AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 124
post #3691 of 3895
Yes.
For some reason, the PCM issue was there even when I connected the HTPC directly to the TV as well.
post #3692 of 3895
Are all audio formats in the LAV Audio Decoder panel set to bitstream? It really looks like the audio stream is being decoded. Are LAV Splitter and Audio decoder being invoked during playback? (Right-click on MPC-HC, Filters)
post #3693 of 3895
Indeed, LAV Audio and LAV Splitter both are being invoked (I blocked Haali Splitter and ffdshow Audio on External Filters).
Should all these ticked options stay as is?
For some reason, the DTS logo light is on at the Onkyo AVR and when I click the Display button on the remote control, I see DTS 5.1 Ch.
post #3694 of 3895
Yes they must all be ticked.
What is that "file source" filter in the chain (capture is low-res so I can't tell)? Just for testing use ony LAV filters (no ffdshow) and set the audio output in MPC-HC specifically to the AMD HDMI audio device, like this:
post #3695 of 3895
Hi Tulli,
So I have been trying all over with the External Filters of MPC-HC for a few days, to get rid of the PCM taking over with no success.
It looks like I managed to make MPC-HC stream DTS 5.1, Dolby Digital 5.1 and DTS-HD-MA to the AVR, as the corresponding light turns on.
That being said, with the PCM still taking over the Pin[IN/OUT] at "AMD HDMI Output (AMD High Definition Audio Device)" and at "LAV Audio Decoder".
Turning the light on for DTS-HD-MA on the AVR took some time, as I had to tick the option "Use DTS-HD Framing for all DTS types" at the 'Audio Settings' tab of LAV.
I must admit that without LAV Audio Decoder, no DTS-HD-MA could be achieved on my AVR. Again, I am thankful for your guidance here.
As you can see on the screenshot, the filter "AMD HDMI Output" 's Pin[IN] reads 'Audio Input pin (rendered)', does 'rendered' refer to your assumption that the audio stream is being decoded, even though the proper light (DTS, Dolby Digital etc.) turns on at the AVR's end ?
post #3696 of 3895
No, that was just a possible cause, but it was a filter problem after all. Nice that you finally nailed it.
post #3697 of 3895
Thanks again Tulli - much appreciated =)
In order to be able to view 3D content, should I use the EDID override file "Samsung 3DTV + ONKYO HT-R548.inf" ? As my Onkyo HT-RC560 receiver is a 7.2 channel AVR.
post #3698 of 3895
If the Onkyo is not 3D capable you'll lose HD audio. Your best option would be two separate connections. And as 5xxx AMD cards can only have one active audio stream the Onkyo monitor must be primary (see 1st. post).
post #3699 of 3895
This Onkyo is 3D/4K passthrough capable. What would you recommend other than going through the 2 separate connections path?
post #3700 of 3895
No need of an EDID override then (nor separate connections).
post #3701 of 3895
denonavrx1000-lg50pk350.zip 2k .zip file
hi,
i bought an denon avr-x1000 a month ago.
when i try to play dts-hd ma i get no sound.
i think the lg tv is the problem.  when i connect an other tv the denon can play dts-hd without a problem.
so i think there is an handshake problem.
i played with meminfo but could not solved the problem (i think i doing something wrong)
can someone make a good edid for me please.
greetz
vincent
post #3702 of 3895
The audio descriptors of the LG and Denon AVR are identical. This means that the DENON is incorrectly set to passthrough the TV audio. You need therefore to the set HDMI on the DENON to non-passthrough of TV audio (in my old DENON I set it to "AMP").
post #3703 of 3895
tx Tulli,
I did what you said but i don t get dts hd with the lg tv  with my small hp monitor the denon plays perfect dts hd
I think i did something wrong with the previous edid from the avr can you please have an other look at this edid's.
sorry for my bad english.
greetz
vincent
lg50pk350.zip 1k .zip file
denonavrx1000.zip 1k .zip file
post #3704 of 3895
Can you please check the supported formats listed for the HDMI audio device (post the print screen if you like - of course connect the TV through the DENON)? All audio formats should be listed. If 2 channels and only Dolby Digital is listed there's a problem with the DENON HDMI setup. An EDID override won't help in this case.
post #3705 of 3895
I tested also different startups   when i first start up the htpc then the denon avr and then the lg tv sometimes i get dts-hd listed but not always.
the connection is tv => denon => htpc
not all audio formats are listed with the lg tv.
when i put the denon + htpc on my hp monitor all formats are listed.and playing.
