AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 111
post #3301 of 3563
Hi all,
I'm having trouble trying to connect from Radeon HD 5970 > Mini displayport/HDMI adapter > HDMI cable > LCD 1080p TV
I get the following in Catalyst Control Centre:
I've run GetEDID.exe and the OutputToFile.bat shows the following error.
Code:
Checking adapter 3: ATI Radeon HD 5900 Series
  Found 5 display devices on adapter 3.
    Checking display device 1 on adapter 3.
      Display device logical index is 2.
      ERROR: Could not retrieve the EDID!
PC is:
Win 7 64bit
Radeon HD 5970
Palsonic LCD TV 32" 1920x1080p
Any help or tips on how I can fix this problem?
post #3302 of 3563
Is there an override for Panasonic Plasma TC-P55GT50 + ONKYO HT-R390 I don't seem to see one in this thread for my specific display. I can provide the files when I get home if needed.
post #3303 of 3563
The Panasonic TX-P42GT20E - ONKYO TX-308 on 1st. post should work.
post #3304 of 3563
Originally Posted by sdjt View Post
Hi all,
I did not test an adapter when I created the program. It is possible that it is not passing an EDID at all with the adapter (as evidenced with the missing supported modes in your screenshot).
I have an adapter but I'm not sure when I will be able to test it.
post #3305 of 3563
Bonjourno! I was hoping that someone would have any experience with a samsung ht d5300 bluray/5.1 surround sound.. im looking to do a edid override for a 47inch lg 47lk450 to enable proper sound through my system via XBMC
post #3306 of 3563
Try this mod:
LG47LF711+5.1+AC3+DTS.zip 1k .zip file
post #3307 of 3563
wow thanks for the quick help my man! Big thanks ill try and let you know
post #3308 of 3563
ah sorry k now im confused ive got two edids showing up in moninfo one that says real time and one that says active.. your edid is the active one and my real time one is the old one.. is this supposed to be like this??
Edited by Jadon Veldman - 10/5/12 at 4:42pm
post #3309 of 3563
Yes, that's correct. Check that AC3 and DTS are listed as supported formats for the HDMI audio device.and make sure to reboot after installing the override.
post #3310 of 3563
rebooted but all i see is dts and dolby.. i might not have my hdmis in the right spots.. my manual doesnt tell me which one is used as input and which ones arc.. assuming i can even use arc with this tv :/confused.gif
post #3311 of 3563
ok so now have sound coming out of 5.1 via computer -> hdmi -> hdtv -> optical -> surround. But is it at all possible to get dts master or true hd? still no ac3 in the encoded formats and when i go to configure the speakers its just giving me stereo to choose from..
Edited by Jadon Veldman - 10/5/12 at 5:46pm
post #3312 of 3563
No, with S/PDIF bandwidth you can only get 2LPCM or compressed multichannel (e.g. AC3 or DTS). Is your connection HTPC - TV - ht d5300? Or rather HTPC - ht d5300 - TV?
post #3313 of 3563
hdtv - tv - ht d5300.. and that sucks. i will keep trying different connections with the hdmi cords till i get any sound.. in the mean time am i supposed to see "ac3" in supported formats under the hdmi audio device? becuase its not there... if i understand tho it will only show up if the computer reads the connection from the ht d5300 through the tv.. correct? thanks for helping me out with this.
post #3314 of 3563
my htpc has an hdmi out.. and my tv has 4 diffrent hdmi inputs so i was only assuming it could passthrough audio with the right combo.. then my ht d5300 has an hdmi out..( i know hdmi out doesnt make sense. but ive talked to another person with the same model (ht d5300) who has sound coming through 2 speakers all by hdmi connections... diifferent tv tho..)
post #3315 of 3563
Check the installation procedure on first post. If the EDID overrride is correctly applied AC3 and DTS would show up as supported formats.
post #3316 of 3563
Update:
Code:
I have the screen set up using a VGA connection and get the following info from the OutputToFile.bat
Code:
Checking adapter 2: ATI Radeon HD 5900 Series
  Found 5 display devices on adapter 2.
    Checking display device 1 on adapter 2.
      Display not mapped to this adapter... Skipping
    Checking display device 2 on adapter 2.
      Display not connected or not active... Skipping
    Checking display device 3 on adapter 2.
    Checking display device 4 on adapter 2.
    Checking display device 5 on adapter 2.
      Display device logical index is 1.
        Display Type:                   CRT
        Display Connection:             VGA
        Manufacturer Name:
        EDID Name:                      DDC Display
        EDID size:                      128 bytes
        Writing EDID text file:         .2.1.txt
        Writing EDID binary file:       .2.1.bin
Screen is: Palsonic LCD TV 32" 1920x1080p
I'm hoping that may help with working out an .inf file for the mini displayport digital setup.
post #3317 of 3563
Code:
        Display Type:                   CRT
        Manufacturer Name:
Any ideas on using the digital mini display port?
Would I be able to use the edid from the VGA connection to override the EDID on the mini displayport/hdmi connection?
