This is an attempt to find out if it is better for certain setups at certain room lighting levels to buy a projector with a higher ON/OFF contrast (typical of LCOS and LCD's with IRIS) or a higher ANSI contrast (typical of DLP's). The tests will be done on the Epson 8500ub, the Mitsubishi hc3800, and the older Sanyo Z5 (720p), all with varying ANSI and varying ON/OFF contrast ratios. This test could actually be done with only (1) projector if we wanted, but we will be using 3 projectors for comparisons to make it more interesting and to possibly make the results more reliable.
Note that the main purpose of this test is not to compare the (3) projectors so much (this is only one of the comparisons I will be doing), but it is to specifically identify how a given contrast number is affected by a given lighting condition, and how this directly relates to the visual perception of the image at these given numbers.
Now please feel free to post any comments on ON/OFF vs ANSI that you may have and DO NOT worry about filling this thread up with general info, because once we get the final testing numbers and have concluded the test was valid, I will then create a new thread just for the numbers themselves....
So let's start the partisan projector and ON/OFF vs ANSI FIGHT!!!
(cough cough I mean friendly debate).
