AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 103
post #3061 of 3565
Originally Posted by Tulli View Post
Mod attached. I've set 1280x720 instead of 1280x800 as the preferred resolution, as the latter is not HDTV standard (which will disable HD-audio bitstreaming through your AVR).
If you wish to use 1280x800 set 2 separate connections to the proj. and AVR respectively, or use the mod attached with the base block of the PLED-W500 that you posted, and manually select 1280x720 when watching movies.
thanks i will tryit at home..
question, 3D 120hz mode only works on 1024x768 at this resolution will be HD audio?
Thanks.. tulli!
post #3062 of 3565
Thanks.. tulli!
No, it has to be HDTV standard (1080p/i or 720p). Only solution there is using separate connections.
post #3063 of 3565
OK.
it will Ati5450 HDMI to ONKYO
and Ati 5450 VGA to projector ??
post #3064 of 3565
OK.
Or ATI DVI/HDMI to proj, for which you'll need a propietary ATI DVI/HDMI adapter.
post #3065 of 3565
The EDID of the Yamaha is "truncated" as it only has the base block, so maybe a cleanup of registry leftovers is in place. See 1st. post (section 4) for instructions. After cleanup reboot, then try again.
Reinstalled windows seemed to do the trick (was about time anyways).
Thanks for the help .
post #3066 of 3565
I'll have to correct myself, no it didn't.
New file attached, see if you can sort it out?
And thanks a million for doing so .
edit: Its not the realtime edid on the yamaha tough, but the onlything i wish is that the graphic card always sent out the hdsounds.
Sometimes i get some weird ass bugg saying there is no support for compressed formats.
Panasonic50G20E+Yamaha667.zip 2.23046875k . file
post #3067 of 3565
Well, the Yamaha EDID has only the base block again, and the Panasonic EDID has the Yamaha audio block so just use it to override the EDID.
post #3068 of 3565
Tulli, works for me with dvi to hdmi-- to projector and Hdmi to receiver. Its ok. Thanks
But this way i loose my other imputs hdmi to reciecer ( ej xbox)
Is any other VGA that i can buy? Has no truble doing 1 hdmi only and HDSOUND / 120hz 4:3?
Ati 6xxx? Or nvidia??
Thanks again
post #3069 of 3565
Thanks again
Get an HDMI switcher (with remote of course).
post #3070 of 3565
thats the only solution?
not any new card? i wanna use receiver switch
thankssss again
post #3071 of 3565
thankssss again
For Nvidia see here. For ATI it's of course Eyefinity, for which I would recommend a 6770 minimum (or 5750). Maybe a lesser card would do but I'm not sure.
post #3072 of 3565
i got a HD33 and HT-R390 receiver. both are 3d ready. i plug in 1.4 cable. but the device manager didnot see the receiver on monitor section. is there way it can see it. cause right now everytime i want to watch 3d bluray. i have to reboot it. idont know why that happens.
please help me.
thanks
post #3073 of 3565
please help me.
thanks
Please provide OS and graphic adapter & video player information. Do you get HD audio bitstreaming even when not being able to play 3D? Do you see all audio formats on the "Supported Formats" for the HDMI audio driver?
If the receiver ID is not shown as a monitor maybe a cleanup of registry leftovers can help, as explained in sec. 4 on 1st. post.
post #3074 of 3565
OS - windows 7 premieum
graphic adapter - ati 6550 on board video card
player - Powerdvd 11
when i go to sound - properties , i see channel 6 or 7 and all does bitsreaming format (dts-hd and etc...)
when i go to monitor properties, i see only PnP monitor...
post #3075 of 3565
Well, if the problem is not PDVD11, and if there is really an issue with how the AVR is repeating the EDID, an EDID override could help, but I can't be sure.
An easy way to test if PDVD is the problem is connecting the HTPC directly to the TV and see if 3D works regardless of switching or powering on/off.
If it works:
1) You could just use separate connections and be done wiith it.
2) Try an EDID override for which I'd need both real-time EDIDs.
