AVS › AVS Forum › Video Components › Home Theater Computers › Blu-Ray Ripping and Storage Long Term Strategy
Blu-Ray Ripping and Storage Long Term Strategy - Page 3
post #61 of 175
Originally Posted by MikeEby View Post
Some Blu-ray movies also are authored with seamless branching. They will include a director's cut and a theatrical version. When I convert to an MKV I create theatrical version. This is the rare case where an ISO is smaller than two versions of the same movie.
I've also seen a few movies that had credits or opening titles in foreign language. This is also done with seamless branching; in this case the MKV could be significantly smaller than an ISO.
One more variation is a disk that contains a 3D version and a 2D version on the same disk. In this case I only rip the 2D version, and it is about ½ the size of the original ISO.
Mike
This is one of reasons I wish to preserve the ISO. I wish to preserve seamless branching and other albeit sometimes annoying features of the original disc. But the difficulty of getting it all working makes me wonder if I should go with MKV sometimes. But I will not give up so easily.
MKV playback seems like a simple more compatible solution. I don't usually even watch the special features.
post #62 of 175
Can you watch the ISO from your HTPC if it's stored on a 2008R2 server? I'm assuming it shouldn't be a problem but not sure which pc should mount the iso
post #63 of 175
Originally Posted by sxr71 View Post
At first with Daemontools it would launch the PowerDVD 9 interface within WMC. Now it launches in its own window and I'm struggling to get it back to the behavior of the Cyberlink PowerDVD plug-in that I have in WMC. If I could get that part taken care I would be a happy camper. It's very hard finding information on that.
Now that, is simple to fix.
Its not Daemon Tools, its Windows.
PowerDVD sets itself as the default player for DVD and BD, so every time Windows sees a BD it will launch PDVD.
Go to Start Menu => Default Programs => Change Auto Play settings. Reset all defaults => Save
After that, go back in and Select "Take No Action" for BD, DVD etc. depending on your personal preference.
Next step is important too:
Start Menu => type 'msconfig' in search box and click it.
Select the 'Startup' tab and list all items according to Manufacturer. Uncheck all boxes belonging to Cyberlink; there should be 3 processes: brs.exe, PDVDserv and one more I can't recall.
This will stop Windows from launching PDVD everytime.
post #64 of 175
Originally Posted by ilovejedd View Post
@sxr71
I don't think I've actually addressed your original questions so here goes:
I rip Blu-rays to ISO format with the original encryption and just install AnyDVD HD on all computers that are tasked with Blu-ray playback for on-the-fly decryption. Why? Earlier versions of AnyDVD HD failed to properly decrypt Blu-ray discs with new protection schemes requiring you to re-rip when an update is released - a not very pleasant task considering current Blu-ray drive speeds (or lack thereof). Keeping the encryption intact makes the ISO as good as the original disc (at least where AnyDVD HD is concerned) so even if you encounter a disc that AnyDVD HD can't currently handle, you won't have to re-rip.
Since you're effectively storing "originals", it's easy to re-convert/transcode to formats compatible with the PS3, Xbox 360 or whatever network player you might choose. Another reason I have my stuff as 1:1 ISO is because I still can't decide what format is best to keep them in - cleaned-up ISO (using ClownBD), BDMV folders, MKV, MP4, M2TS?
I thought I should just mention I tried the Popcorn Hour-as-extender route since I thought an HTPC in the living room and "dumb" boxes in the other rooms would suffice. While the PCH's worked well enough, I found myself missing features that were available on the HTPC. In the end, I built some ION-based machines to work as "extenders". Well, since I'm using Windows 7, they're not exactly extenders but standalone HTPC's in their own right. A lot underpowered, though. With faster hardware becoming available in smaller form factors and with very low power envelopes (in particular H55/H57+Clarkdale and GF9300+Wolfdale for Mini-ITX), you might want to consider building low-end/budget HTPC's for your other rooms, too.
Yes, I'm thinking exactly the way you are. The promise of $100 extenders is tempting but I know it will ultimately limit me. Also I like building computers it's fun to do and they can always be upgraded as one wishes.
I have been using DVDFab but I think it only can decrypt while ripping and doesn't do it in the background like AnyDVD HD. Its lower price is tempting, but if it means no need to re-rip in the future then the extra $20 is not an issue.
