Originally Posted by
Ivaylo Pissanov
Hello everyone. I also have this problem. Im using laptop ASUS K55V with intel integrated video and Nvidia GT 630M; TV Panasonic TX-L42ET5E and DVD player LG HT503PH-DH. Im connecting Asus--->hdmi--->TV Panasonic--->optical cable--->LG dvd player. I just installed the custom edid from Tulli (tnx a lot for his efforts and help) but still i only get 2 chanels. What should i do ??? I have installed the custom edid like it said on the first page.
Again, and again, and again: 2 channels is
correct, even if misleading (if you mean WIndows detection)! It means: 2 channels
uncompressed audio (LPCM), which is the maximum bandwidth for S/PDIF. If you want to sent multichannel
compressed audio just set your application to do so. But it will work only for AC3. DTS will only work when encapsulated in a WAV stream. Best solution for S/PDIF is just using an optical or coaxial cable for audio.
