AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › the "help me choose an LCD" thread
the "help me choose an LCD" thread - Page 7
post #181 of 4426
So, I'm on the fence on what LED TV to buy this month. My budget is strictly around $1250 and under for a 40 or 42" LED TV. I'm mounting on a wall with either Samsung or Sanus super slim wall mount so I'm only considering LED models like Samsung and LG which have panel depths of 1.2" or less. As far as my research goes, Samsung and LG are the only makers of 40, 42" models with 1.2" or less panel depths. I'm also on the fence to buy a 2009 model or wait for the 2010 models later this month. I've narrowed my choices to the following:
Samsung UN40B7000 (2009)
Samsung UN40B6000 (2009)
Samsung UN40C5000 (2010)
Samsung UN40C6300 (2010)
How bad is the flashlighting and has it improved with any firmware or later manufactured units? How about input lag, game mode, etc. (big factor)
LG 42SL90 (2009)
LG LE5500 (2010)
LG LE7500 (2010)
LG LX6500 (2010)
Really love the looks of the "borderless" design and one sheet of glass, though I've read a few scant reviews of the SL90 of sub-par black levels, BUT better input lag with LG compared to Samsung.
post #182 of 4426
Originally Posted by bnm81002 View Post
is the 46SV670U set a true 240HZ or is it similar to the 47ZV650U where it's not 100% 240HZ? from what I can tell from researching, it supposedly is true 240HZ but Toshiba's website online manual doesn't clearly state that? if it is 100% true 240HZ then I will buy it, the price difference between the 2 is just $200 more for the SV670U set, so which one would you buy? also, what is LED Backlighting? are all 240HZ sets incorporated with that? thanks
its 120hz with a scanning backlight.
test show they perform nearly as good as true 240hz LCD's and test also show that there is little to no real world benefit of 240hz anyways, the reduced blur was only visible using test patterns to the human eye, normal content looked the same to test subjects in a blind test Cnet did
post #183 of 4426
Originally Posted by frito View Post
120hz does not improve gaming performance, it actually hurts it (adds more input lag)
read the thread in my sig for more info on input lag and to determine if this matters to you
your probably going to need to throw the good speakers part out of the equation though if you want to find a TV that has 120hz and still performs good with gaming
models i would suggest are
any sharp E77U(n), 700UN (both are 120hz)
LG LH90 (120hz local dimming LED)
any Panasonic 37" LCD (720 or 1080p does not matter they both perform good) (most models are 60hz but there should be some 120hz coming out this year, last year only the 37G1 was 120hz)
avoid samsung and sony as they perform the worst generally speaking for gaming but sony is usually better than samsung in this area
Frito, thanks for the recommendation. I'm so wanting the LH90 but my country (Indonesia) doesn't have that, I would die for the backlight local-dimming action. Anyway, move to the other contenders, Sharp E77U, is it the same with A77M? We don't have E77U or 700 UN here..
As for Panasonic, are you refering to the Plasma or the LCD?
I do believe that the TruMotion (or whatever the marketing is) give a bad impression on watching Blu-ray, but it has good benefit on watching football or playing FPS game (some argue that 100 Hz is required for fast pace FPS to look more LIVE than the traditional 50/60 Hz scanning).
Thanks for the reply!
post #184 of 4426
yeah the A77M is likely to be the same or very close to the E77U here in the US
100/120hz hurts gaming because it introduces excessive input lag on a display that already has built in input lag resulting in you actions with the game pad taking on average 70-120 ms to appear on screen (the TV delay's the signal it gets to process it before displaying it)
read the thread linked in my sig on input lag for more in depth information about it if your interested and also do some searches on google for input lag and you will discover tons of information on PC as well as HDTV's
acceptable input lag for the average person would be less than 40-50ms and FPS gamers that are serious about their gaming performance want displays with input lag less than 30ms preferably under 20ms for best performance in games but with HDTV's you have to be realistic and there are few TV's that deliver less than 20ms input lag, that Sharp model and Panasonic LCD's and Plasma's tend to be the only ones that do pretty constantly
post #185 of 4426
I just check the two, and both are different
The E77U unit seems to be superior than the A77 (it cost about 1500 US here in Indonesia)
What do you think of LG units? I'm thinking of SL80 and SL90, they have a 2ms response time, and some reported that the lag is about 30ms-40ms?
