Originally Posted by
Bob K.
Search for DTS-MA in this thread. Your problem and a solution lie a few pages back. You can also MediaInfo (post #2801) to read and post the file attributes here for us to look at.
I looked back and couldn't find any answers. If you know the solution, please just let me know, I might be missing something.
The DTS-Ma issues I read about in this thread had to do with header compression. As far as I know MakeMKV does no compression at all. I also tried BluRip with and without header compression and have the same problem: not bad sound or ticking or distortion, just an audio code error message.
I also am getting the same error with my BDs I tried to covert that are Dolby TrueHD encoded and standard dolby. I have played many downloaded compressed mkvs under 8 gig that are DTS-MA/Dolby TrueHD and they play fine in their native audio format on the LG. That is why I am wondering if it might be something to do with file size, not using compression, or trying to stream a file that is 15 gig + over the network.
Anyway, I am copying the file to the LG overnight and will see if it plays off the unit's hard drive in the morning.
Here is a dts-ma file I can't play I encoded:
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA
Codec ID : A_DTS
Duration : 1h 55mn
Bit rate mode : Variable
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Title : Losless
Language : English
Here is a dolby true Hd I get the same audio error code:
Audio
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 1h 40mn
Maximum bit rate : 4 293 Kbps
Compression mode : Lossless
Here is a smaller compressed MKV with DTS that plays
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1h 56mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Bit depth : 16 bits
Stream size : 1.23 GiB (22%)
Title : English
Language : English
