AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 105
post #3121 of 3565
Oh very quick... I try to apply... Thank you
post #3122 of 3565
Quick question on wheter an EDID override will solve my issue.
I have my HTPC only connected to my Samsung LN52A750. More often than not, when I come out of standby, I have video but no audio.
Can I use the Samsung LN52A750 - DENON 2310 EDID override to solve my missing audio issue?
TIA,
AL
post #3123 of 3565
TIA,
AL
If the problem is with WMC it won't work at all. Otherwise apply it to the present GenericPnP monitor driver when you get no audio. Reboot and test it. Hopefully it will work.
Also, it won't work with Intel IGPs.
post #3124 of 3565
I have an ATI 5670 video card and while I am using WMC, I lose sound in Windows collectively. It says the device is unavailable (something too that effect).
I also tried searching for HDMIYo but see that the website is no longer up. Would this solve the issue and does anyone know ehere to download it?
TIA,
AL
post #3125 of 3565
TIA,
AL
If you're resuming from sleep from WMC the only solution is (an expensive) Gefen HDMI detective. Otherwise you can try the EDID override.
post #3126 of 3565
Try the attached EDID override which should work for your Samsung TV. It will give you at least DD capability (not sure about DTS).
Thank you for your effort.
AMD HDMI output now says it supports DD (when connected to the TV ofcourse), but I still don't get any DD. The TV is set for DD s/pdif passthrough, I am using MPC-HC with ffdshow (not codecpack) set for DD s/pdif passthrough.
Any suggestions?
post #3127 of 3565
Any suggestions?
Is the AC3 option unticked or deselected in the Codecs tab of ffdshow? Otherwise it is still decoding AC3. Deselect also the mixer option.
post #3128 of 3565
Hello Tulli
I would like to thank you so much for what you've done.
Badly, it doesn't work, but it's not your fault, it's beacause of nvidia. At the same i've written to them to explain my problem. They answer my gtx 560 ti 448 can't bitstream dts-hd.Only dts, because it's made on base of gtx 570 which can't and not on base of gtx 560 which can.
So.... One more time thank you for your great job
post #3129 of 3565
A quick google shows that the 560 ti CAN bitstream DTS-HD MA and TrueHD. However, there are people who cannot and they figure it is handshake issues with the device.
post #3130 of 3565
Al418, maybe you can check this thread out: http://www.avsforum.com/avs-vb/showthread.php?t=1358005
post #3131 of 3565
Thank you. It's the manufacturer who says me its not possible, but in fact i hope you 've reason.
I've ridden the post I try to do a new clean installation.
post #3132 of 3565
New installation and patch with edid overrides, but it doesn't work. So just a question. I know to work well we need to have a 1080 native resolution. That's what i have on my vpl-hw20, but not on my monitor an old Benq. Do you think the resolution of my Benq could be a problem (even if when i use my projector my Benq is off) to have bitstrem dts-hd.
post #3133 of 3565
Yes, 1080i/p or 720p is required to bitstream HD audio. But do you have the Benq connected to the AVR?
But otherwise it could be a filters problem. Try the safest route: MPC-HC + LAV filters (forget ffdshow). Make sure that LAV splitter and LAV audio decoder are set to preferred in MPC-HC. Set LAV audio decoder to bistream all audio formats. If they are correctly engaged (right-click on "filters" on MPC-HC window during playback) it should work ...
post #3134 of 3565
Eh no my Benq is only connected to my computer. I've just try MPC-HC + LAV Filters set to preferred. I do right click during playback, and i see lav splitter and lav audio in my filters.When i set LAV audio to bitstream dts-hd, i have ..no sound...
post #3135 of 3565
Check that the correct HDMI audio device is set for MPC-HC (or that the HDMI audio device is set to default).
post #3136 of 3565
I've just check my audio device for mpc-hc is setted on my hdmi (txsr 608). So it's ok. If i don't set lav audio to bitstream dts-hd and only dts, i have sound in dts on avr. It's only if i check dts-hd, that i 've no sound.
post #3137 of 3565
Silly question, but is MPC-HC playing back on the projector screen (not on the Benq)? It really looks like some HD audio requirement is missing (e. g. HDTV resolution). For if you playback on the Benq you surely won't get HD audio.
post #3138 of 3565
Yes MPC is playing on projector screen. My Benq is only used to control my computer, and he is off when i use my projector. Yesterday i've tried to completely unplug my benq from my computer and reboot after in order to have only one monitor (my projector). But it has changed nothing. I've really no idea now...
post #3139 of 3565
What's the HDCP Status on the Nvidia Control Panel? And can you confirm that TrueHD and DTS HD are not listed on the Supported Formats Windows for the HDMI audio device without the override? Could it be a cable issue?
post #3140 of 3565
Would someone mind checking my thread out to see if a custom EDID is what I need?
http://www.avsforum.com/avs-vb/showthread.php?t=1409264
My receiver is upscaling (I think) 1360x768 to 1080p, which I don't want and the picture looks terrible.
post #3141 of 3565
No, no custom EDID. If you also add bitstreaming of HD audio only solution is separate connections. You'll also need a propietary AMD DVI-HDMI adapter.