I have read your thread, and well I'm in between of SL80 (which report a 30 ms and 10 ms) while the Sharp LE700 is 20ms and 20ms. The Panny S1/G1 unit too has impressive minimum lag. What should I consider from this options?
post #186 of 4426
all great choices really, i would go to a local store that has them if possible and view them for yourself
the LG SL models are slim TV's by the way if that matters to you
post #187 of 4426
1. Budget
Up to $1500 USD (incl. shipping, taxes) - Would prefer to order it from Amazon due to Prime.. but I can also do Best Buy or Walmart.
2. Seating distance
About 5 feet
3. Size/placement limitations
I have a 42" now, so I'm looking for either a 42" or 46", it will be wall-mounted.
4. Uses and sources
Main use is HD television (Dish network), with Xbox 360 gaming and Blu-Ray movies via PS3.
5. Room lighting
Moderate light, dimming lamps, not an issue
Currently have my eye on one of these two.. Anyone own one? Anyone have other suggestions?
Samsung LN46B750 - 46" 1080p 240hz LCD HDTV http://www.amazon.com/Samsung-LN46B7...=1VW0LBMR944DX
or
Sharp 46" 1080p 120hz LCD HDTV http://www.amazon.com/Sharp-AQUOS-LC...=1VW0LBMR944DX
post #188 of 4426
Thanks Frito, actually I'm leaning on LG SL80, as the SL90 has been reported for poor black level. I'll check on the Panasonic G10, anyway, what do you think of Panasonic X15? Should be an improvement of X10.. but reported that it has poor colour calibration..
post #189 of 4426
Frito,
Which of these flat LG LCDs are NOT recommended for internet streaming and games for a bedroom? And, which would you recommend the most for the price?
1) LG 42SL90
2) LG 42SL80
3) LG 42LH90
4) LG 42LH55
5) LG 42LH50
If streaming is not a feature, which LG blue ray with wi/fi would you recommend to support streaming?
post #190 of 4426
I recently moved and am looking for a budget LCD while the next best thing comes out and is perfected in a couple of years, be it 3D or not.
I live in PR, where HDTV sales are not common at all.
Today I saw the 46XV640U at an affordable price, and next to it, they had the 46XV540U in clearance for $20 less.
I know the 540 is older (2008's model?), but by looking at the specs at the Toshiba website, either it has more features (branded as a Regza, has a 10-bit panel, etc), or the 640 features are not as detailed.
The price difference makes me think the 540 is/was much more feature rich than the 640, considering it's in clearance for basically the same price.
I will use it for quite a bit of gaming, too, but noticed both are rated equal by the manufacturer and have a game mode option.
Opinions are appreciated and most likely welcome.
post #191 of 4426
Just a reminder, if anyone has any recommendations for content in the first post, please PM me.
post #192 of 4426
the 46SV670U has LED backlighting, what is that? since not all LCD sets have that, what do they have instead? which is better the LED or the other type used in non-LED LCD's? would you buy the 46SV670U over the 47ZV650U? thanks again
post #193 of 4426
that would mean LED local dimming, i'm not sure how well that performs on that specific model you should probably do a search on google for pro reviews on the model to see how it does i honestly have no clue
post #194 of 4426
Originally Posted by heismanwatch View Post
Frito,
1) LG 42SL90
2) LG 42SL80
3) LG 42LH90
4) LG 42LH55
5) LG 42LH50
not sure on internet streaming i prefer using external devices for that type of stuff, relying on a TV to do such things always has limitations
gaming wise the LH90 and SL80 have been shown to do well, considering that most if not all those models should be using LG IPS panels they should all perform good enough in game mode
post #195 of 4426
Greetings... I hope I follow the guidelines for this, but I have to admit, I am going to mention 1 plasma here.
1. Budget: Around $1,700
2. Seating distance: 14'
3. Size/placement limitations: None
4. Uses and sources: Equally use for Blu-ray, PS3, XBOX 360 Elite, Comcast HD, and Netflix streaming via Xbox... SD signal is a non-issue
5. Room lighting: Variable - I have black-out shades so natural light is not a problem, lighting will be controlled.
I am between the new Samsung LN55C650, Samsung PN58B550, and Sony KDL55EX550 , but am also considering the Samsung UN55B6000... and obviously open for any other suggestions.
From reading hundreds of posts throughout the forum and reviews, I am leaning towards the new LN55C650.
Upgrading from a 3 year old 42" Hitachi P42H01 (relic 1080i - er 720p- plasma) my biggest issue was color banding and poor black levels.
