Originally Posted by EscapeVelocity
Cheap, IPS, good blacks = pick any 2
I would look at getting a 42" set, to maximize size whilst keeping the price down. Almost as big as 46/47", really.
Check out the Vizio E420VSE at Costco, it has good blacks but doesnt use an S-IPS panel. It is also just 60 Hz, but is Edge LED backlit....with thin bezels and ultra thin profile.
Also check into Panasonic LCD offerings in 42".
Other than that there is Vizio 42" E422VL which adds 120 Hz and Frame Interpolation which they call Smooth Motion (which is good for Sports) and defeatable. It also uses and LG S-IPS panel. The blacks wont be as good as the Vizio E420VSE at Costco thus the colors and image wont pop as much and when you turn off all the lights the light blacks will be noticeable. This one uses CCFL florescent tubes for backlighting and has rather homely aesthetics....on a plus side this allows for above average sound quality/volume.
If the E420VSE was 120 Hz, that would be the way to go, IMO. But with your stated preference for S-IPS and 120 Hz, the E422VL is worth serious consideration.
Thanks a ton for the advice. Couple questions:
What kind of panel is the E420VSE? TN or VN? How big of a difference in effective viewing angle does IPS make vs the other panels?
Also, how much of a difference does 120hz make? I admit that my opinion about this is probably primarily informed by marketing. What are the real pros/cons of faster refresh rates?
Edited by doublemazaa - 11/10/12 at 12:54pm