I've been noticing that my supposedly 8x Blu-Ray drive barely rips at 7-14MBps or 56-108Mbps. Which is 1.5-3x. I rarely hit the higher end of that.
MS intentionally crippled the capabilities of WMC extenders so if I like the WMC interface I am stuck predominantly with the Xbox 360 which is crippled.
Otherwise I need to suffer with the amateur interfaces of some of the $100 player and their unique limitations.
An HTPC grows as new software is released. But boy can they be a pain to configure. HTPC capable of Blu-Ray playback are getting cheaper right down to the Atom/ION solution. They will only get smaller and cheaper. In about 2 years I anticipate mobile phones with micro HDMI out fully capable of playing Blu-Ray files. It might even be sooner.
Technology is moving forward so fast and to me that was the reason despite having a dislike for Sony I absolutely could not support the half-assed format of HD-DVD. People were crying about the cost of Blu-Ray and now the players are $99. If anything people don't know that first DVD players were far more expensive than the first Blu-Ray players. The DVP-S7000 was $1299. The PS3 was $599. Inflation adjusted, it was obvious that Blu-Ray was plenty cheap enough for a new format at launch. A format we will have to live with for 8-10 years.
I don't for the life of me understand how technically inclined people don't see that high cost is a temporary thing. You have to live with your format decisions for many years.
post #65 of 175
Hirent and Justin0424:
Thanks. Autoplay is the most annoying feature on earth. Since its inception it has served to annoy me.
It has a habit of re-enabling itself periodically.
post #66 of 175
Seamless branching works perfect with MKVs if they are done correctly. You just need to decide which version of the movie you want or if you want both it will cost some disk space.
Here is an example with the Eac3to GUI I wrote. Notice the two playlists in the Results box. Playlist #1 is 2 hours 26 Minutes, that is the directors cut. #2 is the theatical version. In this example I have selected the theatical version, I just then press the "Add Batch" button then "Run Batch" button and in about an hour you have an MKV ripped to your drive, ready to watch, complete with forced subtitles. Also note in this example I have the movie copied to the hard drive. This is not required...Your can rip directly off the disk as long as AnyDVD-HD is running in the tray.
Now if you want the other version of the movie you must select the playlist #1 and add it to the batch, then run the batches. Note movies like this are somewhat rare. I usually keep only one version of the movie.
Mike
post #67 of 175
Naa....it only does that when there's a change in the system.
For instance; a reinstall, or a patch or an update (not Windows update, PDVD update).
I've noticed every time there's an update it will reset all the settings, so you have to go back in there to reset it all over again.
Not Windows' fault, its PowerDVD. Almost all players/software allow you to select file association; Cyberlink just takes over as the alpha dog.
post #68 of 175
Mike
That's good to know. I am comfortable with my PowerDVD9/ISO/DaemonTools solutions for now. But I will look into MKV so I use use other playback solutions. It would be nice to just use Boxee or XMBC.
post #69 of 175
I hear you. But I think Windows needs to have mechanisms that inform users before changes are made to Autoplay and a "lock mode" which prevents applications from changing settings like that.
MS does annoy me still. They have created the Xbox 360, they make some great keyboards and mouses but for all this WMC hoopla not one person over there has thought about the lack of proper WMC remote controls. They have ZERO concept of making a solution workable in a easy way for consumers. Everything needs a hodge-podge of hacks to work in an acceptable way in a domestic situation.
I guess the upside is the good feeling when you manage to get everything to work.
post #70 of 175
Huh??? My MCE remote works great with zero mods...I haven't touched a keyboard or mouse running WMC in months.
Edit: I take that back...I did have to map a new share to MediaBrowser about 3 weeks ago when I added a new drive to the media server. But that wasn't in WMC, I was at the Windows Desktop then.
Mike
post #71 of 175
Originally Posted by theshadow1234 View Post
Man you guys are using way to much space for a Blu-ray ripping and storage. Blus can be converted easily to a 8-12GB 1080p mkv without video or audio loss. Take away the special features and menus and save yourselves some space. Use h264 for video and extract the primary audio streams to mkv. So far i've converted 10 out 150 Blu-rays out my collection and the results are the same or even better as the original disk. The difference is not noticable by the normal 20/20 human eye . I currently have 110" carada Screen with a Epson 1080UB projector for testing this kind of stuff and it all looks and sounds the same.
