Originally Posted by 42Plasmaman
Appears to be an issue with this player and my Pioneer VSX-1020K receiver.
*I had an Onkyo receiver when IM2 first came out so this sort of explains why it worked with this player in the past.
Just an FYI
When I try to play the Iron Man 2 blu-ray using my Panasonic BD65 player, the disc will reboot when I select play at the Main menu. Resetting my player or using different HDMI input on the receiver did not resolve the issue.
To work around this, all I have to do is turn off the receiver when I'm at the Main menu then select play, wait until it plays about 5 seconds of the movie then turn on the player.
I've had this receiver for over 6 months and this is the only disc that had an issue.
I tried my Panasonic BD35 and it works but the bitstream is detected as DTS only, no HD by the receiver.
Just an FYI
I have the Costco DMP-BD655 version connected to an Denon AVR-791 and have the same issue. Most of the time Iron Man 2 will crash the player as soon as I try to play it from the menu. I've tried turning off 24p, Blu-ray Live with no luck. Here's what I plan to try next:
- Put in a 2GB SD card, turn on Live!
- Try one of the other alternate-language audio tracks
- Double check the FW version in case auto update isn't working for some reason
- I have a Panny AE-4000u projector so need to double check that HDMI-CEC is disabled on both devices
