AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 112
post #3331 of 3565
Sorry, I meant OTOH ("on the other hand").
Here's your mod:
Epson TW9000 - YAMAHA RX-V667.zip 1k .zip file
post #3332 of 3565
Here's your mod:
I installed it and now my rx-v667 shows up as a monitor but none of my other issues are fixed.
Maybe it would be better to open up a new topic for this, so tell me if this has nothing to do with EDID.
When I boot up my pc in 1080p@60hz, all is fine
The TW9000 reports to be working at 1080p@59.9997
Then when I open certain things (control panel, gmail, tweakers.net, context menu in explorer,...) the resolution somehow changes, the screen glitches and my projector will go (very briefly) into the not supported mode. It goes too fast to read but it says something like
- Not supported resolution: H:60,1777 V:161,875
The the screen goes blank until I ALT+F4 the running app.
It does not do this in 720p@60, 1080i@30 and 1080p@24
It also does this when bypassing the AVR
It does not do this when the applications are not full screen (I think)
It does not do this with XBMC (real fullscreen or windowed fullscreen)
My HDMI audio issue got worse btw. Now it will not send anymore sound to my speakers when the projector is off. Before it did this for 5ish minutes, then the 'not pluggin in thing happened' I based myself on this post to have this fix the issue
post #3333 of 3565
You should not need an override for an RX-V receiver with an Epson projector unless you want to default it to a specific resolution.
Here are some Yamaha receiver settings I posted for someone else. It was an RX-V863 but it should point you in the right direction with the 667:
Originally Posted by vladd View Post
Option Menu -> Video Settings -> Video Conv -> On
Option Menu -> Video Settings -> HDMI Res. -> *Through
Option Menu -> HDMI Set -> S. Audio -> RX-V863
I also have an option in the advanced setup to skip a monitor check that may or may not be useful for you.
Turn off AVR.
Hold "Tone" and press "Power" on AVR.
Use the "Program" dial to go to "Monitor Check..."
Press "Tone" to toggle the setting (options are "Yes" or "Skip").
Press "Power" to save setting.
Try those settings before applying an override.
Using this, Favelle got it working with his HTR-6xxx and and Epson 8100. And I have no issues with either of my Yammys and my Epson 8350.
post #3334 of 3565
1.Pansonic TX-32LZD81
2.Onkyo HT-R380
3 ATI 5450
TMT5 playback device.
Onkyo HT--380.txt 9k .txt file
PANSONIC TX-32LZD81.txt 8k .txt file
Edited by 2KAN - 10/26/12 at 4:10pm
post #3335 of 3565
2.Onkyo HT-R380
3 ATI 5450
I have noticed that others with the same AVR have had issues bitstreaming TrueHD. i.e Light on AVR doesnt change and displays PCM.
When i run MonInfo it displays my AVR ? Monitor_Asset_Manger_Realtime.txt 6k .txt file is this correct?
Fixed. I assume the Panasonic video timings are being correctly replicated in the AVR EDID:
Panasonic TX-32LZD81 - ONKYO HT-R380.zip 1k .zip file
post #3336 of 3565
2.Onkyo HT-R380
3 ATI 5450
biggrin.gif Fantastic! Thank you so very very much,this little light has lead to so much frustration and has been driving me mad for a while now and it now works as it should. Thank you again.
[Q] If i upgrade to windows 8 would this new .inf file work also? Thank you again smile.gif
post #3337 of 3565
Yes, it will work on Windows 8 but you must disable driver signature enforcement:
http://www.avsforum.com/t/1227161/edid-overrides-to-solve-bitstreaming-issues-for-ati-5xxxs/3240#post_22347472
post #3338 of 3565
Keeps breaking the audio even with the disable driver signature enforcement turned off?
1. install windows 8
2. Update Ati drivers
3. Install Monitor .inf file
4. red cross appears on speaker icon and breaks audio.
5.reboot and remains broken.
Any suggestions as I really like the look of windows 8, although it looks like it requires a lot of tweeks to work well with a htpc system.
post #3339 of 3565
That should be a driver problem, not due to EDID detection. Are you using latest AMD drivers?
post #3340 of 3565
Yeah was the latest windows 8 32bit from the AMD website. Strange thing was, I had to disable UAC as well as driver signature enforcement to make it stick. All good now, thank you kind sir. smile.gif
post #3341 of 3565
post #3342 of 3565
Hi,
I have an nvidia 8400M GS
hdmi
> Philips 42PFL9664H TV
Coax----> Pioneer VSX-D511 AVR.
When I test the DTS sound via the windows 7 x64 sound test, it sound great and the receiver identify it as DTS but I can't get DTS to work when playing a movie via xbmc\mpc-hm\vlc.
My PS3 can play DTS using the same connection scheme (PS3->TV->AVR) and the AVR identify it as DTS.
Dolby digital works great on all systems.
I have the EDID of the tv and it does state that only LPCM and AC-3 are supported.
I don't know how to get my AVR EDID as its an old reciver with no HDMI.
Anyway someone can help me add the DTS to my TV EDID? Philips-TV-42PFL9664H.zip 1k .zip file
post #3343 of 3565
Try the attached mod, which should work video-wise for your TV. However it may stiil not give you DTS passthrough if your TV does not allow it. Keep in mind that PC graphic drivers do enforce EDID specs.
Philips 42pfl9703h+AC3+DTS (5.1).zip 2k .zip file
post #3344 of 3565
Thanks Tulli, but it doesn't work... still no DTS using MPC and ffdshow set to bitstream.