Even better than the original disk? LOL. Better get your eyes checked because I absolutely notice artifacts like macro blocking in fast sequences if watching an 8 or 9 gig x264 transcoded from a 25 or 35 gig source. In this day of $140 2Tb drives I don't see a reason to take an already highly compressed source and re-render down to 25 or 30% of original size. Add to that storage only gets cheaper with time, and display technology is only going to improve with time, so subtle details that you don't notice now after they're quantized and tossed aside will become more noticeable on displays in the future- black will only get blacker, colors will only become more vibrant and scan rates will only continue to increase. The uncompressed HD audio tracks are also noticably superior to the compressed DD/DTS 5.1 counterparts when you A/B them on a competent audio system.
For a lot of us, HT and a Bluray source is about watching a movie and knowing we're seeing it with the best picture and sound possible. And for others it's apparently about how many titles you can fit onto a harddisk, in which case knock yourself out. I'll agree that ripping main movie + a couple audio tracks and tossing all the menus is worthwhile, but re-rendering an already tightly compressed H.264 source is where I draw the line.
Again 1080p blu-ray to 1080p mkv = no loss and small file size depending on the tools used and the preferences set by the person encoding.
QFT.
post #72 of 175
QFT.
And for a bigger bunch of us it is about watching the movie and not looking up a stats sheet. It is up to each one of us to judge what is acceptable quality wise, not some internet expert opinion.
And, yes funny as it sound sometime recompressing and bringing down the resolution does improve the original source if that source was so grainy as to be a distraction. Those defect are lost during the recompress. I have quite a few movies that look better, to my eyes remember, after processing then before.
Also, in many case 1080p FullHD is a waste for some movie. Talkies and chickflix for exemple. It's up to each one of us to decide what you want to keep on your server.
BTW you seem to forget that we still have the original disk if we really want to see it in all its glory. Unless of course you are one of those you rents and rip... But a nice perfectionist fellow like you wouldn't really do that wouldn't you?
But on a server, space and conviviality trumps optimal quality in my humble opinion. Maybe you would be best served with a 400 disk player instead of a server.
post #73 of 175
Mike
Yes. I picked one up at Microcenter yesterday. It's great. But it's not backlit. The MS models are not easily available and the ones they put out years ago for MCE 2005 are dated and ugly. Contrast those with the beautiful products here: http://www.microsoft.com/hardware/mo...d/default.mspx
There should be at least one WMC remote option in there is what I meant. It should have been launched along with Win 7. Even better would be a Win 7 Home Premium + WMC Remote Bundle. That's what I mean about MS not being consumer friendly.
Sell us the package. I'm starting to look at the overpriced Logitech remotes at this point. Overpriced since MS does not compete in the remote arena. Which is what they should be doing if they want their WMC platform to be a complete solution.
post #74 of 175
What difference does it make if the 400 discs on in a 400 disc player or a NAS/WHS?
That's right. The WHS/NAS allows you to watch from any room and gives you faster access and customizable browsing.
You may choose to degrade your $35 Blu-Rays. But you can start your own thread for that. This thread was not entitled "The Short Term Savings Thread". Or "The Transcoding as Film Grain Removal Thread".
It's like arguing that you prefer to convert your WAV or FLAC files to MP3 because YOU believe that recording engineers mix their recordings too brightly. If so there's something called EQ.
post #75 of 175
Here is the keyboard/remote-mouse combo I have. It is backlit, and has a gyro mouse built in to the remote, kind of like a Wii Controller. Keyboard is decent too.
http://www.amazon.com/Gyration-GYR41...7404055&sr=8-4
post #76 of 175
This thread is about the best way to store a huge amount of video on a server. Like it or not recompressing is one of those way.
Now you can take your elitist attitude and shove it where the sun don't shine for all I care. And as being off topic so is you analogy to audio files.
BTW I don't "degrade" anything since I still have the original pristine disk. But a server is about convenience. Are you telling me you have a 60" top of the line led lcd or plasma in every room of your house? How is that 1080p uncompress feed on your bedroom 37" or less from 12 feet away? Did does your 7 years old son write a 100 pages dissertation on the merit of 1080p on is 19" LCD in is room?
