AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official LG BD550/BD560/BD570/BD590 Owners Thread
Official LG BD550/BD560/BD570/BD590 Owners Thread - Page 53
post #1561 of 6383
AilingRichMan, Yes....Initialize, then select 'Factory Set'. I just grabbed another update and have not had any further problems. My issues stopped once I updated and then did that. I then had to reconfigure all my audio/video/netflix settings...but all has been great since then. Are you running the 590 or the 570?
post #1562 of 6383
Well.. before I take my BD590 back to BB today.. I checked one last time for updates and one was available (sorry I didn't write down the number). After the update, I went ahead and did another factory reset and then tried my standard def movie file I had on the internal hard drive.. now there is a ton of audio static when playing the file after the update and the movie is still very choppy (the water scenes in the beginning of Shutter Island show the issues immediately still...).. so off to BB this morning I go.
I plan to try a replacement unit before I give up and start looking at the WD HD Plus unit or the POPBOX.
post #1563 of 6383
New version is BD.8.31.283.C. Just installed it - too early to tell what it does/fixed but Pandora seems to be better (no audio drops so far on my BD590). Didn't see any new Netcast apps.
post #1564 of 6383
I just don't get why lg does not post what a firmware is fixing.
post #1565 of 6383
I got the BD550 and I'm happy with it so far. I always seem to miss episodes of Persons Unknown and the 550's ability to read mkv files on flash drives is a godsend.
post #1566 of 6383
I could not get the mkv file to play off my flash drive. The player sees photos but when I try to play a movie it just gives me the red "can't do that" symbol in the corner of the screen.
Am I not holding my mouth right or is there a secret handshake?
I think I read somewhere that the 550 does not play video files from usb.
post #1567 of 6383
Hi,
I am trying to play Blu-ray rips (.m2ts files) from my external HDD connected via USB to my BD-570. I select any m2ts file it says "audio format not supported". I could not able to play any of the files.
It successfully played other m2ts files from a different BR rip. Appreciate any ideas why I am getting this error on first BR rip. thanks.
post #1568 of 6383
I have had the BD590 for a while and have had no problems. I am starting to get into ripping my blurays onto my hard drive and streaming them. I have ripped them to MKV but it appears that you cannot stream these to player. Get unsupported video format. What is the best way to stream these files to the BD 590. What are some good programs to convert them. I have tried converting them to divix but even that has given me a problem. Any help or guidance is appreciated
post #1569 of 6383
Anyone watch Cop Out on the 590? At the 4 minute marked it skipped ahead 2 minutes. I replicated the issue three times. Curious if it's just a bad disc or a problem with the player.
post #1570 of 6383
Not that one but had problems with Brooklyn's Finest in blu ray.
post #1571 of 6383
I had issues with Brooklyn's Finest also. Could not get the first one to even load. Sent it back to Netflix and got another one. I didn't think the second one was going to load but after it did it played through to the end.
post #1572 of 6383
Has anyone tried Napster on this player yet?
post #1573 of 6383
I've tried it on the 590 and Napster works great! Better than Pandora in that you can select the songs you want to hear.
post #1574 of 6383
You should be able to stream MKVs with no problem.
What software are you using to rip the Blurays?
post #1575 of 6383
using make Mkv
http://www.makemkv.com/
Any suggestion i will try. Have trial of DVD Fab but had a problem with that too. s
post #1576 of 6383
Thanks for the feedback, I'll trial it soon. Pandora's ok, audio dropouts are quite common (don't think due to my internet connection since it's wired 10 Mb/s download speed).
post #1577 of 6383
My 590 just skipped ahead 3 or so minutes at about the hour mark of The Wolfman. Back to Best Buy it goes; it's too damned expensive to put up with this crap.
post #1578 of 6383
Are you sure it's not a problem with the disk itself? Did you contact LG about it?
post #1579 of 6383
My Sony S570 handled it fine, as did my LG BD390. Honestly, this was a purchase I had been second guessing since I made it, so this makes it a little easier. I'll probably follow up with LG after returning it. But, again, it cost me $350 dollars - I shouldn't have to worry whether this type of thing is going to continue happening, especially after reading the similar incidents in this thread; I shouldn't have to get LG involved.
post #1580 of 6383
New poster here. I just got my 570 today and set it up. Playing netflix and standard DVD just fine.
Tomorrow I'll get Avatar on Blu Ray (netflix) and report in on how it goes. A whole lot of complaints here which scares me. I did not update the firmware. Sin City DVD looked (and SOUNDED!!!) fantastic.
I set the player to output 192 kHz but does that only work on Blu Ray? My Denon 591 accepts it as an input. Sin City sounded great, whatever was going on.
post #1581 of 6383
Bought my self pioneer elite 31 fd new release at best buy for $319, plus $100 off coupon with speaker bstall consult! Hadios LG
post #1582 of 6383
Looking to get a 570 as a bedroom player. Amazon has it for $178 (no tax, free ship) currently, is that a good deal? Is it worth it to hold out for a better price?
Also, is it a better deal to get a 550 for $135 + a wireless AP for $30? I see the 550 doesnt have homelink or DivX though. How solid is the integrated wifi in the 570?
I was ready to purchase the 570 until I read some of the recently posted negative reviews for it on Amazon. Stuff about disc skipping, random shutdown, audio cutouts and speedups, etc. So I came here to read up on it and though there seemed to be less complaints ratio-wise, there are still similar complaints period. So now I'm a bit hesitant. At the same time, I dont really know of another BD player with Netlfix, Pandora, Home network streaming, and DivX for under $199.
A little guidance, help, suggestion, comfort, etc would be most appreciated.
post #1583 of 6383
I've had it for a week and have used it every day. Used netflix, dvd-r and bluray with no skipping. I bought it for 185, so yeh, go for it now before it goes back up. Remember, if you have any issues with it, you can always return it.
post #1584 of 6383
I bought a 570 recently and it hasn't given me any real problems. However, I'm a fairly light user (playing disks once a week, Netflix instant watching once a week) and I have it connected to ethernet by wire. Homelink plays nicely with my Windows Home Server. Worst problem I had was a Netflix disk that skipped, but after looking at the surface of it, I could readily see why. I would say that the price you quoted was a good one.
post #1585 of 6383
Did I choose the best A/V settings for the 570?
192 kHz, 16:9 original, the HDMI pass through options, No sound compression
I want my Denon 591 to do all the work.
post #1586 of 6383
That is the way I have mine configured. Don't know if it is perfect or not.
Also have a 591
post #1587 of 6383
Also have a 591
Do you have yours on 1080p 24hz or 60 hz? I have a 1080p TV but don't know which setting I should use, and which source they're supposed to be used on.
post #1588 of 6383
Originally Posted by ambizytl View Post
You use 24HZ with a source that provides that, such as Blu-ray movies and other content recorded at 24p. I leave it at 24Hz and it automatically switches--you only get 24 Hz when source is 24Hz.
This is from another post in this thread.
post #1589 of 6383
Sweet, thanks!
post #1590 of 6383
picked up a BD570 and did the software update. When I pause a blu ray movie for more than a minute or so it will not resume play when I push play. The only way to get the movie to play again is to go pack to the previous scene. Have not tried a standard DVD yet, only blu ray.
anyone with similar issues?