post #3706 of 3895
That's odd. Only DD+ showing up usually means a resolution problem (non-standard HDTV, thus HD audio gets disabled). Anyway see if the EDID override helps:
LG50pk350DENONAVRX1000.zip 1k .zip file
post #3707 of 3895
I did the edid override and still only dolby digital, dolby digital plus, dts is showing
I hope you got an other sollution to test that maybe will solve tthe problem.
if it is a resolution prolem is there a sollution for?
thanks for all the help.
greetz
vincent
post #3708 of 3895
(Assuming of course that resolution of the LG is HDTV standard - 1080p/i or 720p) I would suggest swapping HDMI cables or connecting to a different HDMI port on the DENON. If it still doesn't work use separate connections with a DVI-HDMI adapter (if AMD it must be propietary or make sure to connect the HDMI port to the AVR). If the graphic adapter is AMD you might need to set the AVR monitor as primary to get sound.
post #3709 of 3895
Hi Tulli,
I have a Win7 x64 running an ATI 5770 to an Onkyo 1010. A while after I turn off the TV and receiver the ATI loses handshake and a box will show up saying a HDMI-to-DVI connector is connected, or something like that. From this point on I'm only able to output stereo from the PC.
A reboot brings back bitstreaming and everything is fine, until again, I turn off the TV and receiver.
I tried a ton of different ATI drivers, tried removing catalyst HDMI audio driver and replacing it with the realtek hdmi driver to no avail.
I also have auto detection disabled in catalyst control panel.
Is there anything that can be done?
post #3710 of 3895
post #3711 of 3895
Gotcha. Do you know if this is an issue with Nvidia or Intel as well? or this is by-design regardless of the card?
post #3712 of 3895
It's a general issue with the HDMI interface.
post #3713 of 3895
Everyone, I think we have a solid solution in our hands.
I'd like to thank Ryan for his tip here!
This is my situation:
Win7 connected via HDMI from an ATI 5770 to an Onkyo 1010 AVR to the TV. As soon as I turn off the AVR and TV (HTPC running 24/7), I'd lose bitstreaming, Windows will revert to 2.0, and there was no way to change that. Only thing that would help was a reboot, so every time we wanted to watch a movie, or I wanted to listen to multi-channel FLAC via WinAMP I had to reboot the machine.
Ryan suggested I try applying the monitor driver trick in post #12, and that seems to resolve the issue. Right now I'm at work and HTPC is running with AVR and TV turned off, Windows still shows all audio formats supported by the AVR as well as allow 2, 4, 6, or 8 channels LPCM through the Windows mixer.
When I get home tonight I'll pop in a movie w/o rebooting and see if bitstreaming works.
I've removed the Realtek ATI HDMI Audio driver which people said solves the audio issue (it never did help), and now i'm running the original ATI HDMI Audio driver from Catalyst 13.11 beta.
EDIT: Regarding the resolution/icons issues, I've never experienced these, it was always just the audio getting messed up.
post #3714 of 3895
That could work (to apply the EDID Override to the GenericPnP monitor driver automatically generated by windows due to HDMI hotplug detection - when switching - giving 2 channel audio). I used to suggest this trick before but didn't work in every case.
post #3715 of 3895
Hey Tulli, I was the one who suggested this method to him. I researched a little bit and thought to myself that it might be any easy shortcut to actually editing EDIDs. Tried it out a couple of days ago on my setup (Sony TV, Marantz receiver, & AMD 7XXX) and it worked like a charm. Stumbled upon Shpitz's post (who sounded like he was having very similar struggles to mine) so I suggested this method to him. If I had to guess (and it really is a guess) as to why this works for some systems and not others is possibly the components need to be somewhat newish (possibly HDMI 1.4). There seems to be a lot of 2-way communication going on between components such as ARC, HDMI control, HDMI passthrough, and all the HDCP crap. I believe the #1 culprit for me was HDMI passthrough with my setup (wish there was a way to defeat that feature) but that doesn't matter now as the issue seems to be fixed.
I do have a question for you while I have you're attention since you seem to be very active in this thread (great job BTW). Is it me or does "Sony" seem to be the most mentioned problem child in these EDID threads? I see some other brands mentioned here and there but there seems to be a hell of a lot of people with Sony issues (especially displays). Do they not play nicely with others?
post #3716 of 3895
The key problem has really been EDID parsing by the drivers, and particularly by AMD. For instance AMD has not fixed yet their problem with detection of HD audio capability with EDIDs with only a 6-LPCM descriptor (5.1 only AVRs). OTOH Sony AVRs do usually have (not sure if they still do) a weird encoding of the audio block (2 audio descriptors, one for plain audio, and one for HD audio) that could affect EDID parsing. Then I've seen problems like with Samsung AVRs where no HD audio descriptors are present in the EDID even when the AVRs are HD audio capable. Other problems - as with projectors - is bad EDID merging by the AVR that has to be fixed with an EDID override.