Any idea why the PS3 can play DTS via my TV but the computer can't?.
post #3345 of 3565
post #3346 of 3565
Is DTS listed as a supported format for the HDMI audio device after applying the override? If you right-click on the ffdshow audio systray icon, does it show "HDMI passthrough" or something similar?
post #3347 of 3565
The only possiblity is that the PS3 is presenting the DTS encapsulated in WAV/PCM. The VSX is able to detect the DTS framing in the PCM stream but the TV just thinks it's passing a regular 2 channel PCM stream.
You would need to use an audio decoder that will encapsulate DTS in WAV/PCM format. I can't think of any offhand that will do it. ffdshow might but I haven't used it in a long time.
post #3348 of 3565
That should be it, vladd! In fact, it should be the rule as most TVs (e. g. Samsungs) don't have DTS capability.
post #3349 of 3565
AFAIK, no tv does.
I believe that you would need to limit the EDID to 2 channel PCM for it to work as well (or set Windows audio settings to be two channel output)
post #3350 of 3565
That's sound true, but I can't understand how the windows test in the audio settings can also send DTS signal. I don't believe it encapsulate it as WAV/PCM.
post #3351 of 3565
Hello,
I have a ATI-6450 and a Onkyo TX-SR313 AV connected by HDMI and am in need of a fix please.
My problem is slightly different to most though from what I am reading, first of all with the Generic PnP Driver installed according to Windows Sound I have all supported formats, XBMC will only play normal DTS files with DTS-HD or TrueHD enabled, in Power DVD options they all show too UNTIL I play something then I lose DTS-HD but PCM and normal DTS remain, if I pause then DTS-HD returns until I play it.
This lead me to try various EDID fixes, a couple I created myself and a number posted on here with a variety of results, most don't change anything at all some break audio completely but one I found enables DTS-HD & TrueHD but only at 48Hz though 192 is listed in the EDID file and 192 PCM continues to work which confuses me, the file in question is "Samsung LE46B650 - ONKYO TX-NR509" and is on the first page.
I have exported my detected EDID from MONINFO too which I have attached below.
TX-SR313.zip 1k .zip file
Please let me know if you require any further information.
post #3352 of 3565
Audio block is standard in all mods to enable all sample rates. If you get 48khz it must be the source as audio is being bitstreamed, i. e. passed through unmolested for reproduction on the AVR.
post #3353 of 3565
Ok 'problem' solved, one should never stay up for 28 hours trying to fix these issues as you end up missing things.
Came back to it this evening using that driver I 'said' partially works, which is just rubbish as it works fully, basically because the files I was testing with were 48KHz that is obviously all I was going to get when playing DTS-HD, I have downloaded some sample tracks at a few different rates and all work ok so my problem is solved.
Thanks anyway for all your help.
post #3354 of 3565
Hello, i need edid overrides for
Samsung ES6800 3DTV,
Onkyo Tx-sr309,
Sapphire Hd 6850 (HD3D).
Pc -> HDMI -> Onkyo tx-sr309 -> HDMI -> Samsung ES6800
DTS-HD OK
DOLBY-HD OK
FULL-HD OK
3D - SBS OK
TMP5 FOR ISO BLURAY (NOT WORKS) NOT RECOGNIZE DEVICE 3D
TRIDEF GAMES 3D (NOT WORKS) NOT RECOGNIZE DEVICE 3D
Pc -> HDMI -> Samsung ES6800
TMP5 FOR ISO BLURAY OK
TRIDEF GAMES 3D OK
post #3355 of 3565
Does it work when connected directly to the TV? If yes, post both real-time EDIDs (see instr. in 1st. post). Otherwise it's a TMT5/driver problem.
post #3356 of 3565
Hi All,
Sorry I thought I updated my post, I have fixed the issue fully now, part of my problem was staying up until 5am trying to fix it I think because I got there at about 3am but didn't realize it...
Basically for my TV the driver for the "Samsung LE46B650 - ONKYO TX-NR509" works, but the one I created for my Amp doesn't frustratingly meaning that I have to manually select this driver, I tried editing it in MonInfo to relect my device name "Onkyo TX-SR313" but when installed it still showed the "TX-NR509".
Still far from the end of the world it's working that is what matters right!
If anyone can fix the naming problem or tell me what I am doing wrong when trying to edit it in MonInfo however that would be much appreciated.
post #3357 of 3565
Create the .bin file with Moninfo, then find the exact position of the ID in the base block with Extron EDID Manager. Use notepad now to replace the ID. in the .inf file, save and apply the override.
post #3358 of 3565
Hi Tulli Thanks but I am not sure I am clear...
1. Create a .BIN File of the Generic PnP Monitor or the working INF I have?
2. When you said the ID am I looking for the Friendly name of the device?
Rest sounds simple enough. :P
Sorry if I am being stupid.
post #3359 of 3565
Yes, use the working INF and the friendly name (the "Monitor Descriptor").
post #3360 of 3565
Onkyo Tx-sr309,
DTS-HD OK
DOLBY-HD OK
FULL-HD OK
3D - SBS OK
TRIDEF GAMES 3D OK
Hello again
Delete older overrides .inf (tx-sr509 - b6500 this forum)and now:
DTS-HD NOT WORKS (bitstreaming) only 2 chanels
DOLBY-HD NOT WORKS(bitstreaming) only 2 chanels
DTS an DD OK
LPCM 5.1 for games, movies,etc OK
FULL-HD OK
3D - SBS OK
TMP5 FOR ISO BLURAY works!!!!
TRIDEF GAMES 3D works!!!!
Reciver whit TV
Onkyo tx-sr309.zip 1k .zip file
Only TV
Samsung ES6800.zip 1k .zip file
Thanks again.
