Originally Posted by Sabrewulf...
BD550 here and VUDU HDX works just fine, starts a full bar stream in seconds, with no buffering. Have a mostly 25Mb connection, your 15Mb should be more than enough if that's what your getting. Do a speed test? http://www.speedtest.net/ Maybe some network issues? I would defiantly update the firmware asap, should give you 1 or 2 more netcast channels, DviX TV and maybe Youtube? Not sure when that came out, as well as BD compatibility updates.
I have run a speedtest (speakeasy0 a few times and have never seen it drop below 12mb while running the test and it always averages out at about 15mb.
My home network is completely gigabit. I have a gigabit router, network switch and everything is hardwired on cat6
Obviously I need to try and update the firmware, which in all honestly should have been the first thing that I did. Problem is that every time I am using the player, it is to watch a movie or netflix with my wife and the last thing I want to do is start updating firmware only to have a problem. The wife rarely understands or appreciates technology issues.
Originally Posted by jaugustu
I'm not sure how Vudu's content is distributed, but you might try changing your DNS to 4.2.2.1/4.2.2.2, which will automatically use the nearest Level3 DNS servers. Those, in turn, should route you to the nearest Vudu server, assuming they have multiple locations. If they don't, well, that might be the problem right there.
I assume that this is a setting in the menu. I will give this a try too.