Now this particular problem with HDMI hotplug detection of HD audio happens in general (AMD, Nvidia or Intel), maybe because its really due to the WIndows OS itself. But perhaps with latest drivers it can always be fixed by applying the EDID override to the wrong GenericPnP EDID generated by WIndows.
For future reference I'll add a note to the first post with a reference to your posted solution.
Edited by Tulli - 12/6/13 at 3:06am
post #3717 of 3895
Hi sorry im back again 2 years later. Still trying to get DTS-HD Master Audio... I have updated my graphics card to a AMD Radeon HD 6550D And I have a LG 47LK450 monitor and using a Samsung HT D5300 bluray/5.1 surround sound. Last time I tried EDID override it did the override but i never got the 6 channel AC-3 and DTS working... The .inf file i have running right now showed both of those in Moninfo but when loaded the file and rebooted it only gave me 2-channel LPCM. Do you have another File suggestion or maybe a custom one for my Monitor? The onnly way I get sound through the blue ray player is if i have HDMI from the PC to the TV then Optical to the 5.1 receiver. I know that you cant get DTS hd master audio through optical, so what is my best option for the best sound with my set up?
Edited by Jadon Veldman - 12/7/13 at 10:46am
post #3718 of 3895
MY EDID:
Monitor
Model name............... LG TV
Manufacturer............. LGE
Plug and Play ID......... GSM0001
Serial number............ n/a
Manufacture date......... 2011, ISO week 1
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 160 x 90 mm (7.2 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 31-82kHz
Vertical scan range...... 57-63Hz
Video bandwidth.......... 160MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1280 x 1024p at 60Hz - VESA STD
1024 x 768p at 60Hz - VESA STD
800 x 600p at 60Hz - VESA STD
640 x 480p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1096 1116 1125 +hsync +vsync
Detailed timing #2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #3....... 1280x720p at 60Hz (16:9)
Detailed timing #4....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #5....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 138.620 1920 1968 2000 2080 1080 1082 1087 1111 +hsync -vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
CE colorimetry data
xvYCC709 support......... Yes
xvYCC601 support......... Yes
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
Metadata profile flags... 0x01
Report information
Date generated........... 12/7/2013
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0031
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,1E,6D,01,00,01,01,01,01,01,15,01,03,80,10,09,78,0A,EE,91,A3,54,4C,99,26,
0F,50,54,A1,08,00,81,80,61,40,45,40,31,40,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,A0,5A,00,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,A0,5A,00,00,00,1E,00,00,00,FD,00,39,
3F,1F,52,10,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4C,47,20,54,56,0A,20,20,20,20,20,20,20,01,03,
02,03,1C,F1,47,10,22,20,05,84,03,02,23,09,07,07,67,03,0C,00,10,00,B8,2D,E3,05,03,01,02,3A,80,18,
71,38,2D,40,58,2C,04,05,A0,5A,00,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,A0,5A,00,00,00,9E,
01,1D,00,72,51,D0,1E,20,6E,28,55,00,A0,5A,00,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,A0,5A,
00,00,00,18,26,36,80,A0,70,38,1F,40,30,20,25,00,A0,5A,00,00,00,1A,00,00,00,00,00,00,00,00,00,CC
post #3719 of 3895
Then under my Blueray settings for audio i have the options for HDMI Audio: On/Off AudioReturnChanel: Auto/Off Digitial Output: PCM/Bitstream (unprocessed)/Bitstream (Re-encoded DTS)/Bitstream(re encoded Dolby D)
confused.gif So confused on the the proper set up...
post #3720 of 3895
Can you please post the native EDID of the Samsung HTD5300? Most probably HD audio is only possible with the built-in blu-ray player, whereas the HDMI-In has only S/PDIF bandwidth.
An EDID override will be necessary anyway for passthrough of compressed multichanel audio (plain DD or DTS). Note also that 2 channels means "2 LPCM", which is the max bandwitdth with S/PDIF. If you already have a modded monitor driver for your setup install it and check that DD (or DTS) is listed as a supported format. Then set your video player to NON-decode mode (direct passthrough) and it will work. IGNORE the 2 channels detection by Windows.
