AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 116
post #3451 of 3563
thanks for the answer
post #3452 of 3563
Hi, i have ATI Radeon 5450, i used to be able to bitstream HD audio, dolby, dts from my HTPC to my AVR Onkyo 606 with Samsung LN52A550. Everything is connected via HDMI and my receiver will show audio ie. HD Master, True-HD etc, or dolby, DTS. Since upgrading to Windows 8, i am no longer able to passthrough audio to my receiver, all i see is PCM. Also, in my sound configuration in windows, i now only see stereo! I used to be able to select 5.1, 7.1 and quadrophonic? options before. I have the latest Catalyst 13.1 and a clean install Windows 8 and still to no avail. Did W8 change how it detects my audio config? I never did any EDID override back with Windows 7 with Catalyst 10.5 drivers. Do i need an EDID override? Any help would be appreciated or directions on how i could fix this. Thanks in advance.
post #3453 of 3563
Are TrueHD and DTS HD listed for the HDMI audio device? Which player are you using to bitstream? Could be a problem with your current AMD driver. Try an older version compatible with Win8.
post #3454 of 3563
Originally Posted by carlincapo View Post
Hello again,
DTS-HD y DD-HD not work (bitstreaming) with this edid:
Samsung ES6800 - ONKYO TX-SR309.zip 1k .zip file "trulli' overrrides"
only 2 channels in control panel
DTS and DD works
3D works
DTS-HD y DD HD works (bitstreaming) with this edid:
Samsung LE46B650 - ONKYO TX-NR509.zip 1k .zip file "download here"
8 channels in control panel
but 3D not work
My reciver is ONKYO TX-SR309 and my TV Samsung ES6800
Onkyo tx-sr309.zip 1k .zip file
and
Samsung ES6800.zip 1k .zip file
Can you fix this problem?
thanxs again, you are the best!!!
Clean all drivers, install catalyst 13.1, install trulli overdrive "Samsung ES6800 - ONKYO TX-SR309.zip" and works all!!!
DTS-HD, Dolby-HD, 3D, etc,
Trouble whit realtek HDMI ATI, uninstall.
thanxs Trulli again.
post #3455 of 3563
Are you referring to the AMD HDMI Output properties? TrueHD and DTS HD are not listed frown.gif I am using TMT5 for bluray disc playback and MPC-HC (with LAV filters) for MKV, m2ts movie files.
post #3456 of 3563
Nevermind. I finally got it to work. Bitstream audio now works as again. Thanks.
post #3457 of 3563
Tulli, can EDID override help with hdcp issues? Here is my edid.
post #3458 of 3563
No, what issues?
post #3459 of 3563
No, what issues?
Getting this error on the laptop (hd4000 intel core i5 3rd gen with a 1920x1080p internal display) using the internal display
The working theory is that the display is likely connected using displayport and WMC does not allow hdcp over DP so no premium channels work (local channels work fine with minimizing and maximizing window).
The premium cable channels works fine if connected to an external HDMI display. So the suspicion is this is an HDCP issue.
post #3460 of 3563
Hi Friends , i have the same problem with dts hd and ati , can you help me with my system ? I have a ati 6850 , my display is a Samgung un40eh6030 and my receiver is a ht r358 ( it´s the receiver from the Home system HT S3505 .
Thanks !!
post #3461 of 3563
Thanks !!
The attached mod should work with your TV. Otherwise capture and post the real time EDID.
Samsung UE40ES7000 + 5.1HDaudio.zip 1k .zip file
post #3462 of 3563
HI Tulli. First, thanks for what is clearly a lot of work you have been doing to help people out over the last few years. I have a quick question. I have a Windows 8 PC with a HD5670 connected via HDMI to a Harman Kardon AVR which is connected to an Epson 5020UB Projector. Sound seems to be fine, but video blanks out every few seconds whenever I am not actively playing full screen video from the PC. Everything I have read seems to point to a handshake problem occuring between the three devices. Video works fine from all of my other inputs connected to that AVR. Do you think creating a custom inf, and loading it for my setup will fix my problem? Thank you in advance!
post #3463 of 3563
No, unfortunately it won't help as the problem is not detection but specifically handshaking, You could try using separate connections with an AMD DVI-HDMI adapter. Or the more expensive choice of a Gefen HDMI Detective.
post #3464 of 3563
Hello Tulli,
I am trying to get EDID override for the following system: PC with Intel HD 3000, HDMI-Splitter with 2 outputs for Panasonic 50VT30 and Denon AVR 4308. It does not work.
Now I read that EDID override with the HD 3000 is not possible.
My question is if it is poosible to make that work with an ATI HD 7750 graphic card. HD Sound over HDMI Splitter / Denon AVR and 3D Picture over HDMI Splitter / Panasonic 50VT30.
Attached you will find the inf.Files. If the solution with the HD 7750 is possible it will be great if you can merge that files.
Thank you very much
Stefan
Denon AVR 4308.zip 1k .zip file
Panasonic 50VT30.zip 1k .zip file
post #3465 of 3563
post #3466 of 3563
Hello Tulli,
thank you for that file. I hope it will work with the HD 7750.
Regards - Stefan
post #3467 of 3563
Hi all,
I'm currently having a problem that I can't explain, which I believe may be due to this issue.
I have a denon 4311 and I switch between 2 tvs (well 1 tv and 1 monitor) as it has duel hdmi out.
