HELP! Please!
I have a mitsubishi WD-73840 connected to a home built computer with CF HD6850s.
It will bitstream movie data just fine, but games are what I was really interested in. The TV has built in 5.1 sound on a 16 speaker sound bar, so its psycho acustic reflected sound. It works pretty well.
I actually bought a DVI+SPDIF -> HDMI adapter. It works but its HDMI 1.3b and for some reason I'm not getting 1:1 pixels anymore. I had to use a Digital dolby live card with it to encode the audio but its older and the audio skips because it was never really ment for a 64 bit OS.
I think EDID is my last hope for getting high quality picture and surround sound. Please if anyone could take pity on me and help me make an EDID file. With the adapter I do get surround sound. I think the only problem is that the TV's EDID reports that there are only 2 speakers instead of like this
Code:
CE audio data (formats supported)
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No <----Make these Yes
Front center............. No <----Make these Yes
Rear left/right.......... No <----Make these Yes
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
Mitsubish TV EDID
Code:
Monitor
Model name............... MEUSPTV14
Manufacturer............. Mitsubishi
Plug and Play ID......... MEL31D5
Serial number............ n/a
Manufacture date......... 2011, ISO week 21
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 2040 x 1150 mm
Power management......... Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.669 - Ry 0.308
Green chromaticity....... Gx 0.281 - Gy 0.668
Blue chromaticity........ Bx 0.150 - By 0.059
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-68kHz
Vertical scan range...... 59-61Hz
Video bandwidth.......... 230MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1920x1080p at 30Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1920 x 1080p at 60Hz - VESA STD
1360 x 765p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1920x1080p at 24Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
Detailed timing #2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #3....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #4....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 3.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
Video latency (p)........ 1ms
Audio latency (p)........ 1ms
Video latency (i)........ 1ms
Audio latency (i)........ 1ms
HDMI video capabilities.. Yes
EDID screen size......... No additional info
3D formats supported..... Not supported
Data payload............. 030C003000B82DE001010101C8040140001F
CE colorimetry data
xvYCC709 support......... No
xvYCC601 support......... No
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
Metadata profile flags... 0x00
CE video capability data
CE scan behavior......... Supports overscan and underscan
IT scan behavior......... Supports overscan and underscan
PT scan behavior......... Supports overscan and underscan
RGB quantization range... Selectable (via AVI YQ)
YCC quantization range... Not supported
Report information
Date generated........... 4/18/2013
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0021
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,34,AC,D5,31,01,01,01,01,15,15,01,03,80,CC,73,78,2A,70,85,AB,4E,48,AB,26,
0F,50,54,21,08,00,D1,C0,8B,C0,81,80,81,C0,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,F5,7A,74,00,00,1E,01,1D,80,18,71,38,2D,40,58,2C,45,00,F5,7A,74,00,00,1E,00,00,00,FD,00,3B,
3D,0F,44,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4D,45,55,53,50,54,56,31,34,0A,20,20,20,01,91,
02,03,32,F1,48,90,22,20,05,04,03,07,01,26,15,07,50,09,07,07,83,01,00,00,72,03,0C,00,30,00,B8,2D,
E0,01,01,01,01,C8,04,01,40,00,1F,E3,05,00,00,E2,00,7F,01,1D,80,3E,73,38,2D,40,7E,2C,45,80,F5,7A,
74,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,F5,7A,74,00,00,9E,01,1D,00,72,51,D0,1E,20,6E,28,
55,00,F5,7A,74,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,F5,7A,74,00,00,18,00,00,00,00,00,A0
Adapter EDID
Code:
Monitor
Model name............... CAT-6066
Manufacturer............. CAT
Plug and Play ID......... CAT6660
Manufacture date......... 2006, ISO week 50
Screen size.............. 600 x 340 mm (27.2 in)
Red chromaticity......... Rx 0.652 - Ry 0.332
Green chromaticity....... Gx 0.270 - Gy 0.589
Blue chromaticity........ Bx 0.141 - By 0.068
White point (default).... Wx 0.285 - Wy 0.293
Horizontal scan range.... 31-50kHz
Vertical scan range...... 56-75Hz
Video bandwidth.......... 80MHz
Native/preferred timing.. 1920x1080i at 60Hz
Detailed timing #1....... 720x480p at 60Hz
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768i at 87Hz - IBM
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
800 x 600p at 85Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
640 x 480p at 85Hz - VESA STD
IT underscan............. Not supported
Detailed timing #1....... 1920x1080i at 50Hz
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 1440x480i at 60Hz
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #3....... 1440x576i at 50Hz
Modeline............... "1440x576" 27.000 1440 1464 1590 1728 576 580 586 624 interlace -hsync -vsync
Detailed timing #4....... 1280x720p at 60Hz
Detailed timing #5....... 1280x720p at 50Hz
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
Channel configuration.... 10.1
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. Yes
Front left/right center.. Yes
Rear left/right center... Yes
CEC physical address..... 1.0.0.0
Maximum TMDS clock....... 165MHz
Report information
Data source.............. Real-time 0x0051
Raw data
00,FF,FF,FF,FF,FF,FF,00,0C,34,60,66,00,00,00,00,32,10,01,03,80,3C,22,78,2A,03,20,A7,55,45,96,24,
11,49,4B,1F,DF,00,45,59,A9,40,81,80,31,59,01,01,01,01,01,01,01,01,01,1D,80,18,71,1C,16,20,58,2C,
25,00,5B,56,21,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,5B,56,21,00,00,18,00,00,00,FC,00,43,
41,54,2D,36,30,36,36,0A,20,20,20,20,00,00,00,FD,00,38,4B,1F,32,08,00,0A,20,20,20,20,20,20,01,D1,
02,03,22,71,4F,85,02,03,04,01,06,07,11,12,13,14,15,16,10,1F,23,09,07,07,83,7F,00,00,65,03,0C,00,
10,00,01,1D,80,D0,72,1C,16,20,10,2C,25,80,5B,56,21,00,00,9E,8C,0A,A0,14,51,F0,16,00,26,7C,43,00,
5B,56,21,00,00,98,8C,0A,A0,20,51,20,18,10,18,7E,23,00,5B,56,21,00,00,98,01,1D,00,72,51,D0,1E,20,
6E,28,55,00,5B,56,21,00,00,1E,01,1D,00,BC,52,D0,1E,20,B8,28,55,40,5B,56,21,00,00,1E,00,00,00,2B
