AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 100
post #2971 of 3565
Hello, Tulli,
if you can help. I need an EDID Override
TV = Samsung UE46D8090 (3D)
AVR = Denon 1912
GraphicCard in the Medioacomputer = AMD Radeon 6450, 1024
Sorry for my bad English
Thanks to for your help and greetings from Germany
DeSam
post #2972 of 3565
Originally Posted by DeSam View Post
Hello, Tulli,
AVR = Denon 1912
DeSam
Post the Samsung real-time EDID (see 1st. post). Are you sure that you need an EDID override? What's the issue?
post #2973 of 3565
Hallo,
the Real time is 0 x 0031
My problem:
The Caralyst centre does not recognise(see) the monitor. Announcement(Message) is "Denon AVR1912 ". The Software TMT5 no TrueHD is economical.
The GraficCard does not recognise(see) the possibilities(opportunities) of the Samsung monitor.
Do you need(require) dspinfo.bin?
DeSam
post #2974 of 3565
The "Denon AVR1912" ID for the monitor is OK. For audio check if TrueHD and DTSHD are listed on the "Supported Formats" window of the AMD HDMI audio properties. If so bitstreaming of HD audio should work.
For an EDID override I need the full, 256-bytes native EDID of the Samsung TV, in whatever format.
post #2975 of 3565
I hope which is so right it. Please rename .txt in .inf
DeSam
Samsung UE46D8090.txt 3.0078125k . file
post #2976 of 3565
DeSam
Samsung UE46D8090 - DENON AVR1912.zip 1.3017578125k . file
post #2977 of 3565
Sorry, does not function(work).
TMT5 AV-Centre setting on DTS now possibly.
AVR = STEREO, signal type unknown
By BluRay 3D starting Blackscreen
Greeting DeSam
post #2978 of 3565
Greeting DeSam
It's a TMT setup issue (check the TMT5 thread here and on the Arcsoft forum for a possible solution). In any case it is not an EDID problem.
post #2979 of 3565
OK, many thanks for your help. I will check TMT5
Greeting DeSam
post #2980 of 3565
i have nvidia and denon 2310 edid overwrite might be my solution?
i am running xbmc under linux
regards
post #2981 of 3565
Hello Tulli,
after struggeling a long time with our HTPC/AVR/TV combination we finally nailed
our old Philips 42PF5421 as the root of our problem not getting HD audio to work.
If the TV is disconnected from our Onkyo TX-NR809 all HD audio formats play just fine. But with the HDMI cable connected we get an error in XBMC/TMT5 etc.
We would like to ask if you could take a look at our
- Monitor Asset Manager Report for Philips 42PF5421
- Monitor Asset Manager Report for Onkyo TX-NR809
Maybe it is possible for you to create a custom EDID Override inf-file for us since the general Samsung LN-S4095D - ONKYO TX-NR906 doesn´t work.
It would be greatly appreciated.
post #2982 of 3565
Originally Posted by solidsatras View Post
Hello Tulli,
Is the Onkyo set up to not passthrough the TV audio? Check the listed audio formats on the "Supported Formats" window for the HDMI audio device. If you only see 2 channel PCM when connected to the ONKYO->TV that's the issue.
post #2983 of 3565
Hi Tulli!
I have a Nvidia GeForce GT 555M connect with HDMI cable to Samsung UN60D6000SFXZC and this one connect with optic cable to Pionner Elite VSX-07TX and my problem is I cannot have 5.1 just 2.0 and I read on other forum the problem is the EDID because my other laptop work well with the same setup...
Can you help me with a custom EDID?
Sorry for my poor english...
Thank's!
post #2984 of 3565
Originally Posted by VIPguard View Post
Hi Tulli!
Thank's!
Try the attached EDID override.
Samsung UN40D6050+6LPCM+5.1AC3+5.1DTS.zip 1.2783203125k . file
post #2985 of 3565
You're the best!
Thank's a lot!!!
post #2986 of 3565
Originally Posted by Tulli View Post
It happens mostly with projectors (the Optoma is a case in point), with the AVR not repeating the EDID data properly.
Parsing problems are rarer now, but AMD has still a bug with bitstreaming and 5.1 AVRs (as explained in 1st. post).
Then there's the "hack" of TV's EDIDs to enable multichannel passthrough.
They're good for enabling 3D over an HDMI1.3 AVR (if you don't mind losing HD audio).
And finally, EDID overrides help sometimes with handshaking.
I think that's most of it ...
Thanks for taking the time to explain that to me. I've been sorta outta the loop so to speak with HTPCs etc for at least three years plus. So I guess it's a great way to defeat 2 chan EDID read thus causing only 2 chan xmit into FPD? I guess this would matter if you're then passing audio back outta the TV via SP/DIF and want AC3 etc bitstream...