Come on. You are blindly critisising without having really seen a good recode. BTW how are your eyes? In what field do you work.? You know some trades are hard on the eyes and as you get older your sight is getting less than perfect.
Oh and about the grain, the recording engineer, producers etc, etc, intention and artistic meaning... You know what, I don't care! I'm the one paying the 35$ not they. 99.9% of movies ever made will never end up in a museum as a piece of art. Those are ephemeral entertainment for the most part not religious icons. You aren't desecrating anything by riping, rencoding, cleaning anymore than you do when playing with the control on your TV to adjust the picture to your taste.
Gime a break...
post #77 of 175
I've thought about that option. I think it's what I'll try next. Nice small keyboard and much more reasonably priced than Logitech products.
post #78 of 175
Gime a break...
Didn't I ask you to start your own thread? I posted the original post and if the language wasn't clear to you then let me clarify again. I meant "long-term" strategy. Again the implication being that storage is already dirt cheap and getting cheaper. The implication also being that 2 years down the road when 4TB drives are $100 I don't want to have regrets about having a server full of degraded Blu-Rays that makes me need to go right back to square one: putting the disc in the player each time I want to watch a movie.
If in the next month I wish to run a 1080p projector and sit 8 feet away from a 135" image I could do so without having to re-rip my whole collection since my server is full of transcoded degraded Blu-Ray movies. If next year or 2 years from now I get a home that lets me do that in 2 rooms I could so without regretting having made a short sighted decision.
You may only be able to afford a 19" screen or you find that $150 for 2TB is unaffordable to store 70 movie, which is where I suspect the anger is coming from. I wonder how you afford $35 a Blu-Ray. For YOU then your solution is acceptable. But I didn't ask for a solution for you. I asked for a solution for me. This is getting to be like that fox who lost his tail in a trap asking the others to cut off their tails story. Straight from Aesop.
Please start your own debate thread and leave this one alone. I said in the OP that there is no be no degradation in the solution. Please respect that and leave this thread alone.
Also my profession and my eyesight is beyond the scope of this thread. Any elitism is your perception. I just don't want to degrade a $35 product to save $1 in storage costs. That's just rational. Respect that and start your own thread.
post #79 of 175
Again with the elitism... Sorry "friend" but #1 you post on this forum asking for solutions to your problem. I took the time to give you mine. You don't like it that is your right. What you don't have the right though is to tell me where I should post just because you don't like my solution.
BTW I can bloody well afford a 1080p projector and a 135" screen. I just spent 15,000$ to redo my HT room this week, $5200 on a Sony KDL60NX800 to replace my busted PJ and 106" screen. So yeah I can buy a 1080p PJ and a 135" screen if I want even though I'm not in a liberal profession.
Now understand me well, it is YOUR RIGHT to rip to ISO if you want to. But don't come riding on your high horses because other have a different point of view or better yet next time write a better title to your damn thread.
post #80 of 175
Cool it guys...
post #81 of 175
To the OP,
I strictly use AnyDVD to create 1-for-1 .iso's of blu-rays, keeping the protection intact. As far as I can determine, this is the most future-proof backup possible. I.e, Slysoft even recommends leaving the protection in place. Besides, I can ALWAYS readily encode, etc in the future if I wanted to since I'll already have a "perfect" copy of the disc online.
I have 1 HTPC up and running smoothly, and am now going to take my separate ripping PC and build a server around those components I already have. This will let me then put other, small, cheap HTPC's around the house to pull movies to those other TV's as well. This is easy as pie using MediaBrowser to create "virtual libraries" from multiple shared drives. This future proofs me in terms of expansion to more TV's in the house.
All .iso's are going to be stored on the server's drives, which is a Norco 20-bay chassis. If I run out of bays in this chassis, I can expand using an SAS expander. All 20 bays will be used for "primary" .iso copies. "Secondary" .iso copies will be on separate drives, stored offline and offsite. After creating an .iso to the primary drive, I simply connect the secondary hard drive via a eSATA dock, and drag the .iso copy over. Once full, this secondary backup drive goes in storage...and then on to the next. Future proof for expansion, and redundantly backed up. For current hard drive cost, it's about $6/blu-ray for the primary and secondary backup total. This will only go down in time.