On the font page there is an LGTV and Denon 4311 edid but as I have a Panasonic tv and an LG monitor how will I apply an edid override? Can I just apply an edid for the 4311 as currently I am unable to get hd audio from my 6320 to my 4311.
If anyone can help I'd be so grateful as I have no Idea what's gone wrong or how this happened as previously it was working fine, but switching between monitors may have caused this issue.
Absolutly any help/advic welcome...
My Monitor (HDMI OUT 2) is an LG Flatron W2452T
My TV (HDMI OUT 1) is either the Toshiba 55WL968 / Panasonic WT series...
My ATI card is a 6320 (E-450)
If anyone can give me any advice, help, solution I'd be eternally grateful as currently my entire system will not play hd audio and I don't know why frown.gif
Thanks in advance.
post #3468 of 3563
Choose the EDID override according to the TV, not the AVR.
What is exactly your issue? With output to two different TVs you can't use one single EDID override unless video timings are compatible with both TVs.
post #3469 of 3563
Hi,
My issues is that my avr is reporting hd audio but my htpc won't send it via ffdshow, mpc-hc etc..
But if I reconnect to one of my other tvs it does send hd audio?
Basically, my avr has 2 hdmi outputs. It outputs to the monitor to the tv depending on what I am doing, or in some cases both at thence same time.
Since switching between monitors and tvs etc my htpc has stopped detecting the capabilitys that my avr can receive bit stream hd audio, it's reported as being supported but fails when it's attempted.
If I disconnect and reconnect to my other HDTV my htpc sends he audio to the avr as expected, re connect my monitor and it's gone!
Bearing in mind the htpc is connected to the avr via hdmi and then on to a display (that receives no audio anyway) I'm confused why my htpc stops being he audio compatible when connected to a monitor as that (to me) makes no sense as its just where the picture goes, the audio stops at the avr and goes out the speakers... So I can only assume that when switching monitors that my avr is somehow reporting back to windows that the new monitor is not capable of he audio even though it's displayed in the audio settings? ...
Tl;dr
HTPC -> AVR -> TV all via hdmi = HD Audio
HTPC -> AVR -> Monitor = No HD Audio even though it is reported as supported?
I'm so bamboozled by this as to me, it's just end end point display, it should effect my audio compatibility what so ever? I should be able to connect to a black and white 4" display if I want and still get hd audio via my avr which is connect to my htpc via hdmi smile.gif
Dam pcs!
I was thinking of buying a steam box, but **** like this reminds me why I moved to consoles all those years ago smile.gif
post #3470 of 3563
What is the native resolution of the monitor? If not HDTV (i. e 1080p or 720p) the DENON won't allow HD audio.
post #3471 of 3563
Hello joined the forum just for this problem. I have a problem playing DTS-HD files. My Max Number of Channels in sound setting only goes up to 6, I get stuttering of DTS-HD files in XBMC. I have tried all the settings from the XBMC forums and suggestions from forum members and the last case scenario was suggested to override the EDID to make XBMC and Windows recognize 8 channel capability.
My setup
GPU - Sapphire HD6450 512mb
HDTV - Sony KDL-40EX403
AVR - Onkyo HT-R380
As the guide states (using Moninfo) -
- I connected my GPU to my TV and created the INF to get the TV info
- then I connected the GPU to the AVR (normal setup) and created the INF to get the AVR info
Here are the files
Onkyo HT-R380 and Sony KDL-40EX403.zip 3k .zip file
Edited by Elvenmunky - 2/20/13 at 12:18pm
post #3472 of 3563
post #3473 of 3563
Thank you! Fixed my problem!
post #3474 of 3563
I'm trying to get DTS-HD from my HD 6870 via HDMI, but haven't been able to using any software including Total Media Theater 6. All I can get is regular DTS. So far all the search results on here seem to point to this EDID issue. I tried to update my drivers with the method described here, but I must be doing something wrong because it gives me the message "The best driver for your device is already installed" "Windows has determined the driver software for your device is up to date".
Here's what I'm running and what I pulled from the moninfo program.
Samsung PN58b550
Samsung PN58B550.zip 1k .zip file
Onkyo TX-SR313
Onkyo TX-SR313.zip 1k .zip file
post #3475 of 3563
post #3476 of 3563
Wow, that worked perfectly, thank you so much. I've literally been trying to get this to work since yesterday! Now even my XBMC software works.
P.S. I had to reboot Windows 8 via the advance boot options to disable driver signing before it would allow me to update the new driver provided.
post #3477 of 3563
I'm trying to get truehd out of my devices, here is the hardware I am using and a zip folder containing the GetEDID info. please help smile.gif
HTPC
AMD 640 3.0Ghz quad core
8 GB DDR3 1333Mhz
2 GB Radeon HD6670
Asus M5A78L-M LX V2 Motherboard
Corsair Builder Series CX500W PSU
Trendsonic Apollo ATX Gaming Case
AV Equipment
LG - 50PZ570T 50" plasma 3DTV
Onkyo - HT-R380 (HT-S3300)
Onkyo zip
.0.1.zip 2k .zip file
Edited by TheBigRoberto - 2/27/13 at 7:58am
post #3478 of 3563
LG - 50PZ570T.zip 1k .zip file
post #3479 of 3563
post #3480 of 3563
Thank you so much, works perfectly