Why not just use TOS/link or SP/DIF outta the motherboard into the AVR then? I guess if you had it that way and also a modern "internet" TV you would have to swap audio inputs on the AVR in order to hear sound from PC or Internet TV/widget abilities or even ATSC. If looped into TV via HDMI and backout via TOS/link into AVR I guess you then don't have to change audio inputs on AVR for TVs internet functions or PC functions. Also I guess the TV then can act as an HDMI audio switch into the older SP/DIF only AVR...
Interesting...
and a VERY CLEVER work around!
post #2987 of 3565
Yes, definitely.
Here is a picture of this.
192kHz is missing and that´s needed for bitstreaming I think.
As soon as we unplug the TV´s HDMI-cable from the Onkyo AVR,
DTS-HD and Dolby TrueHD work just fine, so we thought it has to be something to do with the TV-> AVR HDMI-Handshake.
What else could be the problem?
post #2988 of 3565
Yes, definitely.
What's the resolution? It has to be standard HDTV for bitstreaming (1080i/p or 720p). If resolution is the problem then best solution is a split connection to the TV and the AVR.
post #2989 of 3565
We use 1280 x 720p so the resolution shouldn´t be the problem I think:
Leaflet for Philips widescreen flat TV 42PF5421 107cm (42") LCD HD Ready
Our HTPC only has one onboard HDMI output. Could something like this:
1X2 PRO Series Powered HDMI® Splitter with 3D support (Rev. 2.0)
help settle our problem? Do you think it´s worth a try?
post #2990 of 3565
I'm stuck
My configuration is:
Sony Vaio CA (HD6470M) -> (hdmi) -> Samsung LE40B551 -> optical -> Logitech Z-5500
and I get only stereo sound
But if I connect PS3 instead of Vaio I get 5.1 sound.
Could You help me?
post #2991 of 3565
No need of the splitter with that resolution. Could it be an HDCP issue? Do you have or have you tried AnyDVDHD? What's your graphic adapter? (if it is an Intel IGP an EDID override won'y work).
post #2992 of 3565
Originally Posted by dawitcichy View Post
I'm stuck
Could You help me?
Samsung LE32C550+6LPCM+AC3+DTS.zip 1.26953125k . file
post #2993 of 3565
Our HTPC setup:
A6-3670K with Radeon HD 6530D
ASRock A75M-ITX FM1
AMD Catalyst 12.1 installed (as well as original drivers)
We use the Dolby TrueHD and DTS MA files from demo-world as well as our own bluray rips(Makemkv) for testing.
So HDCP shouldn´t be an issue, or am I mistaken here?
I see there is a 14 day trial version of AnyDVDHD. We will test playback with one of our blurays to see if it makes any difference.
We´re really greatful for your help. We thought one of your custom EDID files for our AVR/TV combination would solve our problem, but it seems it´s a bit more complicated.
post #2994 of 3565
Our HTPC setup:
ASRock A75M-ITX FM1
Well, I rechecked the TV EDID and native resolution is 1280x768, i.e. not HDTV standard, as can be seen in the screen-capture:
Only solution is using split connections.
post #2995 of 3565
Dear all,
I have a Mac Mini (running Windows 7) connected to this Sony BDV-E985 HTIB via HDMI, and the Sony BDV-E985 is connected to the NX720 TV using HDMI as well.
I have sound, but when I do "configure speakers" on the Radeon HDMI Audio driver, it only detects two channels. The display properties detects as "SONY AVAMP". The sound is good, but I want it to detect all the speakers (5.1 channels).
Can this be fixed with an EDID override? I know the multichannel is possible because I did it with another Mac Mini running Win 7, but a Denon AVR.
Are any of the pre-made overrides suitable or will I need a custom one?
Thanks! This thread is dense and I'm still trying to understand everything.
post #2996 of 3565
Originally Posted by adept1 View Post
Dear all,
2 channels PCM detection is correct for S/PDIF (see first post updates on the subject). You will only require an EDID override if DD and DTS are not listed as supported formats for the HDMI sound device.
post #2997 of 3565
Tulli,
Actually I applied the Sony AVAMP override I found here and it lets me see all the speakers now! Did a speaker test and it's perfect. However, when I reboot, it reverts to generic PnP monitor. How to get around that?
post #2998 of 3565
Actually never mind. Although it reverted to Generic PnP Monitor, my speaker settings have been retained. So everything is still working thanks!
-adept1
post #2999 of 3565
That´s right. Sorry to have mislead you on this, I was so sure it stated 1280x720 but I was obviously wrong.
Again thank you very much for your help. We finally know what to do.
post #3000 of 3565
Hi, I wondered if you could help me out. I upgraded my htpc card to a radeon 6570. For some reason it's stopped bitstreaming audio after initially doing so. When I enter the TMT5 settings in Media Center the sound options are greyed out displayed in the picture below. Any solutions? Arcsoft tech support is clueless. Thanks for any input.
[IMG][/IMG]
