Originally Posted by
azzazzin
Thanks for the reply Tulli
Here's my (51D490 series) Samsung Plasma 3D 720p TV's native EDID in bin and inf formats as requested. Would be much obliged if you'd indicate how you fixed it
3D-TV.zip 2k .zip file
The Audio Block of the Sony AVR had only 2-LPCM, DD & DTS. Replaced it with a full audio block.
Samsung PS-51D490 + Full Audio.zip 1k .zip file
Note: just realized that native resolution is 1360x768! This is not a standard HDTV resolution so you might still run into issues by going through the AVR. If so using separate connections to the TV and AVR is one solution.
OTH resolution in the NVIDIA-UN-3DTV is 1080i. Do this: use the base block of the this .inf file., as before, but the extension block from my mod above. Maybe it'll work this way as the native VSDB block of the Samsung Plasma is untouched in the extension block (which AFAIK is crucial for 3D).
Edited by Tulli - 6/20/12 at 5:58pm
