Hi all
In need of some serious technical asistance here!
OK I know aledgedly Plasmas are better, but I would still like to go for an LCD, pref LED LCD, FULL HD, I hear that the edge lit with Local Dimming are the ones I need, to avoid crappy blacks/ grey blooming areas? I want rich blacks colours the lot, most state edge lit but nothing about locall dimming as this is the combination i need i gather?
1. my Budget - £1500 the very MAX
2. my Seating distance - Approx 3 Meters
3. my Size/placement limitations - need or should I say want 55"- 60"
4. my Uses and sources - will be used at home in lounge area
5. my Room lighting - spot lights with dimming switches
I have done a bit of research and I can say that most shops dont mention about local dimming, as you can appriciate I am going to be spending over a G's worth of hard earned cash and I want the very best money can buy as the next man, Would really honour your guys honest professional options and any sugestions on makes models and outlets....
I have looked at this model and belive it has local dimming capabilites....?
SAMSUNG UE55C6505 55"
According to :
reevoo.com/p/samsung-ue55c6505
Again should I just scrap the whole idea of LED and just settle for any 55" LCD FULL HD, as they only differ in size ( thickness ) a few cm, and price is more or less £200 - £300 more.
I am after great picture quality! Need FULL HD and minimum TV size 55",
Please please help and point me in the right direction dont want to make a silly mistake early on in the year?
Thanks all in advance!
According to :
