Originally Posted by
DavidT99
Have you tried downgrading CCC to v11.4? I have found this to be a good starting point for driver issues, it just seems to always work. YMMV.
David
Hi David,
Thanks for helping...I just tried 11.4 and it doesn't work for me. sorry
Tulli
I'm not familiar with HK but you say that sound works in "regular mode" and "all formats supported". What is "bypass mode"? And does 3D work through the AVR?
Tulli,
In order for 3D to work, I have to set the HK to bypass mode. This sends the signal directly to the projector bypassing the HK.
There's a member here that said his worked only after having changed his VC to the 6XXX series.
I know the 7XXX series is supposed to be the same re 1.4a compliant.
Is there something to do with the HK EDID?
Again, If I DO NOT put the bypass mode...everything works EXCEPT 3D!
When in Bypass mode...no sound and no 3D.
I really want this to work and do not know what to do anymore...
