AVS › AVS Forum › Video Components › Home Theater Computers › EDID Overrides to solve bitstreaming issues for ATI 5xxx's
EDID Overrides to solve bitstreaming issues for ATI 5xxx's - Page 21
post #601 of 3568
Originally Posted by Tulli View Post
The bitstreaming issue with ATI 5xxxs cards is due to a FAULTY value in the EDIDs of DENON, SONY, and some ONKYO AVRs/AVPs, which sets 192kz as UNSUPPORTED for TrueHD, and sometimes even for DTS HD
Hi Tulli,
I haven't been checking this thread regularly, so I've only just noticed that you've found the root cause of the issue.
One thing that still confuses me - if the AVR EDID causes the issue, does that mean that a standalone Blu-Ray player will have the same problems bitstreaming TrueHD?
post #602 of 3568
Originally Posted by cbemoore View Post
Hi Tulli,
No, standalones are fine AFAIK. My guess is that they simply ignore these EDID specs. Otherwise DENON and SONY would have already addressed the issue (ONKYO has in fact). It's definitely surprising to see that latest DENON models still exhibit the problem.
post #603 of 3568
I saw earlier in this thread that the EDID was OK on the 3007 someone sent in, so I doubt this is my problem, but thought I'd see if anyone has some thoughts.
I just purchased a Gigabyte ATI 5450 card and installed in my HTPC.
My PC sees the HDMI, as I can set it as default, and TMT sees it too. As well, the drivers sees the Onkyo because the display in the Catalyst drivers page says: 1. ATI Radeon HD 5450 (TX-NR3007 + DDC Display]
But on the Onkyo, when I try to select HDMI for the Audio in setup, it does not show, so I cannot select it.
I will be posting this in teh Onkyo thread, as well as the 5xxxx thread. Hopefully someone will have some ideas.
Thanks for any advice you can offer
post #604 of 3568
Hi Tulli,
please help me check the EDID.
TRUE HD AND DTS-MS cant work by ATI 5450.
TV:TH-P46G10W
AMP:integra40.1
thank you.
Paul
TH-P46G10W_INTEGRA40.1.zip 2.302734375k . file
post #605 of 3568
Originally Posted by ppaulxp123 View Post
Hi Tulli,
TV:TH-P46G10W
AMP:integra40.1
thank you.
Paul
The Integra40.1 EDID is fine. DTS-HD & TrueHD descriptors have no flaws.
post #606 of 3568
Hi Tulli,
I've just done some re-testing, and my Onkyo TX-SR607 works perfectly without an EDID override. So feel free to add that to the list of working receivers.
The 607 firmware is also shared by the 507 and 577, so I assume these will work fine too.
You previously created an EDID override for me (thanks!) but my audio problems must have been related to ffdshow configuration, rather than EDID. Do you want to remove the Onkyo 607 EDID from your database to avoid any confusion?
post #607 of 3568
Thanks, will do that right now ...
post #608 of 3568
Hi Tulli.
I have a TV Sony 40W5500 and Receiver Denon AVR2309. I've attached the 2 inf files.
I'd greatly appreciate it if you could do the EDID mod for me. Many thanks.
Denon_Sony.zip 2.3095703125k . file
post #609 of 3568
Hi!
I have problems for bit-streaming hd audios...and in the arc soft forums they told me to come here....I' ve tried one edid from the 1st page(the one for onkyo+panasonic)...but it says that is not compatible with the OS...my av recevier is an Onkyo 507 and the tv is a Panasonic p42s10...As is said...the windows 7 32 bits, says that the .inf is not compatible with the system...
I don't know if it's a problem of the edid or what...I'm trying those thing with the tmt 3.0.170...
if it helps..i cannot bitstream any Hd audio..it crashes when change to those audios...
Could someone help me?
post #610 of 3568
Originally Posted by ksm6 View Post
Hi Tulli.
Here's your mod ...
Sony KDL-40W5500 - DENON2309.zip 1.208984375k . file
post #611 of 3568
Originally Posted by w123123 View Post
Hi!
Sorry but Onkyo 507 does not require an EDID override to bitstream.
Do you have the Realtek driver installed? It doesn't work with TMT3.170.
post #612 of 3568
no...I'm using the ATi Hd audio driver...in the program (tmt3) i can select to bitstream the audio trough hdmi and so...but then...when i choose the hd audio the program crashes down...
if it helps..i have:
-the latest ati drivers (10.2)
-tmt 3.0.170
-ffdshow latest one
-haali media splitter 1.9.355.21
-AC3 filter from augist 2009
the thing is that i remeber using the power dvd, with an original bluray and it works..but power dvd doesn't work with bluray folders...that why i try tmt...so it's a config problem...isn't it?
Maybe trying windvd 2010....
post #613 of 3568
Not sure about TMT3 .170 but yes, PDVD9 bitstreams only with mounted ISO images, if you want to play from hard drive.
Maybe you should ask in both TMT3 and Windvd2010 about bitstreaming support for disk folders.
post #614 of 3568
Tulli,
Thank you very much!
post #615 of 3568
Hey Tulli!
I have a TV Panasonic TH-42PZ80EA and the Receiver Denon AVR2309. I've attached the 2 inf files.
I would be very happy if you could do the EDID mod for me. 1000 thanks!
EDID.zip 2.1484375k . file
post #616 of 3568
Originally Posted by Nephilim55 View Post
Hey Tulli!