Or will I see no difference in image sound/quality?
post #3318 of 3563
What is moninfo reporting as a the real-time EDID? If no real-time EDID is detected then there is definitely a connection problem that couldn't be fixed in anyway with an EDID override. If no connection can be established there's only the choice of trying another cable/adapter/connection of course.
post #3319 of 3563
Hi guys
I know it is ati5xxxx thread but I have issue with my Ati 6850 - Onkyo HT-R390 - Samsung plasma PS50C7700, I don't get any DTS-HD but only up to DTS- and 3D is working great. So I chose from the first post Samsung 3DTV - ONKYO HT-R548 but it didn't got the dts-hd so i choose the Samsung LN-S4095D - ONKYO TX-NR906 and i got the dts-hd but I lost 3D (couldn't watch any 3d movie) so please can u help with this one.
post #3320 of 3563
Originally Posted by nikonja View Post
Hi guys
Samsung PS50C7700 (HT-R390 Fixed).zip 1k .zip file
post #3321 of 3563
Sorry. Forgot all about this. I'm digging out my Display Port adaptor now to test.
post #3322 of 3563
Hm... that's not going to work. I have a regular Display Port -> HDMI but my 6970 has a mini DP connection. I'm still going to look at the GetEDID code though and see if I can figure out why it's not getting the EDID.
post #3323 of 3563
@Tulli
Thanks 3D is ok but I don't have DTS-HD again. Can you maby combine PS50C7700 and ONKYO TX-NR906, if that is even possible !
post #3324 of 3563
Not needed. DTS-HD descriptor is present in your mod:
Check that all audio formats are listed under "Supported Formats" for the HDMI audio device. Is that a dual monitor setup? Is the plasma set as primary monitor?
post #3325 of 3563
After lodes of looking around I think I finally arrived in the correct corner of the internet to solve my issue.
i have an AMD centered HTPC (A6-3500 apu) that is giving me troubles.
The setup:
HTPC ==(hdmi)==>Yamaha rx-v667==(hdmi==>Epson EMP TW9000 projector
from the yamaha I connect to a 7.1 surround setup (Boston A)
This all works good (including bitstreaming truehd with XBMC AE build) except for 3 things:
- Windows is supposed to detect my AVR as a monitor, but doesn't
- I cannot run windows 7 in higher mode than 1080p 30hz interlaced. If I go higher I get glitches when opening control panel etc. 720p 60hz does work
- When I do not turn on the projector, but connect via rcmd and just start music, the AMD audio HDMI connection goes to not plugged in after 5ish minutes
Do you think an EDID override could solve one or more issues?
Also, if I read the guides it says to roll back to defautt pnp monitor, but do i also need to uninstall the latest ccc drivers?
Edited by daffeh - 10/16/12 at 7:14am
post #3326 of 3563
Try fist cleaning up all monitor driver leftovers in the registry (1st. post, section 4), reboot and see if redetection fixes the problem with the video timings. If OTH the AVR has a glitch replicating the projector EDID an override would fix it.. Finally the AMD audio being "not plugged" is a driver issue.
If in the end an EDID override is needed post the native real-time EDID of the TW9000.
post #3327 of 3563
Hello Guys,
I was surfing the web desperately for months to find a solution for not getting HD audion on my Onkyo HT-R380 (TV: Samsung LE40C530; VGA: Shappire Ultimate HD6670 [catalyst 12.8]) - Finally got to this thread.
Does a quick solution exist, or do I have to play around manually?
Tlore
post #3328 of 3563
Originally Posted by Tlore View Post
Hello Guys,
Tlore
Yes, look at the table on 1st. post for closest mod to your setup. Or search through the thread for similar mods for a 5.1 AVR.
post #3329 of 3563
Sorry, I missed that list at the end of the post
I used the advised general Samsung-Onkyo combination... and it works!
Many THANKS!
post #3330 of 3563
What does OTH stand for?
