Originally Posted by jjeff
I've never owned a Harmony but I've read where people can somehow add a IR code that may not be on the current remote for that unit. You don't want to use the 710(DVD only) codes because they won't work with Sony BRs. I have a 700 DVD player which has Eject but none of the buttons overlap with Sony BRs.
You'd want to use the TIME/TEXT code from a older Sony BR remote that had that feature. Any of the x60 or x50 series should work. For example, BDP-S350, BDP-S550, BDP-S360 or BDP-S560. All those models had a remote that included the TIME/TEXT button.
You know I bet if you told your Harmony you had a BDP-S350 or BDP-S550 you'd be all set, since both those remotes has EJECT and TIME/TEXT. From looking at the manuals the only button I noticed they lacked was the TV INPUT button. I'm guessing you don't use that button anyway since you can probably control your TV with other buttons on the Harmony.
It's been my experience that even though Sony omits certain buttons on newer remotes, older remotes(of the same product category) with those buttons can control newer products and enable those functions.
I know my 700 Sony DVD remote will enable all of the features missing on the 710 DVD player remote, I had a 710 for a brief time.
Good luck and let us know how it works!
I created a BDP-350 device on my Harmony and there is a command "TIME" on the database. It has no effect on the S570.
Did any of the other operations work with your S570? eg. PLAY or STOP?
