 of 3574
Originally Posted by ladik1983 View Post
Hi,
I own ONKYO Htx-22hdx + Onkyo SKS-22X linked via HDMi into ATI HD5670. During playback bluray with DTS-HD MA audio on PowerDVD 10 or 11 reciever shows only DTS 5.1
in audio settings of PowerDVD 11 I choose non-decoded high-definition audio to external deviced but when movie playing it switch to DD/DTS audio and that is what ONKYO show on the display, and there is no way how to switch to non-decoded high-definition audio.
my HD audio device and Catalyst are latest, everything works fine but not non-decoded HD audio
please hlep me, i am desperate
Hey ladik, I also have the ONKYO Htx-22hdx and ATI card, I too had no luck with DTS HD MA, I use TMT5. Well I just got back in to HTPC after giving up about 4 years ago as everything was just too much hassle to get right.
Well I'm glad to say things are a somewhat better these days now that I use mainly XBMC. I'd sort of given up on HD audio until a patch was released this week for XBMC for windows that allows HD audio only to find I still got no HD audio from my ONKYO Htx-22hdx, long story short I was involved a little in the original EDID thread here years ago so I thought I'd look for a solution here.
Anyways my TV is a Samsung so I installed an Onkyo/Samsung monitor.inf from the the first post of this thread and voilla I now have DTS HD MA from both TMT5 and XBMC.
Not tried True HD yet as I can't find any files with it.
Good luck
post #2953 of 3574
Hi tulli
I try to bitstream from AMD HD6990-> onkyo HT-5405 but have no luck.
Here is my .inf please help.
thank you
HT-R548.zip 2.474609375k . file
post #2954 of 3574
Originally Posted by icemancmx View Post
Hi tulli
thank you
LG-SL80 - HT-R548.zip 1.265625k . file
post #2955 of 3574
many many thx.it's WORK ^___^
post #2956 of 3574
Tulli,
If my HTPC reboots or sleeps with the display off, it will not sync with the projector when it wakes up or I turn the monitor on.... I HAVE TO REBOOT WITH EVERYTHING on to get a signal.
I am desperate for your assistance. I have created an INF for my Rotel RSP-1069 and created an INF for my Mitsubishi HC-500 projector. I have tried to use both to help my VIDEO sync issues but its not working.
Please help me create the correct INF??
I have attached the 2 INFs to this post.
THANK YOU!!!
Recv-RSP-1069 - Proj-HC-5000.zip 2.3720703125k . file
post #2957 of 3574
Originally Posted by mkedda View Post
Tulli,
THANK YOU!!!
I need to know first if problem is with WMC, for which only solution is a Gefen Detective device.
post #2958 of 3574
Originally Posted by vladd View Post
Special Note: This will capture the EDID of your display as the ATI driver sees it. That means that if you do not have an override in place, your realtime EDID will be captured. If you do have an override in place, the override will be captured. I debated fixing this but Tulli suggested (and I agree) that it would be good to leave it as is so you can see exactly what your video card sees.
If you need help with an override , you should only need to zip and post your ".txt" or ".bin" EDID files but including the console output would not hurt.
Hello Tulli and Vladd,
I have Onkyo HT-R390 a LCD iiyama ProLite X2377HDS. The output from the PC via the HD5850. Unfotrunately, the DTS-HD and Dolby TrueHD do not work. Could you modify the EDID, please? I send the ZIP file. Thank you
Onkyo HT-R390+LCD iiayma ProLiteX2377HDS.zip 6.84375k . file
post #2959 of 3574
The audio descriptor of the Onkyo AVR is fine. Are HD audio formats listed on the HDMI audio driver properties panel? What player are you using for playback? What OS?
post #2960 of 3574
Tulli, Thanks for the reply. This is for use with windows 7 OR home server 2011 and XBMC.
What if I chose Ubuntu?
post #2961 of 3574
Here's your mod. I forgot to ask about the graphic adapter but Intel IGPs don't accept EDID overrides.
As for Ubuntu I don't know, but wouldn't be surprised that it works with it ...
post #2962 of 3574
The HD formats are HDMI on the controller panel. I use MPC-HC + ffdshow rev4305 v1.6.0.4014. OS is Windows 7 Ultimate 64bit. By using this link LG PK-350 - ONKYO HT-R380, the sound is OK.
post #2963 of 3574
If all formats are listed (included DTS HD and TrueHD) there's no problem with EDID detection and it's a setup problem with MPC-HC. Right click on MPC-HC windows during playback and select "Filters". Check that ffdshow is there. If so right-click on ffdhow audio tray icon: it should show something like "HDMI passthrough". If ffdshow is not listed add to options-> external filters and set it to "prefer".
post #2964 of 3574
MPC-HC and I have set audio ffdhow well. The "HDMI passthrough" I checked everything (Dolby Digital, DD Plus, Dolby TrueHD, DTS and DTS-HD). The MPC-HC I set an external filter. The problem is that the output is SPDIF (1403) instead of HDMI bitstrem (1402).
When using this setting "http://www.mediafire.com/?qfmppcyr4f5a3ax", the sound is OK
post #2965 of 3574
Hello Tulli, (sorry for my English, I am French). I've got problems with EDID I think, I've tried one custom inf file, it passes DTS-MA but not True-HD. Could you please make a custom inf file from the ones attached ?
I use a Sony kdl40ex500 TV with a onkyo ht-r380. Thank you so much !
Sony kdl40ex500 - onkyo htr380.zip 2.412109375k . file
post #2966 of 3574
... no idea. Try the attached EDID override.
iiyama ProLite X2377HDS - ONKYO HT-R390.zip 1.3076171875k . file
post #2967 of 3574
Sony kdl40ex500 - ONKYO HT-R380.zip 1.263671875k . file
post #2968 of 3574
Thank you very much, your mode works perfectly. Thanks
post #2969 of 3574
Tulli,
Thanks for uploading the files.
I could be mistaken but it seems like you re-uploaded why I had originally provided, two seperate infs that were identical to what I provided.
Am I missing something?
post #2970 of 3574
Tulli,
Oh, sorry ... here's the right one.
HC-5000 - RSP-1069.zip 1.2548828125k . file