Code:
Monitor
  Model name............... EPSON PJ
  Manufacturer............. Samsung
  Plug and Play ID......... SECA50B
  Serial number............ n/a
  Manufacture date......... 2011, ISO week 45
  Filter driver............ None
  EDID revision............ 1.3
  Input signal type........ Digital
  Color bit depth.......... Undefined
  Display type............. RGB color
  Screen size.............. 1600 x 900 mm (72,3 in)
  Power management......... Not supported
  Extension blocs.......... 1 (CEA-EXT)
  DDC/CI................... Not supported
Color characteristics
  Default color space...... sRGB
  Display gamma............ 2,20
  Red chromaticity......... Rx 0,640 - Ry 0,329
  Green chromaticity....... Gx 0,300 - Gy 0,600
  Blue chromaticity........ Bx 0,149 - By 0,060
  White point (default).... Wx 0,313 - Wy 0,328
  Additional descriptors... None
Timing characteristics
  Horizontal scan range.... 15-92kHz
  Vertical scan range...... 24-85Hz
  Video bandwidth.......... 170MHz
  CVT standard............. Not supported
  GTF standard............. Not supported
  Preferred timing......... Yes
  Native/preferred timing.. 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
  Detailed timing #1....... 1920x1080p at 50Hz (16:9)
    Modeline............... "1920x1080" 148,500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
     640 x  480p at  60Hz - IBM VGA
EIA/CEA-861 Information
  Revision number.......... 3
  IT underscan............. Supported
  Basic audio.............. Not supported
  YCbCr 4:4:4.............. Supported
  YCbCr 4:2:2.............. Supported
  Native formats........... 5
  Detailed timing #1....... 1920x1080i at 60Hz (16:9)
    Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
  Detailed timing #2....... 1920x1080i at 50Hz (16:9)
    Modeline............... "1920x1080" 74,250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
  Detailed timing #3....... 1280x720p at 60Hz (16:9)
    Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
    1920 x 1080p at  60Hz - HDTV (16:9, 1:1) [Native]
    1920 x 1080p at  50Hz - HDTV (16:9, 1:1)
    1920 x 1080p at  24Hz - HDTV (16:9, 1:1)
    1920 x 1080i at  60Hz - HDTV (16:9, 1:1)
    1920 x 1080i at  50Hz - HDTV (16:9, 1:1)
    1280 x  720p at  60Hz - HDTV (16:9, 1:1)
    1280 x  720p at  50Hz - HDTV (16:9, 1:1)
     720 x  480p at  60Hz - EDTV (16:9, 32:27)
     720 x  480p at  60Hz - EDTV (4:3, 8:9)
     720 x  576p at  50Hz - EDTV (16:9, 64:45)
     720 x  576p at  50Hz - EDTV (4:3, 16:15)
     720 x  480i at  60Hz - Doublescan (16:9, 32:27)
     720 x  480i at  60Hz - Doublescan (4:3, 8:9)
     720 x  576i at  50Hz - Doublescan (16:9, 64:45)
     720 x  576i at  50Hz - Doublescan (4:3, 16:15)
     640 x  480p at  60Hz - Default (4:3, 1:1)
    1440 x  480p at  60Hz - DVD (16:9, 16:27)
    1440 x  480p at  60Hz - DVD (4:3, 4:9)
    1440 x  576p at  50Hz - DVD (16:9, 32:45)
    1440 x  576p at  50Hz - DVD (4:3, 8:15)
    NB: NTSC refresh rate = (Hz*1000)/1001
CE vendor specific data (VSDB)
  IEEE registration number. 0x000C03
  CEC physical address..... 1.0.0.0
  Supports AI (ACP, ISRC).. Yes
  Supports 48bpp........... No
  Supports 36bpp........... Yes
  Supports 30bpp........... Yes
  Supports YCbCr 4:4:4..... Yes
  Supports dual-link DVI... No
  Maximum TMDS clock....... 225MHz
  Video latency (p)........ 151ms
  Audio latency (p)........ n/a
  Video latency (i)........ 121ms
  Audio latency (i)........ n/a
  HDMI video capabilities.. Yes
  EDID screen size......... No additional info
  3D formats supported..... Not supported
  Data payload............. 030C001000B82DE04CFF3DFFC00401000063
CE colorimetry data
  xvYCC709 support......... No
  xvYCC601 support......... No
  sYCC601 support.......... No
  AdobeYCC601 support...... No
  AdobeRGB support......... No
  Metadata profile flags... 0x00
CE video capability data
  CE scan behavior......... Supports overscan and underscan
  IT scan behavior......... Always underscanned
  PT scan behavior......... Supports overscan and underscan
  RGB quantization range... Selectable (via AVI YQ)
  YCC quantization range... Selectable (via AVI YQ)
Report information
  Date generated........... 17/10/2012
  Software revision........ 2.60.0.972
  Data source.............. Real-time 0x0031
  Operating system......... 6.1.7601.2.Service Pack 1
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4C,A3,0B,A5,01,01,01,01,2D,15,01,03,80,A0,5A,78,0E,DE,50,A3,54,4C,99,26,
  0F,50,54,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
  45,00,40,84,63,00,00,1E,02,3A,80,D0,72,38,2D,40,10,2C,45,80,40,84,63,00,00,1E,00,00,00,FD,00,18,
  55,0F,5C,11,00,0A,20,20,20,20,20,20,00,00,00,FC,00,45,50,53,4F,4E,20,50,4A,0A,20,20,20,20,01,B3,
  02,03,33,B5,54,90,1F,20,05,14,04,13,03,02,12,11,07,06,16,15,01,0F,0E,1E,1D,72,03,0C,00,10,00,B8,
  2D,E0,4C,FF,3D,FF,C0,04,01,00,00,63,E3,05,00,00,E2,00,FB,01,1D,80,18,71,1C,16,20,58,2C,25,00,40,
  84,63,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,40,84,63,00,00,9E,01,1D,00,72,51,D0,1E,20,6E,
  28,55,00,40,84,63,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,5F
