In an effort to distribute HDMI video from sources in my basement, I've run pairs of Cat6 cable from that central location to each of my bedrooms. Each pair is now at a single or dual gang opening in the wall. My question is, should I terminate the ends with Cat6 keystone jacks and then use RJ45 termiated patch cables to the Balun inputs, or should I terminate the wires with RJ45 for direct connection to the Baluns? Will there be a problem with 1080p distribution if I go with the keystone jacks? I think the result would look much more professional that way, but I don't want to hurt or degrade the video signal quality...
Many thanks...
Many thanks...