But AFAIK with a 5750 only one audio stream will be active (for the primary display) so ... If you set the AVR as primary you lose the desktop on the TV; (no cloning as resolutions are different).
An Nvidia card (which can handle multiple audio streams) + separate connections (+ a standard DVI-HDMI adapter or cable) is the only real solution that I see in your case.
post #3142 of 3565
Yes HDCP is ok in the control panel, all my product are approved for. I confirm dts-hd and dolby true hd are not supported in the control panel without the override.With the override my computer see my avr, and my avr send image on my projector, but i've no sound. It looks like my avr is off. For the cable it was one of the first thing i've tested. I've tried 4 cable,and for the last one is hdmi1.4 so it couldn't be this...
post #3143 of 3565
Just found this thread and before I go through the previous 104 pages, I just built a HTPC with a 3770K and ASUS Z77 MB supporting Intel's new HD 4000 GPU.
MB HDMI direct to Panny PJ works fine. When I try to go through my Denon 2311, the PC knows that I'm connected to the Denon and does not see the PJ.
Are you saying that EDID overrides won't work with an Intel HD 4000? It does show a Generic PnP monitor when connected directly to the PJ. The Denon EDID looks reasonable when going through the AVR.
If this has no chance would the Gefen HDMI Detective Plus have a chance? I really want the video to pass through the Denon as my Blu-ray play does.
Am I spinning my wheels to make this work?
post #3144 of 3565
That's a good question, but up to SB EDID overrides are not accepted. I can only assume that it's the same with IB but I haven't tested it yet.
But in your case try separate connections using a DVI-HDMI adapter/cable. Being a Z77 you could still add a discrete card to have a third display device (should work but I guess) if you need to (a discrete card would accept an EDID override of course, but defeating the purpose of a Z77).
As for the Gefen I'm not sure as the problem that you have seems to be a bad EDID replication by the DENON. Then the Gefen should be programmed with the video timings of the proj. plus audio block from the DENON. I'd really go for the separate connections route (or the discrete card + EDID override).
But of course we could also try an EDID ovrerride right away and see if HD4000 accept them...
post #3145 of 3565
Thanks Tulli. I think I'll figure out how to build an EDID override and see if Intel got their act together. If it doesn't work I'll go the ATI route so that I don't get into multiple input switching on the PJ and AVR.
post #3146 of 3565
Just capture the real time EDID (instructions on 1st post) and post it if you like. I'll help you with the mod.
post #3147 of 3565
Very kind of you. The real time INF files via Moninfo are attached. HDMI direct from PC to PJ works fine. HDMI to Denon input gets sound but its output doesn't pass the video through to the PJ. The Denon OSD setup menu shows up on the screen so I know the Denon is sending video, just not from the PC HDMI.
This will be an interesting test of the new Intel IB/Z77/HD4000 to see if overrides are now accepted.
Thank you.
Panny AE7000U - Denon AVR2311.zip 2.478515625k . file
post #3148 of 3565
Thank you.
Panasonic AE7000U - DENON AVR-2311CI.zip 1.2802734375k . file
post #3149 of 3565
Tulli,
Bottom line: Intel Ivy Bridge/HD4000 with the Z77 chip DOES now accept overrides.
I'm still testing since after successfully installing your INF file, powering down, hooking the PC HDMI to the Panasonic PJ through the Denon and powering up the PC with the PJ and AVR on, the monitor file reverted back to Generic. Hooking up my VGA monitor (to see what I'm doing) and reinstalling the EDID override driver on the correct monitor, the desktop suddenly appeared on the screen. No reboot.
HDMI audio seems to be fine. I'm currently playing a DTS 5.1 Blu-ray in the PC with TMT5 and it decodes properly on the Denon.
Seems like Intel got its act together. Thank you for the EDID override file. I'm just afraid to unhook the VGA monitor or reboot for fear drivers will revert.
post #3150 of 3565
I'm hoping I arrived at the correct place for help. I have a problem that's been plaguing me for months. My Gigabyte 790 chip based Motherboard throws "you have disabled a display that supports audio playback" as soon as I switch inputs on my Pioneer VSX1020 to , say, Tivo or Xbox. TV is a Vizio 55" plasma. I just installed a standalone ATI 5450 and wiped the drivers, did a driverclean then a full reinstall. This did not help.
This error is a mild annoyance as a reboot clears, and a reboot is fast on my SSD. However, if I want to experiment with using this machine as a PVR, I can't reboot to watch something if it's recording something else. Is this the right area for help?
