I've never had problems with this before, and both Vudu and Amazon streaming are fine, but I tried to stream Netflix tonight (first time in about a week), and the aspect ratio was messed up: standard-screen content was window-boxed (small square in the middle of the screen), and widescreen content was squeezed, reaching from left to right but not from top to bottom (so the image was distorted, too wide). All my settings are fine--same as always, "pixel-to-pixel"--and, as I said, Vudu and Amazon, as well as all discs, are perfect. I can make the widescreen movies look correct by hitting "letterbox" on my projector, but that actually makes the standard-screen material distorted, all stretched skinny. Or I can zoom the standard-screen material, but that doesn't fix the distortion of the widescreen material.
I don't want to do either of those fixes, though, because I'll lose resolution. I want the regular anamorphic image that I had been receiving. I called Netflix customer service, but that was a waste: she deactivated and then reactivated me, which did nothing, and then she told me to unplug and replug the HDMI cable into my Blu-ray player. No help.
What in the world happened??