Seems to me (obviously, I guess it would) to be the fastest, cheapest way to be as future-proof as possible. I gave lowest priority to disk costs. Hope that helps...
post #82 of 175
I just wish I could find a DLNA program that would support streaming a Blu-ray ISO. My TV (a samsung) has a built in DLNA capability. I have blu-ray ISOs on my network but no way yet(other than the aformentioned remux/ or transcoding the streams) to get them to the TV in the other room. I have a laptop wall mounted behind the TV but it isn't powerful enough to play 1080p blurays.
post #83 of 175
Originally Posted by Tom_L View Post
To the OP,
It certainly helps. I started with DVDFab but I think I'm going to switch to AnyDVD. I think keeping the protection intact makes sense in case an update comes along and causes me to re-rip my Blu-Rays. I take it one license for AnyDVD will allow me to run it on multiple HTPCs.
I am also thinking of going for the 20-Bay Norco. I suspect that given my rate of buying movies 20 bays should be enough. But you never know and the concept of an SAS expander is new to me but I was just wondering today how to expand a Norco case + RAID card setup. I was thinking along the lines of eSata but that's not really acceptable for a rack mounted solution. I will read up on it.
Mediabrowser is great program - a real lifesaver.
I'm not yet sure how I'll do backups but eSata transfer sounds like a good idea along with offsite storage. Just keep filling them and moving them as they fill up.
I'm almost considering keeping a separate MKV copy of the discs for compatibility. I already do so with audio with parallel FLAC/ALAC/AAC libraries. The hardest thing is to keep them all consistent. I don't plan on having too many movies initially. But always quality over quantity.
post #84 of 175
Now that would be a great thing. Now if PowerDVD handled managed DLNA streaming it might justify its high cost. There are Blu-Ray players that rival its cost.
post #85 of 175
Like Mike Lang already said, please cool it, guys, or I will have to close this thread. From the OP's initial post:
1. I would like no loss in quality whatsoever in video or audio. I do not believe in transcoding a lossy format.
That is his choice, even if you don't agree with it.
I haven't read this thread, but I will add my 2 cents, even though it has probably all been said - I use AnyDVD HD for ripping to either BDMV or .ISO - no loss of ANYTHING with that method.
Personally speaking, I prefer to load the movie only onto my server (as I always have the originals in case I want to watch the extras), and I hate navigating menus and sitting through (or skipping) movie previews, so I use Eac3to to demux the movie streams and then remux with Mkvmerge. This way I include only the streams I want (full bitrate video, lossless audio re-encoded to FLAC, chapters, and one subtitle stream). This keeps the size of the .MKV down to a minimum yet I sacrifice NOTHING in terms of audio/video quality.
If you want to retain the entire disc along with the extras, then you only need AnyDVD HD. If you want to do like I do, then you will need more programs, most of which are free or available with other HTPC software that you probably already own.
post #86 of 175
Bob,
I just moved into the HTPC world of BluRay last week. I have a collection from my PS3. But want to move just the movies onto my hard drives. I don't care how much space they take up. Space is cheap.
I prefer exactly what you noted above. Just so I have the above straight, you:
1. Use AnyDVD HD to rip to the HD.
2. Eac3to convert the Audio
3. Use Mkvmerge to put the audio back in and make the video .MKV
Is that it?
post #87 of 175
If you don't care about taking up space then ripping to ISO is the best way to preserve the bluray. It's also the quickest and easiest way.
post #88 of 175
Originally Posted by q3131a View Post
Bob,
Is that it?
You can skip #1 rip directly from the disk with eac3to, demux video, audio, subtitles and chapters then remux the tracks you want with mkvmerge.
Mike
post #89 of 175
How long does it take to make an ISO? Ripping with eac3to and remuxing with mkvmerge only takes between 30 minutes to an hour.
Mike
post #90 of 175
Mike
I believe around 30-45 mins. My bluray drive comes tomorrow finally. Really it only takes 30-an hour for the whole encoding? Is there a way to have it auto rip? Also do you have to rip with eac3to then remux with mkvmerge or is it only one step? I want an easy process with simply clicking on rip dvd then coming back in an hour to put in another bluray disk.