Look forward to your suggestions and let me know if I can provide anymore information. Can't believe it took me so long to find this forum..
post #196 of 4426
here's 2 reviews on the 46SV670U set, 1 review considers it a "Top Pick", the other review considers it a good set, looks like I will be buying it over the 47ZV650U model,
http://hometheatermag.com/flat-panel...670u_lcd_hdtv/
http://reviews.cnet.com/flat-panel-t...-33490604.html
post #197 of 4426
I will come forward and say right away i prefer plasma personally but i'm going to suggest the Plasma not because of that reason but because of your viewing distance you need as big of a TV you can get to get the best experience so i would get the 58" plasma easily over other models
i will also mention that i saw a new C650 LCD at frys today and was somewhat surprised to see visible smearing with dark moving images on it and AMP was turned on and at a high level. it looked pretty bad when that scene was playing but otherwise it had the typical SOE effect that 120hz/AMP is known for when turned up too high and if you don't know what i'm talking about you should view these TV's in a store and play with the AMP settings to see if you like it, plasma does not need motion enhancement and it will be a major change for you coming from a plasma over to an LCD but you may be one of the people that prefer its look over more natural motion on a plasma with less blur
post #198 of 4426
Which LG or other recommended external device could you recommend?
Just curious...
post #199 of 4426
... because of your viewing distance you need as big of a TV you can get to get the best experience so i would get the 58" plasma easily over other models
That was one of my initial thoughts as well... just wasn't sure if there was that much of a difference between plasmas and LCDs at a larger distance.
Yes I am familiar with it, and I questioned the salesman at Best Buy, who was kind enough to hook up a Blu-ray player for a direct source and we played with the settings. With the Brightness turned down and turned down the AMP. With those adjustments, the "smear" decreased but didn't disappear completely (although enough for my liking). With that said, is there a different plasma you would recommend instead of this for the price range? Or would this be my best bet?
Thank you for your input!
post #200 of 4426
Panasonic Plasma's are regarded as the best but Samsung's perform good as well but sometimes have a buzzing problem
2009 model Panasonic's have an issue with their black level's getting lighter as they age but the 58"+ models seem to be exempt from the problem by all owners accounts perhaps take a look at the 58S1 or the 65S1, the 65" is a little bit above your price range but for the viewing distance it would be worth it for sure, you may come across the S14 model at best buy or costco of the 65" which for all intents and purposes is mostly the same thing as the S1
for your money these TV's i'm sure would perform better than any LCD TV your going to find in this price range and size, the only LCD's that are going to come close or beat them in certain areas are the Samsung B8500 and the LG LH90 the 55LH90 you may find for around 2k but the 55B8500 is going to run you 3k and imo its not worth the extra 1k but it is a great TV
post #201 of 4426
Just curious...
i'd personally go with the LH90 because its the best one PQ wise due to local dimming LED, as for external devices that depends on what your planning to play back or stream
post #202 of 4426
Streaming Yahoo, Netflix, Movies, Games, Pandora. At times I'll use it as a PC monitor, but I'll have my laptop for that.
And...why is the 42" LH90 (LED Back-lit 240Hz) less expensive than the 42" SL90 (LED Edge-lit 120Hz)?
Thanks in advance!
post #203 of 4426
Originally Posted by Disturbed932 View Post
LG 42SL90 (2009)
LG LE5500 (2010)
LG LE7500 (2010)
LG LX6500 (2010)
LG LE7500 (2010)
LG LX6500 (2010)
Where can you see ^^^^^^^these two LGs on-line?
post #204 of 4426
Currently have a Toshiba 51h84 Rear Projection in my living room. Works great. No problems, but am thinking of getting a new TV for no reason other than I want something new.
Seating area is 10 feet away. Would getting something larger than 50" even make sense for a room that size?
Ideally want to stay at $1k shipped. Any recommendations?
post #205 of 4426
Hi,
I am trying to decide between the Samsung 40b750 or Sony 40z5100?
1. Budget - $1000 (I have found both these TV's in this price range Sony XBR9 seems higher for not that much improvement in features over z5100)
2. Seating distance - not an issue
3. Size/placement limitations - have room for 40in TV.
4. Uses and sources - bedroom
5. Room lighting - no direct sunlight (so reflection is not a huge concern)
I was suprised to read CNET's review that suggested the Samsung 40b750 was the best of the 40in LCDs (even compared against the Sony XBR). I would be interested if others agree.
In addition to the regular desires and uses (good HD viewing for blue ray movies and standard definition viewing for cable), I am also interested in connecting the sets to the Internet wirelessly so I can access weather and streaming content. So I would be interested in folks thoughts on which set is easier to connect wirelessly (looks like Samsung has an $80 wifi dongle where I don't see one for Sony).