Have you already tried the Panasonic TH-42PZ700U - DENON AVR3808 mod on the list? Should work for you. But of course, if you have video issues let me know and I'll do the mod.
post #617 of 3568
Yes I tried that one, but it did not work out on my system. I would be very happy if you could help me.
post #618 of 3568
Without the override you should get DTS HD bitstreaming with no issues. If you can't then problem is with your setup, so that an EDID override won't make any difference.
What is your player and configuration (OS, audio driver)?
post #619 of 3568
I use the MPC-HCE 1.3.1752.0 with Ati Catalyst 10.2 audio driver on Win7 32bit with the ffdshow_rev3299_20100303_xxl. And I only get a stereo bitstream, no HD bitstream. I do not know what is wrong if not the EDID.
post #620 of 3568
Follow dbone1026 MPC-HC setup guide linked in his signature (it's been already posted one or two pages back in this thread). Also, try using Albain's ffdshow builds as they work best for most cases.
On top of that there's the obvious: make sure that the ATI HDMI audio driver is set to 5.1 or 7.1. And make sure that the DENON HDMI is set to "AMP".
post #621 of 3568
I already had everything as you suggested but one thing:
There is another setting in the DENON receiver, I had to set besides HDMI to "AMP", and that is the "2.3.4 Auto Surround Mode" which must be set to "OFF". Only then it works completly.
But now it is working fine with the Panasonic TH-42PZ700U - DENON AVR3808 mod, thank you very very much!
post #622 of 3568
Will add that to the tips for troubleshooting section ... thx.
post #623 of 3568
...But on the Onkyo, when I try to select HDMI for the Audio in setup, it does not show, so I cannot select it.
Never got an answer here, but I did in the Onkyo thread. For anyone interested, HDMI does not show as an option in the Audio setup on the 3007. I had to select ----,and now it plays throught the HDMI.
BUT, I do not get TrueHD Bitstreaming
So, maybe it is not true that the EDID is OK for the 3007.
What I have done in the setups so far:
  • I have set HDMI as default audio device
  • I have tried various settings in the Realtek setup, and currently have it set to 7.1
  • I have TMT set to play HDMI, and use Original Stream
But all I can get on the AVR is DTS, Dolby, or Muti Channel. No TrueHD.
FYI...I do get TrueHD from my Samsung Blue-Ray player.
Any thoughts is appreciated.
post #624 of 3568
If you want me to check, post the 3007 EDID so that to make sure that it's not an EDID issue.
post #625 of 3568
I've downloaded the Moninfo tool and have been reading your instructions at the first page of this thread. I really hate to bother you with this question, but I'm not sure I understand. The first instruction of:
Connect the graphic card HDMI-in to your display device HDMI-out.
implies to me that the graphic card will have an HDMI-in port, which would imply to me that it has 2 HDMI ports: 1 in and 1 out. I have the Gigabyte 5450, and it has 1 HDMI port, OUT.
Then same applies to my display, which by the way, is a SIM2 Link 300 projector. there is 1 HDMI port in it, and it is an HDMI-IN, not out.
So I am confused on how I should hook up to get the readings.
I presume youd do need me to try to get it from the Projector and the Onkyo.
Sorry to bother with what should be basic. I guess my brain just isn't in high gear this morning.
post #626 of 3568
Sorry about the confusion ... I will eliminate the "in" and "out" as they are really irrelevant. Connections should be:
1. ATI <=> Projector (to capture the projector EDID)
2. ATI <=> AVR (to capture the 3007 EDID)
And connection must be digital, o course, i.e. DVI/HDMI.
But you would capture only the 3007 EDID, as current hypothesis is that it really doesn't require to be EDID-overriden to bitstream. If proved to be otherwise after checking then the projector EDID would be required too.
post #627 of 3568
I am using ATI 5450 and HK AVR 2600. MonInfo shows HK supporing 192Khz however, whenever, I play a blu ray movie with DTS HD audio the sound format is down-sampled to regular DTS. I have been reading three different threads and after reading 70% of those, I still cannot find an answer. In powerdvd, I get only two options, pcm decoded by powerdvd or non-decoded pcm. Please review the bin file.
Secondly, I would like to split my hdmi out to both tv and avr. Monoprice splitter is doing exactly that, however, windows sound panel configures speakers to only two channels when signal is split and I get regular dts/DD only. BTW, the first problem has nothing to do with splitter, there, the signal is going directly to avr. I wonder if there is a way to disable jack monitoring so windows sound will always remain as 5.1.
Thanks in advance for any help.
HK AVR2600.zip 0.2958984375k . file
post #628 of 3568
Just checked and the HK 2600 EDID is fine, so no need to mod it to bitstream.
As for the HDMI splitter it is transmitting the TV EDID and thus the 2 channel problem in Windows. You may try an EDID override with the HK 2600 EDID as-is and see if it works.
post #629 of 3568
Tulli, thanks a lot for your reply. After a lot of install/uninstall, I now see that while playing a blu ray, power dvd has a third option that deals with sending uncompressed audio to AVR.
When you say EDID override, you mean creating a .inf file using moninfo and using it as my display driver, right? I have tried that and as soon as pc sees the splitter the windows speaker config changes to stero and no HD audio after that. According to this old thread http://www.avsforum.com/avs-vb/archi...t-1181876.html there is a service by ATI that can be disabled to fix this issue, however, I am not seeing it anywhere. I am going to start disabling all audio related services to see if I can figure it out, unless someone has a better idea.
post #630 of 3568
I'm going to be nitpicky and I apologize up front for it, but, it's sending COMPRESSED audio to the AVR. The reason that I press this distinction is because it's confusing. LPCM = uncompressed, TrueHD/DTS-HD MA = compressed (aka bitstreaming). I know I'm annoying with this and again I do apologize.
