AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 121
post #3601 of 3895
Thanks for the heads up, but you know what's strange? I had 3D and bitstreaming working in Windows 7 Ultimate with no special drivers. I'm on 8 Pro now.
post #3602 of 3895
Of course, because the problem is due exclusively to Nvidia drivers.
post #3603 of 3895
hi guys, i've got a big problem..
i've used successfully edid override since two 2 ago, when i format my hdd for an upgrade.
Now, the same file that i previously use (lg monitor + denon receiver) doesn't work..
My system is the same, just use SSD instead HDD... last Catalyst installed for my Ati 5450, win 7 ultimate.
Some advice?
Thx
(sorry for my poor english)
post #3604 of 3895
No idea as it should just work. Are all audio formats listed for the HDMI audio device? Perhaps it's a DS filter problem. What video player are you using?
post #3605 of 3895
yes, all forat are listed.
i'm using mpc-hc.. not problem at all with dts or dolby..
the problem is that my audio device isn't recognized if i don't start my amp first and then my htpc... and after short time (if i don't use pc) my audio device just dissaper :/..
with edid override i resolved this problem last time.. now it simple doesn't work....
post #3606 of 3895
Are you using the same AMD driver?
post #3607 of 3895
the last one, official release.... i didn't back up the old ones... maybe i can try with previous release?
post #3608 of 3895
Sure, should be a driver problem.
post #3609 of 3895
just try some previous drivers.. but it doesn't work....
little update..
try 11.4 driver version and disabled Denon passthrough (previously works fine but it doesn't matter)
Now, when I turn on my amp, i need to manually unplugged and re-plugg my hdmi cable in order to see "ATI HMDI OUTPUT" avaible...
Only if i turn on pc and amp together, my "ATI HMDI OUTPUT" is avaible from the beginning of session...
very frustrating ....
Edited by Luca Zanetti - 8/31/13 at 7:32am
post #3610 of 3895
I'm trying to bitstream DTS-HD using AMD HD 6950 and ONKYO HT-R391 on LG LW6500 with no luck. My last resort is to try the EDID mod. Everything works ok (DTS/LPCM/AC3/etc) and the receiver was tested using a PS3 and a DTS-HD MA bluray and it is fine. Even using the latest catalyst 13.4 and ATI HDMI drivers or Realtek one.
Using Windows 8 pro.
Could you please help me ?
Setup:
TV LG LW6500
Receiver Onkyo HT-R391 (S3500 receiver)
AMD HD 6950
Windows 8 Pro
Catalyst 13.4
LG LW6500 + ONKYO HT-R391.zip 3k .zip file
Edited by xisque - 9/5/13 at 1:59pm
post #3611 of 3895
post #3612 of 3895
PERFETCT!!!!!!!
Working 100%!!!!! Finally!
post #3613 of 3895
little update..
new update.. i try with moninfo to create my own .inf file... and now works! I'm very happy smile.gif
post #3614 of 3895
Hi there.
OK, so I have the problem where no HD supported formats appear when I look at the properties for my AVR in Windows Playback Devices.
TV is Sony KDL-40W4000, AVR is Onkyo TX-NR515. Running Window 8 (so have to disable device driver signature verification to install overridden EDID drivers).
I've tried the MonInfo generated INF file for the AVR to no avail.
Have also tried a few of the generic options (and one specific Sony/Onkyo combo) from the EDID INF database.
Oddly enough, when I look at the EDID info for the Onkyo AVR in MonInfo, I see DTS-HD as a supported format:
Playback Device property info shows 8 channels and 192khz support.. but only DTD/DD - no DTS-HD:
Graphics is onboard Intel HD Graphics (the original one - H55 chipset, Core i3 530).
Attached are the realtime INF files from MonInfo (TV+AVR) just in case you think an override would fix this issue.
Thanks for any help at all!!
Cheers, Sony KDL-40W4000 and Onkyo TX-NR515.zip 3k .zip file
Dourn
post #3615 of 3895
Unfortunately Intel graphic adapters don't accept EDID overrides. It's odd nevertheless that only Dolby Digital Plus is listed as supported. Normallly this is due to the sound driver or adapter not being capable of bitstreaming HD audio, only mutlichannel LPCM.
EDIT: googled and found that bitstreaming is possible indeed, so all audio formats should show up. Could be a driver installation issue. Is the MEI driver also installed?
Edited by Tulli - 9/8/13 at 7:56pm
post #3616 of 3895
Hiya - thanks for the quick response.
DTS-HD bitstreaming is indeed possible, I can do it via TMT5.
Intel MEI is indeed installed, and I have the latest drivers (v8.15.10.2858 - no updates available since 2010 I think).
The only reason I'm trying to fix this is that I want to use XBMC as my Bluray player - TMT5 ocassionally issues some distortion when bitstreaming on some titles (always in the same place on a given title) - I'm trying to see if XBMC does the same - but XBMC will only let me bitstream formats that appear in the Support Formats tab on the Playback device properties.
I suspect you're right and it's just that the Clarkdale IGP isn't accepting the EDID override.
So dang, I dunno.
Think I may try a re-install of everything and, if that fails, I'll try a new discrete graphics card.
Thanks anyway!!
post #3617 of 3895
hi, I'm from thailand
I'have been use this file " LG PK-350 - ONKYO HT-R380" it can use on win7-64bit
and now I'm use win 8.1 it can not use "The third-party INF does not contain sigital signature information."
Could you please help me ? Please..
My device HT-R558 (HT-s4505) from ATI7770, moniter LG E2342
Edited by kable3g - 9/10/13 at 8:00pm
post #3618 of 3895
post #3619 of 3895
Originally Posted by Tulli View Post
You need to disable driver signature enforcement first:
http://www.avsforum.com/t/1227161/edid-overrides-to-solve-bitstreaming-issues-for-ati-5xxxs/3240#post_22347472
thank you.
I can do.
post #3620 of 3895
Hi,i would like some help please,i have a lg 42LA6130 and a onkyo HT-R588,graphic card is ati radeon HD-5450 and im running windows 8,all sound formats are listen including hd formats and it says that i have 6 channels,that is right but i think that is there the problem and thats why i cant play hd sound formats,is it possible to do edid override and fix this problem?thanks
post #3621 of 3895
Try the attached EDID override. It should work with your TV.
LG LW6500 - ONKYO HT-R391 (fixed).zip 1k .zip file
post #3622 of 3895
Hi,thanks for the reply but after i install this i have to reset the receiver and the tv?because it says that the hdmi device is not connected.thanks
post #3623 of 3895
Double check the installation (see 1st. post). Make sure to reboot after install.
post #3624 of 3895
Hi again,ive try all again and ive double check all and the same problem,after reboot computer i dont have any sound,say that the hdmi device is not connected.
post #3625 of 3895
Do you have the latest AMD driver installed?
post #3626 of 3895
Yup,ive check now and its the last
post #3627 of 3895
No idea. It looks like a driver issue, and don't see how the EDID override install might have caused it. Perhaps a clean driver install will fix it.
Does it work if the EDID override is uninstalled?
post #3628 of 3895
Yes,after i delete the override and install the "normal" it works good only with that problem that dont play the hd formats
post #3629 of 3895
Onboard audio is disabled? Frankly I have no clue, except that the EDID override is not specifically for your TV, but that shouldn't matter.
Anyhow, post the real-time of your TV if you like to try a proper EDID override.
post #3630 of 3895
Its ok,i will leave like this,anyway most of the movies i have its dts so its ok,anyway thanks a lot for your help.