Thank you in advance for your assistance.
post #206 of 4426
Ok please help me decide!
I was pretty much set on going with the Sony KDL-52EX700/701 edge lit LED set until I read some of the issues people are having it in the official forum. I finally got to see it in person in Best Buy and it was hooked up to a Sony BR player and the colors looked great. I was a little concerned with the reflections off the glossy bezel but it was not a HUGE concern.
I then went over to Costco and saw the 46/60" versions (didn't have the 52) and the colors seemed really dull. I wasn't able to get into the menus to see what they set at.
I also got to see the Samsung UN55C7000 up close and personal and it also looked great. Comparing the Sony and Samsung at Best Buy was very close. I liked both the styles but the Samsung's colors did seem a bit more crisp. I don't think that plus the 3D capability of the Sammy would command a $900 difference (if bought in the store). However, with the upcoming deal (free BR player, glasses and AvM movie) I would consider going with the Samsung over the Sony.
Lastly, I have been giving a lot of thought of just going with the Samsung UN55B8500. Its just a tad out of my price range and I'm just hoping for it to drop a couple hundred more (I doubt it will though). The 46" 8500 is right in my price range but I think 46" is just a little too small.
One last issue I have is the TV will be on a stand and not wall mounted. The stand measures 52" across. The 55" Samsungs are 52" across and I wonder if it would look cramped on the stand. The 52" Sony measures 49" across so I'd have an inch and a half on each side.
This is what my living room looks like right now just to show you what I am looking at.
post #207 of 4426
Originally Posted by SixthGear View Post
New user here too, and I'm at a loss for what panel to go with.
Requirements:
Budget - ~$1500-2000
Seating Distance- 8-10ft
Size/Placement Limitations: None
Room Lighting: Fairly bright room, with the light source being a sliding glass door to the left of where the panel will be. The door has big blinds over it that can be closed/turn light away from the TV.
Uses: Gaming (xbox 360), HTPC, TV (HD), Movies
My budget is fairly flexible, but the more I spend on a TV, the less I can spend on other components/TV stand. It's going to be my first TV, and I'd like to get something that will last. I had been wavering back and forth like some other users between Plasma and LCD, and I really don't want to deal with changing black levels and other concerns that go along with owning a plasma (image retention, burn-in). Another thing as far as a concern goes for me is something that is durable. I'm in a career field that sees me moving every few years, so I don't want something that can be broken or damaged easily (even if I'll be reimbursed for the partial value).
Bump.
post #208 of 4426
1. Budget
About $1000
2. Seating distance
The distance between the wall I plan to mount it on and the ledge of my bed is about 4.5 feet, but I'll be sitting on the bed with my back against the other wall, so the expected/maximum viewing distance is around 7 to 8 feet.
It will be wall mounted in my small room. Can probably fit up to a 42" - 46" tv.
4. Uses and sources
Primarily gaming (PS3), watch videos/movies off my computer, and streaming Youtube/Yahoo etc directly from the TV (So I need wi-fi connectivity).
5. Room lighting
My room is definitely not very bright, but I'm used to it. My lights emit yellow light. Sometimes I might use the TV in a darker setting (watching videos/movies)
Others: I'm a total noob when it comes to TVs, so I have no idea how many HDMI ports I'll need and how high the refresh rate should be and etc. Also I do not have a home theatre system in my room, so this TV will need to have good sound as well. I also read that LED (edge-lit LED?) TV's have better picture quality than regular LCDs, so I'd like that if possible. Basically I just want everything to best as best as possible within my budget. Thanks in advance.
post #209 of 4426
Can I get some good suggestions as to which LED to get:
1. Budget - $2800.00
2. Sitting Distance - about 10 to 12 ft
3. Size - 52 to 55 inch
4. Uses - regular TV , movies and the Wii once in awhile
5. Room Lighting - can be altered if need be
I was originally looking at the Sony NX 800 but so far from reading through the forum here and not seeing great reviews about edge lit LED TV's I am now thinking of waiting for the HX900. I am not that much of an expert will I really see a difference in pq with the edge lit LED's or is it something an expert will notice. Thanks in Advance
post #210 of 4426
Ok need some quick guidance for a less used set going into living room. All things being equal on price +-50$, which one:
samsung un46b7000
samsung ln46b750
samsung ln46c650
Vizio XVT472SV
thx, need to pull the trigger tonight if going with the 7000 and don't want to rush into wrong decision. Originally started with a way lower budget for secondary tv, but I like the value out there now on some of last years models, and the thin look of the led.
