Originally Posted by
jong1
It means it is "bluescreen"'ing. You probably do not see the bluescreen if it is set to restart afterwards, but there should be something in the event viewer that may or may not give a hint to the problem.
There are many reasons not limited to:
- bad driver installation or faulty driver (try clean installing the latest driver)
- faulty memory
- overclocking memory, GPU or CPU too much
- Just wrong timing in the BIOS for CPU, chipset or memory
- overheating
It
is something to worry about and should not happen.
Thank you.
-Drivers were all installed cleanly and are up-to-date.
-Not sure about memory... or how to check.
-No overclocking, GPU is set to max memory in bios
-Timing... possibly. My board technically only supports 1333 memory, but I installed 1600. I didn't make any bios changes (most settings are defaulted to auto) and it just "worked"
-I don't think overheating is an issue
I opened the event viewer and I had two errors. I have no clue what the second error might be. The first is most likely the culprit since I was in media center and I was using the HDHomerun:
Event 3, ehRecvr
TV tuner encountered an error. (0xc0040524) Silicondust HDHomeRun Tuner 1018D369-1
Event 1000, Application Error
Faulting application name: ehshell.exe, version: 6.1.7600.16385, time stamp: 0x4a5bccdc
Faulting module name: audiokse.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdac9
Exception code: 0xc0000005
Fault offset: 0x00059cfa
Faulting process id: 0x%9
Faulting application start time: 0x%10
Faulting application path: %11
Faulting module path: %12
Report Id: %13