If it doesn't work the problem is definitely with PDVD11.
post #3076 of 3565
Hi guys,
I am little new to this so please bear with me. I have a htpc with an nvidia card connected to a pioneer 940 hd via marantz 5006
htpc (nvidia + linux) [hdmi] -> marantz 5006 [hdmi] -> Pioneer 940 HD
I see horrible flickering (the text is pretty unreadable) when using the above config. But If I connect the htpc directly to the pioneer, everything is crystal clear.
So do I need an EDID override when connecting my htpc to my receiver?
The other issue I have is that when I have my htpc connected to my receiver, I get no sound over hdmi. How would I go about solving that?
Sorry if these are basic questions.
post #3077 of 3565
Originally Posted by Variable View Post
Hi guys,
The EDID override capability is a Windows Vista/7 feature. If you can also override the EDID in Linux it won't hurt to try it. In Windows it only overrides the defalult monitor driver, so it's very easy to install/uninstall without affecting other functionalities of the the system.
post #3078 of 3565
Sorry Tulli for asking this stupid question.
Any override request for any HDMI 1.4 AVR with an AMD/ATI 6*** series card or Liano?
post #3079 of 3565
No problem, Rica. I guess, yes. Are you looking for one, specifically?
post #3080 of 3565
No, my friend.
I'm just investigating. I don't have any HDMI 1.4 AVR and I'm preparing a post for 3D HTPC thread. This is why I asked.
Do you think I can say "there is no EDID issues with 6*** series cards with HDMI 1.4 AVRs."?
post #3081 of 3565
Thanks for the reply.
I am close to getting audio working, but the screen looks blurry. That is the fonts are pretty much unreadable. Any thoughts/suggestions?
post #3082 of 3565
post #3083 of 3565
No, my friend.
Problems should be exceptional, like a projector and an AVR that can't repeat the proj. EDID correctly. But in any case, the easiest solution would be separate connections. In sum, an EDID override shouldn't be required in almost all cases.
post #3084 of 3565
Thanks Tulli.
But seperate connections (for frame -packed 3D together with HD audio) are not suitable for 6*** series cards or Liano. We always need a second cheaper card (like 5450) for HD audio. (while 7*** series are OK.)
post #3085 of 3565
here is my file for hd33 and ht-r390 inf file
thanks
hd33.txt 3.005859375k . file
ht-r390.txt 3.013671875k . file
post #3086 of 3565
thanks
Optoma HD33 - ONKYO HT-R390.zip 1.2822265625k . file
post #3087 of 3565
thanks
post #3088 of 3565
I'm using Windows8 preview and I'm having issues with using the EDID .inf file. When I try to swap drivers I get the "Cannot install unsigned drivers" error.
Is there a way to get a signed .inf file?
I'm using LG 42LE4500 and Onkyo 390 AV reciever. This probably works with the generic EDID files (using the LG 55LD520 - ONKYO TX-SR308 file) or do I need a custom EDID file?
post #3089 of 3565
Hey all...
Haven't read through the entire thread yet, but do you think this procedure would resolve the following issue?
New HTPC connected to Denon 1911 (and working perfectly fine on BD input).
However, when attention is on Sat/Cbl input (Bell 9242) connected via Component/Optical audio....and HTPC powers on or wakes up, this Sat/Cbl input starts dropping audio/video.
Thinking this could be a handshake issue between the Denon and HTPC that is causing the Denon to do this. (or the HDMI from the Denon to the TV to do this)
Everything goes through AVR and then to TV via one HDMI cable.
HDMI Control and Video Upconvert is off on AVR and I've also tried different HDMI cables and Inputs with no luck.
PC is an Asrock A75M-ITX board with an A6-3500 APU
. Using Xbmc on win8 cp.
Its not a huge issue, as I can turn off PC and all is fine. Would be nice to fix though.
Any advice is appreciated.
post #3090 of 3565
Hi Tulli !
Here is my real-time EDIDs for my LG 55LW5700. I have been using this INF "LG 60PK550LG+5.1AC3&DTS" to get 5.1 AC3 & DTS to work on my system. My problem is that I have to have to keep switching between inf files to get either the 3D capabilities of my TV or surround sound to work. I would like to have both in one inf file. Also is it a big deal that moninfo detects my screen size @ 7.2 inches instead 54.5?
LG55LW5700.zip 2.453125k . file
